[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-655-gc8eedf3ae
git at osgeo.org
git at osgeo.org
Mon Mar 21 23:43:13 PDT 2022
the project "PostGIS".
via c8eedf3aeb1dd571ef7bcf15ad0c19486d9dd031 (commit)
via 5d0da1251cf8adda23d9ae2262245f9bcb956c11 (commit)
via b360ef3f08570f254ae5711c141f95371f25fb2c (commit)
from 842dd8b50274bfec09ab7430a735764d85ce0a0d (commit)
revisions in full, below.
commit c8eedf3aeb1dd571ef7bcf15ad0c19486d9dd031
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Tue Mar 22 09:42:43 2022 +0300
Add NEWS mention of LTO
diff --git a/NEWS b/NEWS
index 8e3199580..deaefa28a 100644
--- a/NEWS
+++ b/NEWS
@@ -15,6 +15,7 @@ PostGIS 3.3.0dev
- #4912, GiST: fix crash on STORAGE EXTERNAL for geography (Aliaksandr Kalenik)
- ST_ConcaveHull GEOS 3.11+ native implementation (Paul Ramsey, Martin Davis)
- #5100, Support for PostgreSQL 15 (atoi removal) (Laurenz Albe)
+ - GH678, Enable Link-Time Optimizations by default if supported (Sergei Shoulbakov)
* New features*
- ST_Letters creates geometries that look like letters (Paul Ramsey)
commit 5d0da1251cf8adda23d9ae2262245f9bcb956c11
Merge: 842dd8b50 b360ef3f0
Author: Sergei <managerzf168 at gmail.com>
Date: Mon Mar 21 10:50:57 2022 +0300
Merge b360ef3f08570f254ae5711c141f95371f25fb2c into 842dd8b50274bfec09ab7430a735764d85ce0a0d
commit b360ef3f08570f254ae5711c141f95371f25fb2c
Author: sergei sh <sshoulbakov at kontur.io>
Date: Sat Mar 12 22:39:19 2022 +0300
LTO enabled by default if supported; selecting ar, ranlib implementation based on compiler vendor; lwgeom, raster: possible uninitialized variable fixes
diff --git a/configure.ac b/configure.ac
index d9335d716..1c36fcbec 100644
--- a/configure.ac
+++ b/configure.ac
@@ -26,8 +26,15 @@ AC_CONFIG_MACRO_DIR([macros])
AC_CONFIG_AUX_DIR([build-aux])
AC_PROG_INSTALL
-# Set default AR_FLAGS before libtool does
-: ${AR_FLAGS=rs}
+dnl Overwrite _LT_PROG_AR
+m4_pushdef([_LT_PROG_AR],
+ [: ${AR_FLAGS=rs}
+ PG_PROG_AR
+ PG_PROG_RANLIB
+ dnl Call original _LT_PROG_AR
+ m4_popdef([_LT_PROG_AR])
+ _LT_PROG_AR
+]) # _LT_PROG_AR
dnl Invoke libtool: we do this as it is the easiest way to find the PIC
dnl flags required to build liblwgeom
@@ -1168,6 +1175,9 @@ if test $ENABLE_DEBUG -eq 1; then
else
AC_DEFINE([PARANOIA_LEVEL], [0], [Disable use of memory checks])
CPPFLAGS="-DNDEBUG $CPPFLAGS"
+ AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -flto], [_cv_flto], [-flto], [], [CFLAGS="$CFLAGS -flto"], [])
+ AC_LIBTOOL_LINKER_OPTION([if $compiler supports -flto], [_cv_flto], [[-flto]], [LDFLAGS="$LDFLAGS -flto"])
fi
AC_DEFINE([POSTGIS_DEBUG_LEVEL], [0], [Define debug level. Default 0])
diff --git a/liblwgeom/varint.c b/liblwgeom/varint.c
index 22b8e7ef6..fca005364 100644
--- a/liblwgeom/varint.c
+++ b/liblwgeom/varint.c
@@ -140,6 +140,7 @@ varint_u64_decode(const uint8_t *the_start, const uint8_t *the_end, size_t *size
