[SCM] PostGIS branch master updated. 3.5.0alpha2-38-g907df5ff9
git at osgeo.org
git at osgeo.org
Fri Aug 23 12:01:19 PDT 2024
the project "PostGIS".
via 907df5ff97242a1e16e0d9ef08929531301dadf1 (commit)
from 6337992ba91eb278a7df176d28ed50948287c137 (commit)
revisions in full, below.
commit 907df5ff97242a1e16e0d9ef08929531301dadf1
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Aug 23 11:59:23 2024 -0700
Support for GEOS 3.13 and RelateNG.
Most functionality remains the same, but new GEOS predicate implementation has a few small changes.
- Boundary Node Rule relate matrices might be different when
using the "multi-valent end point" rule.
- Relate matrices for situations with invalid MultiPolygons
with shared boundaries might be different. Run ST_MakeValid
to get valid inputs to feed to the calculation.
- Zero length LineStrings are treated as if they are the
equivalent Point object.
References #5770
diff --git a/NEWS b/NEWS
index abd4cc928..acb4fbb67 100644
--- a/NEWS
+++ b/NEWS
@@ -2,12 +2,12 @@ PostGIS 3.5.0
2024/xx/xx
To take advantage of all postgis_sfcgal extension features SFCGAL 1.5 is needed.
-PostgreSQL 12-17 required. GEOS 3.8+ required. Proj 6.1+ required.
+PostgreSQL 12-17 required. GEOS 3.8+ required. Proj 6.1+ required.
Many thanks to our translation teams, in particular:
Dapeng Wang, Zuo Chenwei from HighGo (Chinese Team)
-Teramoto Ikuhiro (Japanese Team)
+Teramoto Ikuhiro (Japanese Team)
Andreas Schild (German Team)
* Breaking Changes *
@@ -38,6 +38,17 @@ Andreas Schild (German Team)
be ST_Contains(ST_Buffer(A, R), B) (Paul Ramsey)
- Remove the WFS_locks extra package. (Paul Ramsey)
- #5747, GH-776, ST_Length: Return 0 for CurvePolygon (Dan Baston)
+ - #5770, support for GEOS 3.13 and RelateNG. Most functionality
+ remains the same, but new GEOS predicate implementation
+ has a few small changes.
+ - Boundary Node Rule relate matrices might be different when
+ using the "multi-valent end point" rule.
+ - Relate matrices for situations with invalid MultiPolygons
+ with shared boundaries might be different. Run ST_MakeValid
+ to get valid inputs to feed to the calculation.
+ - Zero length LineStrings are treated as if they are the
+ equivalent Point object.
* Deprecated signatures *
diff --git a/liblwgeom/gbox.c b/liblwgeom/gbox.c
index 265c69286..ae13dd4f0 100644
--- a/liblwgeom/gbox.c
+++ b/liblwgeom/gbox.c
@@ -346,6 +346,18 @@ gbox_contains_2d(const GBOX *g1, const GBOX *g2)
return LW_TRUE;
+int
+gbox_within_2d(const GBOX *g1, const GBOX *g2)
+ if ( ( g1->xmin < g2->xmin ) || ( g1->xmax > g2->xmax ) ||
+ ( g1->ymin < g2->ymin ) || ( g1->ymax > g2->ymax ) )
+ return LW_FALSE;
+ return LW_TRUE;
int
gbox_contains_point2d(const GBOX *g, const POINT2D *p)
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index 5a7d00c78..85085a49d 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -2060,6 +2060,11 @@ extern int gbox_overlaps_2d(const GBOX *g1, const GBOX *g2);
extern int gbox_contains_2d(const GBOX *g1, const GBOX *g2);
+* Return #LW_TRUE if the first #GBOX is within the second on the 2d plane, #LW_FALSE otherwise.
+extern int gbox_within_2d(const GBOX *g1, const GBOX *g2);
* Copy the values of original #GBOX into duplicate.
