[postgis-tickets] [PostGIS] #5076: Extension install with pgaudit in place generates log explosion
trac at osgeo.org
Mon Jan 31 16:37:41 PST 2022
Reporter: pramsey | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: postgis | Version: 3.2.x
Resolution: | Keywords:
Comment (by robe):
This is only an issue in create extension and upgrade extension or is it
an issue also during general use? If only an install/upgrade concern,
this should be under build/upgrade/install section no? And then pass it
off to strk to deal with :)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5076#comment:2>