lwerror("%s: varint extends past end of buffer", __func__);
+ *size = 0;
return 0;
diff --git a/macros/compiler-vendor.m4 b/macros/compiler-vendor.m4
new file mode 100644
index 000000000..1f91db22d
--- /dev/null
+++ b/macros/compiler-vendor.m4
@@ -0,0 +1,56 @@
+dnl Selecting tool implementation based on compiler vendor
+dnl Wrap Autoconf check for whether GNU compiler is used
+AC_DEFUN([PG_LANG_COMPILER_GNU],
+[_AC_LANG_COMPILER_GNU])
+dnl Check if Clang compiler is used
+AC_DEFUN([PG_LANG_COMPILER_CLANG],
+ AC_CACHE_CHECK([whether we are using Clang],
+ [ac_cv_[]_AC_LANG_ABBREV[]_compiler_clang],
+ [_AC_COMPILE_IFELSE([AC_LANG_PROGRAM([], [[#ifndef __clang__
+ trigger error
+ #endif
+ [pg_compiler_clang=yes],
+ [pg_compiler_clang=no])
+ ac_cv_[]_AC_LANG_ABBREV[]_compiler_clang=$pg_compiler_clang
+ pg_compiler_clang=$ac_cv_[]_AC_LANG_ABBREV[]_compiler_clang
+dnl Determine compiler vendor
+AC_DEFUN([PG_COMPILER_VENDOR],
+ PG_LANG_COMPILER_CLANG
+ PG_LANG_COMPILER_GNU
+ pg_compiler_vendor=
+ if test "$pg_compiler_clang" = "yes"; then
+ pg_compiler_vendor="clang"
+ elif test "$ac_compiler_gnu" = "yes"; then
+ pg_compiler_vendor="gnu"
+ fi
+dnl Select AR based on compiler
+AC_DEFUN([PG_PROG_AR],
+ PG_COMPILER_VENDOR
+ case "$pg_compiler_vendor" in
+ "clang") AC_CHECK_TOOLS(AR, [llvm-ar ar], :) ;;
+ "gnu") AC_CHECK_TOOLS(AR, [gcc-ar ar], :) ;;
+ *) AC_CHECK_TOOL(AR, ar, :) ;;
+ esac
+dnl Select RANLIB based on compiler
+AC_DEFUN([PG_PROG_RANLIB],
+ "clang") AC_CHECK_TOOLS(RANLIB, [llvm-ranlib ranlib], :) ;;
+ "gnu") AC_CHECK_TOOLS(RANLIB, [gcc-ranlib ranlib], :) ;;
+ *) AC_CHECK_TOOL(RANLIB, ranlib, :) ;;
+ esac
diff --git a/raster/test/cunit/cu_raster_geometry.c b/raster/test/cunit/cu_raster_geometry.c
index 65a6021fb..4eee17dc4 100644
--- a/raster/test/cunit/cu_raster_geometry.c
+++ b/raster/test/cunit/cu_raster_geometry.c
@@ -583,6 +583,7 @@ static void test_raster_get_pixel_bilinear() {
double ul_y = 0.0;
double scale_x = 1;
double scale_y = 1;
+ int err;
double xr, yr;
double igt[6];
@@ -623,14 +624,15 @@ static void test_raster_get_pixel_bilinear() {
rt_band_set_pixel(band, 1, 1, 40.0, NULL);
- double value;
- int nodata;
- rt_band_get_pixel_bilinear(
+ double value = 0.0;
+ int nodata = 0;
+ err = rt_band_get_pixel_bilinear(
band,
xw, yw, // double xw, double yw,
&value, &nodata // double *r_value, int *r_nodata)
+ CU_ASSERT_EQUAL(err, ES_NONE);
printf("xw = %g, yw = %g, value = %g, nodata = %d\n", xr, yr, value, nodata);
Summary of changes:
NEWS | 1 +
configure.ac | 14 +++++++--
liblwgeom/varint.c | 1 +
macros/compiler-vendor.m4 | 56 ++++++++++++++++++++++++++++++++++
raster/test/cunit/cu_raster_geometry.c | 8 +++--
5 files changed, 75 insertions(+), 5 deletions(-)
create mode 100644 macros/compiler-vendor.m4
hooks/post-receive
