[SCM] PostGIS branch master updated. 3.5.0alpha2-28-g5144b6598
Thu Aug 22 09:10:52 PDT 2024
the project "PostGIS".
       via  5144b6598d7c4dbf9812bffca42316b2fef65290 (commit)
       via  9e564dd008f20d3e99874d84ce8f1340df90bfeb (commit)
      from  e3529a98caef2a0018fea994feff2c15e270ea1b (commit)
revisions in full, below.
commit 5144b6598d7c4dbf9812bffca42316b2fef65290
Merge: e3529a98c 9e564dd00
Author: pramsey <pramsey at cleverelephant.ca>
Date:   Thu Aug 22 09:10:50 2024 -0700
    Merge pull request 'Add BBOX and CRS options example for ST_AsGeoJSON function #5739' (!211) from danf/postgis:st_asgeojson_bbox_crs_example into master
    Reviewed-on: https://git.osgeo.org/gitea/postgis/postgis/pulls/211
commit 9e564dd008f20d3e99874d84ce8f1340df90bfeb
Author: Dan <dan.faudemer at gmail.com>
Date:   Mon Aug 19 16:48:33 2024 +0200
diff --git a/doc/reference_output.xml b/doc/reference_output.xml
index f04988142..9317c3af7 100644
--- a/doc/reference_output.xml
+++ b/doc/reference_output.xml
@@ -767,6 +767,11 @@ FROM (VALUES (1, 'one', 'POINT(1 1)'::geometry)) AS t(id, name, geom);</programl
 <para>3D geometries are supported:</para>
 <programlisting>SELECT ST_AsGeoJSON('LINESTRING(1 2 3, 4 5 6)');</programlisting>
 <screen>{"type":"LineString","coordinates":[[1,2,3],[4,5,6]]}</screen>
+<para>Options argument can be used to add BBOX and CRS in GeoJSON output:</para>
+<programlisting> SELECT ST_AsGeoJSON(ST_SetSRID('POINT(1 1)'::geometry, 4326), 9, 4|1);</programlisting>
+<screen>
+  {"type":"Point","crs":{"type":"name","properties":{"name":"urn:ogc:def:crs:EPSG::4326"}},"bbox":[1.000000000,1.000000000,1.000000000,1.000000000],"coordinates":[1,1]}
+</screen>
 	  </refsection>
   <refsection>
     <title>See Also</title>
Summary of changes:
 doc/reference_output.xml | 5 +++++
 1 file changed, 5 insertions(+)
hooks/post-receive
