[SCM] PostGIS branch master updated. 3.5.0alpha2-36-ga331a8ed8
git at osgeo.org
git at osgeo.org
Fri Aug 23 09:21:48 PDT 2024
the project "PostGIS".
via a331a8ed86c89540541eec46c1f257701c1e7a25 (commit)
from 5503f52932016146688e9e917b721e16cd22d975 (commit)
revisions in full, below.
commit a331a8ed86c89540541eec46c1f257701c1e7a25
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Aug 23 09:21:02 2024 -0700
Add documentation note about escaping for inputs to ST_EstimatedExtent
when inputs include quotes and spatial characters, closes #5697
diff --git a/doc/reference_bbox.xml b/doc/reference_bbox.xml
index 9c282d58c..46bfcc698 100644
--- a/doc/reference_bbox.xml
+++ b/doc/reference_bbox.xml
@@ -179,6 +179,12 @@ BOX3D(220227 150406 1,220268 150415 1)
</para>
</note>
+ <note>
+ <para>
+ Escaping names for tables and/or namespaces that include special characters and quotes may require special handling. A user notes: "For schemas and tables, use identifier escaping rules to produce a double-quoted string, and afterwards remove the first and last double-quote character. For geometry column pass as is."
+ </para>
+ </note>
<para role="availability" conformance="1.0.0">Availability: 1.0.0</para>
<para role="changed" conformance="2.1.0.">Changed: 2.1.0. Up to 2.0.x this was called ST_Estimated_Extent.</para>
Summary of changes:
doc/reference_bbox.xml | 6 ++++++
1 file changed, 6 insertions(+)
hooks/post-receive