diff --git a/liblwgeom/lwgeom_geos.h b/liblwgeom/lwgeom_geos.h
index 4af0d85d4..84638d82b 100644
--- a/liblwgeom/lwgeom_geos.h
+++ b/liblwgeom/lwgeom_geos.h
@@ -33,8 +33,6 @@ typedef void (*GEOSMessageHandler)(const char *fmt, ...) __attribute__ (( format
#include "liblwgeom.h"
#include "lwunionfind.h"
** Public prototypes for GEOS utility functions.
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index 15a69d2d4..67feb698d 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -83,6 +83,7 @@ PG_OBJS= \
lwgeom_box.o \
lwgeom_box3d.o \
lwgeom_geos.o \
+ lwgeom_geos_predicates.o \
lwgeom_geos_prepared.o \
lwgeom_geos_clean.o \
lwgeom_geos_relatematch.o \
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 92b2b5f53..a6bc297b8 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -50,17 +50,6 @@
** Prototypes for SQL-bound functions
-Datum relate_full(PG_FUNCTION_ARGS);
-Datum relate_pattern(PG_FUNCTION_ARGS);
-Datum disjoint(PG_FUNCTION_ARGS);
-Datum touches(PG_FUNCTION_ARGS);
-Datum ST_Intersects(PG_FUNCTION_ARGS);
-Datum crosses(PG_FUNCTION_ARGS);
-Datum contains(PG_FUNCTION_ARGS);
-Datum within(PG_FUNCTION_ARGS);
-Datum containsproperly(PG_FUNCTION_ARGS);
-Datum covers(PG_FUNCTION_ARGS);
-Datum overlaps(PG_FUNCTION_ARGS);
Datum isvalid(PG_FUNCTION_ARGS);
Datum isvalidreason(PG_FUNCTION_ARGS);
Datum isvaliddetail(PG_FUNCTION_ARGS);
@@ -83,7 +72,6 @@ Datum polygonize_garray(PG_FUNCTION_ARGS);
Datum clusterintersecting_garray(PG_FUNCTION_ARGS);
Datum cluster_within_distance_garray(PG_FUNCTION_ARGS);
Datum linemerge(PG_FUNCTION_ARGS);
-Datum coveredby(PG_FUNCTION_ARGS);
Datum hausdorffdistance(PG_FUNCTION_ARGS);
Datum hausdorffdistancedensify(PG_FUNCTION_ARGS);
Datum ST_FrechetDistance(PG_FUNCTION_ARGS);
@@ -100,46 +88,28 @@ Datum pgis_union_geometry_array(PG_FUNCTION_ARGS);
** Prototypes end
PG_FUNCTION_INFO_V1(postgis_geos_version);
Datum postgis_geos_version(PG_FUNCTION_ARGS)
- const char *ver = lwgeom_geos_version();
- text *result = cstring_to_text(ver);
- PG_RETURN_POINTER(result);
+ const char *ver = lwgeom_geos_version();
+ text *result = cstring_to_text(ver);
+ PG_RETURN_POINTER(result);
PG_FUNCTION_INFO_V1(postgis_geos_compiled_version);
Datum postgis_geos_compiled_version(PG_FUNCTION_ARGS)
- const char *ver = lwgeom_geos_compiled_version();
+ const char *ver = lwgeom_geos_compiled_version();
-static char
-is_poly(const GSERIALIZED* g)
- int type = gserialized_get_type(g);
- return type == POLYGONTYPE || type == MULTIPOLYGONTYPE;
-static char
-is_point(const GSERIALIZED* g)
- return type == POINTTYPE || type == MULTIPOINTTYPE;
* @brief Compute the Hausdorff distance thanks to the corresponding GEOS function
* @example ST_HausdorffDistance {@link #hausdorffdistance} - SELECT ST_HausdorffDistance(
* 'POLYGON((0 0, 0 2, 1 2, 2 2, 2 0, 0 0))'::geometry,
* 'POLYGON((0.5 0.5, 0.5 2.5, 1.5 2.5, 2.5 2.5, 2.5 0.5, 0.5 0.5))'::geometry);
PG_FUNCTION_INFO_V1(hausdorffdistance);
@@ -1761,819 +1731,6 @@ Datum isvaliddetail(PG_FUNCTION_ARGS)
PG_RETURN_HEAPTUPLEHEADER(result);
- * overlaps(GSERIALIZED g1,GSERIALIZED g2)
- * @param g1
- * @param g2
- * @return if GEOS::g1->overlaps(g2) returns true
- * @throw an error (elog(ERROR,...)) if GEOS throws an error
-PG_FUNCTION_INFO_V1(overlaps);
- GSERIALIZED *geom1;
- GSERIALIZED *geom2;
- GEOSGeometry *g1, *g2;
- char result;
- GBOX box1, box2;
- geom1 = PG_GETARG_GSERIALIZED_P(0);
- geom2 = PG_GETARG_GSERIALIZED_P(1);
- gserialized_error_if_srid_mismatch(geom1, geom2, __func__);
- /* A.Overlaps(Empty) == FALSE */
- if ( gserialized_is_empty(geom1) || gserialized_is_empty(geom2) )
- PG_RETURN_BOOL(false);
- * short-circuit 1: if geom2 bounding box does not overlap
- * geom1 bounding box we can return FALSE.
