[PostGIS] #5740: ST_DistanceSpheroid doesn't return 0 when one geometry contains the other
trac at osgeo.org
Fri Aug 2 16:32:12 PDT 2024
Reporter: cdestigter | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.4.3
Component: postgis | Version: 3.4.x
Resolution: | Keywords:
Comment (by pramsey):
Yep, a little more subtle. The geometry bounding box was sneaking into the
geodetic covers operation, causing a mis-fire when the code started from a
geometry (as in this example).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5740#comment:5>
