[postgis-tickets] [PostGIS] #5062: check_test_enabled is disabled
PostGIS trac at osgeo.org
Mon Jan 31 09:09:22 PST 2022
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.2.1
 Component:  build/upgrade/install  |    Version:  3.2.x
Resolution:  fixed                  |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"6ab30ba04ff1b24446543b9c16407dde78d8d606/git" 6ab30ba/git]:
 #!CommitTicketReference repository="git"
 revision="6ab30ba04ff1b24446543b9c16407dde78d8d606"
 Enable check-tests-enabled test on "make check"
 Closes #5062
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5062#comment:5>
