[PostGIS] #5769: debbie PostGIS 3.4 failing on make install on PG17
PostGIS trac at osgeo.org
Fri Aug 23 10:41:11 PDT 2024
 Reporter:  robe          |      Owner:  robe
     Type:  defect        |     Status:  assigned
 Priority:  blocker       |  Milestone:  PostGIS 3.4.3
Component:  QA/buildbots  |    Version:  3.4.x
 Keywords:                |
 This might have been a result of switch to build with meson, as the issues
 seem the same as what master had.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5769>