- if ( gserialized_get_gbox_p(geom1, &box1) &&
- gserialized_get_gbox_p(geom2, &box2) )
- if ( ! gbox_overlaps_2d(&box1, &box2) )
- initGEOS(lwpgnotice, lwgeom_geos_error);
- g1 = POSTGIS2GEOS(geom1);
- if (!g1)
- HANDLE_GEOS_ERROR("First argument geometry could not be converted to GEOS");
- g2 = POSTGIS2GEOS(geom2);
- if (!g2)
- GEOSGeom_destroy(g1);
- HANDLE_GEOS_ERROR("Second argument geometry could not be converted to GEOS");
- result = GEOSOverlaps(g1,g2);
- GEOSGeom_destroy(g2);
- if (result == 2) HANDLE_GEOS_ERROR("GEOSOverlaps");
- PG_FREE_IF_COPY(geom1, 0);
- PG_FREE_IF_COPY(geom2, 1);
- PG_RETURN_BOOL(result);
-PG_FUNCTION_INFO_V1(contains);
- SHARED_GSERIALIZED *shared_geom1 = ToastCacheGetGeometry(fcinfo, 0);
- SHARED_GSERIALIZED *shared_geom2 = ToastCacheGetGeometry(fcinfo, 1);
- const GSERIALIZED *geom1 = shared_gserialized_get(shared_geom1);
- const GSERIALIZED *geom2 = shared_gserialized_get(shared_geom2);
- int result;
- GBOX box1, box2;
- PrepGeomCache *prep_cache;
- /* A.Contains(Empty) == FALSE */
- if (gserialized_is_empty(geom1) || gserialized_is_empty(geom2))
- POSTGIS_DEBUGF(3, "Contains: type1: %d, type2: %d", gserialized_get_type(geom1), gserialized_get_type(geom2));
- ** short-circuit 1: if geom2 bounding box is not completely inside
- ** geom1 bounding box we can return FALSE.
- if (gserialized_get_gbox_p(geom1, &box1) &&
- gserialized_get_gbox_p(geom2, &box2))
- if (!gbox_contains_2d(&box1, &box2))
- ** short-circuit 2: if geom2 is a point and geom1 is a polygon
- ** call the point-in-polygon function.
- if (is_poly(geom1) && is_point(geom2))
- const GSERIALIZED *gpoint = shared_gserialized_get(shared_geom2);
- LWGEOM *lwpt = lwgeom_from_gserialized(gpoint);
- IntervalTree *itree = GetIntervalTree(fcinfo, shared_geom1);
- bool result = itree_pip_contains(itree, lwpt);
- lwgeom_free(lwpt);
- prep_cache = GetPrepGeomCache(fcinfo, shared_geom1, NULL);
- if ( prep_cache && prep_cache->prepared_geom && prep_cache->gcache.argnum == 1 )
- g1 = POSTGIS2GEOS(geom2);
- if (!g1)
- HANDLE_GEOS_ERROR("Geometry could not be converted to GEOS");
- POSTGIS_DEBUG(4, "containsPrepared: cache is live, running preparedcontains");
- result = GEOSPreparedContains( prep_cache->prepared_geom, g1);
- else
- if (!g1) HANDLE_GEOS_ERROR("First argument geometry could not be converted to GEOS");
- if (!g2)
- POSTGIS_DEBUG(4, "containsPrepared: cache is not ready, running standard contains");
- result = GEOSContains( g1, g2);
- if (result == 2) HANDLE_GEOS_ERROR("GEOSContains");
- PG_RETURN_BOOL(result > 0);
-PG_FUNCTION_INFO_V1(within);
- PG_RETURN_DATUM(CallerFInfoFunctionCall2(contains, fcinfo->flinfo, InvalidOid,
- PG_GETARG_DATUM(1), PG_GETARG_DATUM(0)));
-PG_FUNCTION_INFO_V1(containsproperly);
- char result;
- GBOX box1, box2;
- PrepGeomCache * prep_cache;
- /* A.ContainsProperly(Empty) == FALSE */
- * short-circuit: if geom2 bounding box is not completely inside
- if ( ! gbox_contains_2d(&box1, &box2) )
- prep_cache = GetPrepGeomCache(fcinfo, shared_geom1, 0);
- GEOSGeometry *g = POSTGIS2GEOS(geom2);
- if (!g) HANDLE_GEOS_ERROR("First argument geometry could not be converted to GEOS");
- result = GEOSPreparedContainsProperly( prep_cache->prepared_geom, g);
- GEOSGeom_destroy(g);
- else
- GEOSGeometry *g2;
- GEOSGeometry *g1;
- if (!g2)
- result = GEOSRelatePattern( g1, g2, "T**FF*FF*" );
- * Described at
- * http://lin-ear-th-inking.blogspot.com/2007/06/subtleties-of-ogc-covers-spatial.html
-PG_FUNCTION_INFO_V1(covers);
- int result;
- GBOX box1, box2;
- POSTGIS_DEBUGF(3, "Covers: type1: %d, type2: %d", gserialized_get_type(geom1), gserialized_get_type(geom2));
- /* A.Covers(Empty) == FALSE */
- * short-circuit 1: if geom2 bounding box is not completely inside
- * short-circuit 2: if geom2 is a point and geom1 is a polygon
- * call the point-in-polygon function.
