[SCM] PostGIS branch stable-3.4 updated. 3.4.2-47-g940798dd7
git at osgeo.org
git at osgeo.org
Fri Aug 2 13:26:25 PDT 2024
the project "PostGIS".
The branch, stable-3.4 has been updated
via 940798dd7486499447b35c46666d584e7a2ef2f5 (commit)
via d16152b9300fb97f30488e6b438851a8cbaba1f1 (commit)
via bea6e61f49687cbdddcb02b94a8990b508ce5d73 (commit)
from 4c8093b58e672047ba1ed925be59842f1dc9943b (commit)
revisions in full, below.
commit 940798dd7486499447b35c46666d584e7a2ef2f5
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Aug 2 13:26:20 2024 -0700
News entry for 5752
diff --git a/NEWS b/NEWS
index f80a6ad5b..55a541b9b 100644
--- a/NEWS
+++ b/NEWS
@@ -31,6 +31,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
itself (Paul Ramsey)
- #5720, Correctly mangle special column names in shp2pgsql (Paul Ramsey)
- #5734, Estimate geography extent more correctly (Paul Ramsey)
+ - #5752, ST_ClosestPoint(geography) error (Paul Ramsey)
PostGIS 3.4.2
2024/02/08
commit d16152b9300fb97f30488e6b438851a8cbaba1f1
Date: Fri Aug 2 13:22:24 2024 -0700
Return the appropriate closest points in the geography close point calculation, references #5752
diff --git a/liblwgeom/cunit/cu_geodetic.c b/liblwgeom/cunit/cu_geodetic.c
index 5e89aef3b..98d598e67 100644
--- a/liblwgeom/cunit/cu_geodetic.c
+++ b/liblwgeom/cunit/cu_geodetic.c
@@ -1593,6 +1593,7 @@ static void test_lwgeom_area_sphere(void)
/* end #3393 */
static void test_gbox_to_string_truncated(void)
GBOX g = {
diff --git a/liblwgeom/cunit/cu_tree.c b/liblwgeom/cunit/cu_tree.c
index ce46c1c4f..c60e4e72d 100644
--- a/liblwgeom/cunit/cu_tree.c
+++ b/liblwgeom/cunit/cu_tree.c
@@ -419,6 +419,27 @@ static void test_tree_circ_distance_threshold(void)
+static void test_geography_tree_closestpoint(void)
+ LWGEOM *lwg1, *lwg2, *lwg3;
+ LWPOINT *lwpt;
+ POINT2D pt;
+ /* Simple case */
+ lwg1 = lwgeom_from_wkt("LINESTRING (18 9, 18 1)", LW_PARSER_CHECK_NONE);
+ lwg2 = lwgeom_from_wkt("POINT (16 4)", LW_PARSER_CHECK_NONE);
+ lwg3 = geography_tree_closestpoint(lwg1, lwg2, 0.1);
+ lwpt = (LWPOINT *)lwg3;
+ lwpoint_getPoint2d_p(lwpt, &pt);
+ CU_ASSERT_DOUBLE_EQUAL(pt.x, 18, 0.0001);
+ CU_ASSERT_DOUBLE_EQUAL(pt.y, 4.0024302, 0.0001);
+ lwgeom_free(lwg1);
+ lwgeom_free(lwg2);
+ lwgeom_free(lwg3);
** Used by test harness to register the tests in this file.
@@ -431,4 +452,5 @@ void tree_suite_setup(void)
PG_ADD_TEST(suite, test_tree_circ_pip2);
PG_ADD_TEST(suite, test_tree_circ_distance);
PG_ADD_TEST(suite, test_tree_circ_distance_threshold);
+ PG_ADD_TEST(suite, test_geography_tree_closestpoint);
diff --git a/liblwgeom/lwgeodetic_tree.c b/liblwgeom/lwgeodetic_tree.c
index a425046a0..cbede3750 100644
--- a/liblwgeom/lwgeodetic_tree.c
+++ b/liblwgeom/lwgeodetic_tree.c
@@ -770,11 +770,11 @@ circ_tree_distance_tree_internal(const CIRC_NODE* n1, const CIRC_NODE* n2, doubl
/* Node 2 is a point */
else
- geographic_point_init(n2->p1->x, n2->p1->y, &gp1);
+ geographic_point_init(n2->p1->x, n2->p1->y, &gp2);
geographic_point_init(n1->p1->x, n1->p1->y, &(e.start));
geographic_point_init(n1->p2->x, n1->p2->y, &(e.end));
- close1 = gp1;
- d = edge_distance_to_point(&e, &gp1, &close2);
+ close2 = gp2;
+ d = edge_distance_to_point(&e, &gp2, &close1);
LWDEBUGF(4, " got distance %g", d);
diff --git a/regress/core/geography_expected b/regress/core/geography_expected
index a7062388c..a5ead8c91 100644
--- a/regress/core/geography_expected
+++ b/regress/core/geography_expected
@@ -66,4 +66,4 @@ lrs_llp_2|0.00
lrs_llp_3|1.00
ERROR: geography_line_locate_point: 2st arg is not a point
lrs_substr_1|LINESTRING(9.28 23.25,18.97 25.93)
-lrs_sl_1|LINESTRING(25 40,25 42.79)
+lrs_sl_1|LINESTRING(25 42.79,25 40)
commit bea6e61f49687cbdddcb02b94a8990b508ce5d73
Date: Wed Jul 3 15:13:56 2024 -0700
Bring fixes to script back from head
diff --git a/utils/check_tests_enabled.sh b/utils/check_tests_enabled.sh
index caaca5ceb..3b3d3e298 100755
--- a/utils/check_tests_enabled.sh
+++ b/utils/check_tests_enabled.sh
@@ -1,4 +1,3 @@
#!/bin/sh
usage() {
@@ -33,6 +32,7 @@ check_enabled() {
#cat ${TMPDIR}/enabled_tests
find ${bd} -name '*_expected' |
+ sed 's|//|/|' |
sed 's|_expected$||' > ${TMPDIR}/available_tests
#cat ${TMPDIR}/available_tests
Summary of changes:
NEWS | 1 +
liblwgeom/cunit/cu_geodetic.c | 1 +
liblwgeom/cunit/cu_tree.c | 22 ++++++++++++++++++++++
liblwgeom/lwgeodetic_tree.c | 6 +++---
regress/core/geography_expected | 2 +-
utils/check_tests_enabled.sh | 2 +-
6 files changed, 29 insertions(+), 5 deletions(-)
hooks/post-receive