- bool result = itree_pip_covers(itree, lwpt);
- GEOSGeometry *g1 = POSTGIS2GEOS(geom2);
- result = GEOSPreparedCovers( prep_cache->prepared_geom, g1);
- else
- GEOSGeometry *g1;
- GEOSGeometry *g2;
- if (!g2)
- result = GEOSRelatePattern( g1, g2, "******FF*" );
- if (result == 2) HANDLE_GEOS_ERROR("GEOSCovers");
-* ST_Within(A, B) => ST_Contains(B, A) so we just delegate this calculation to the
-* Contains implementation.
- * Described at:
-PG_FUNCTION_INFO_V1(coveredby);
- int result;
- GBOX box1, box2;
- char *patt = "**F**F***";
- POSTGIS_DEBUGF(3, "CoveredBy: type1: %d, type2: %d", gserialized_get_type(geom1), gserialized_get_type(geom2));
- /* A.CoveredBy(Empty) == FALSE */
- * short-circuit 1: if geom1 bounding box is not completely inside
- * geom2 bounding box we can return FALSE.
- if ( ! gbox_contains_2d(&box2, &box1) )
- POSTGIS_DEBUG(3, "bounding box short-circuit missed.");
- * short-circuit 2: if geom1 is a point and geom2 is a polygon
- if (is_point(geom1) && is_poly(geom2))
- const GSERIALIZED *gpoint = shared_gserialized_get(shared_geom1);
- IntervalTree *itree = GetIntervalTree(fcinfo, shared_geom2);
- if (!g1)
- if (!g2)
- result = GEOSRelatePattern(g1,g2,patt);
- if (result == 2) HANDLE_GEOS_ERROR("GEOSCoveredBy");
-PG_FUNCTION_INFO_V1(crosses);
- int result;
- GBOX box1, box2;
- /* A.Crosses(Empty) == FALSE */
- if ( gbox_overlaps_2d(&box1, &box2) == LW_FALSE )
- if (!g1)
- if (!g2)
- result = GEOSCrosses(g1,g2);
- if (result == 2) HANDLE_GEOS_ERROR("GEOSCrosses");
-PG_FUNCTION_INFO_V1(ST_Intersects);
- int result;
- GBOX box1, box2;
- /* A.Intersects(Empty) == FALSE */
- * short-circuit 2: if the geoms are a point and a polygon,
- * call the itree_pip_intersects function.
- if ((is_point(geom1) && is_poly(geom2)) ||
- (is_point(geom2) && is_poly(geom1)))
- SHARED_GSERIALIZED *shared_gpoly = is_poly(geom1) ? shared_geom1 : shared_geom2;
- SHARED_GSERIALIZED *shared_gpoint = is_point(geom1) ? shared_geom1 : shared_geom2;
- const GSERIALIZED *gpoint = shared_gserialized_get(shared_gpoint);
- IntervalTree *itree = GetIntervalTree(fcinfo, shared_gpoly);
- bool result = itree_pip_intersects(itree, lwpt);
- prep_cache = GetPrepGeomCache(fcinfo, shared_geom1, shared_geom2);
- if ( prep_cache && prep_cache->prepared_geom )
- if ( prep_cache->gcache.argnum == 1 )
- if (!g) HANDLE_GEOS_ERROR("Geometry could not be converted to GEOS");
- result = GEOSPreparedIntersects( prep_cache->prepared_geom, g);
- else
- GEOSGeometry *g = POSTGIS2GEOS(geom1);
- if (!g)
- else
- GEOSGeometry *g1;
- GEOSGeometry *g2;
- if (!g2)
- result = GEOSIntersects( g1, g2);
- if (result == 2) HANDLE_GEOS_ERROR("GEOSIntersects");
-PG_FUNCTION_INFO_V1(touches);
- char result;
- GBOX box1, box2;
- /* A.Touches(Empty) == FALSE */
- g1 = POSTGIS2GEOS(geom1 );
- if (!g1)
- g2 = POSTGIS2GEOS(geom2 );
- if (!g2)
- result = GEOSTouches(g1,g2);
- if (result == 2) HANDLE_GEOS_ERROR("GEOSTouches");
-PG_FUNCTION_INFO_V1(disjoint);
- char result;
- GBOX box1, box2;
- /* A.Disjoint(Empty) == TRUE */
- PG_RETURN_BOOL(true);
- * geom1 bounding box we can return TRUE.
- if (!g1)
- if (!g2)
- result = GEOSDisjoint(g1,g2);
- if (result == 2) HANDLE_GEOS_ERROR("GEOSDisjoint");
-PG_FUNCTION_INFO_V1(relate_pattern);
- char *patt;
- char result;
- size_t i;
- /* TODO handle empty */
- if (!g1)
- if (!g2)
- patt = DatumGetCString(DirectFunctionCall1(textout, PG_GETARG_DATUM(2)));
- ** Need to make sure 't' and 'f' are upper-case before handing to GEOS
- for ( i = 0; i < strlen(patt); i++ )
- if ( patt[i] == 't' ) patt[i] = 'T';
- if ( patt[i] == 'f' ) patt[i] = 'F';
- pfree(patt);
- if (result == 2) HANDLE_GEOS_ERROR("GEOSRelatePattern");
-PG_FUNCTION_INFO_V1(relate_full);
- char *relate_str;
- text *result;
- int bnr = GEOSRELATE_BNR_OGC;
- if ( PG_NARGS() > 2 )
- bnr = PG_GETARG_INT32(2);
- if (!g1)
- if (!g2)
- POSTGIS_DEBUG(3, "constructed geometries ");
- POSTGIS_DEBUGF(3, "%s", GEOSGeomToWKT(g1));
- POSTGIS_DEBUGF(3, "%s", GEOSGeomToWKT(g2));
- relate_str = GEOSRelateBoundaryNodeRule(g1, g2, bnr);
- if (!relate_str) HANDLE_GEOS_ERROR("GEOSRelate");
- result = cstring_to_text(relate_str);
- GEOSFree(relate_str);
- PG_RETURN_TEXT_P(result);
-PG_FUNCTION_INFO_V1(ST_Equals);
-Datum ST_Equals(PG_FUNCTION_ARGS)
- char result;
- GBOX box1, box2;
- /* Empty == Empty */
- if ( gserialized_is_empty(geom1) && gserialized_is_empty(geom2) )
- * short-circuit: If geom1 and geom2 do not have the same bounding box
- * we can return FALSE.
- if ( gbox_same_2d_float(&box1, &box2) == LW_FALSE )
- * short-circuit: if geom1 and geom2 are binary-equivalent, we can return
- * TRUE. This is much faster than doing the comparison using GEOS.
- if (VARSIZE(geom1) == VARSIZE(geom2) && !memcmp(geom1, geom2, VARSIZE(geom1))) {
- if (!g1)
- if (!g2)
- result = GEOSEquals(g1,g2);
- if (result == 2) HANDLE_GEOS_ERROR("GEOSEquals");
PG_FUNCTION_INFO_V1(issimple);
Datum issimple(PG_FUNCTION_ARGS)
diff --git a/postgis/lwgeom_geos_predicates.c b/postgis/lwgeom_geos_predicates.c
new file mode 100644
index 000000000..ec97e0185
--- /dev/null
+++ b/postgis/lwgeom_geos_predicates.c
@@ -0,0 +1,993 @@
+ * PostGIS - Spatial Types for PostgreSQL
+ * http://postgis.net
+ * PostGIS is free software: you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation, either version 2 of the License, or
+ * (at your option) any later version.
+ * PostGIS is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with PostGIS. If not, see <http://www.gnu.org/licenses/>.
+ * Copyright 2009-2014 Sandro Santilli <strk at kbt.io>
+ * Copyright 2008 Paul Ramsey <pramsey at cleverelephant.ca>
+ * Copyright 2001-2003 Refractions Research Inc.
+#include "../postgis_config.h"
+/* PostgreSQL */
+#include "postgres.h"
+#include "funcapi.h"
+#include "utils/array.h"
+#include "utils/builtins.h"
+#include "utils/lsyscache.h"
+#include "utils/numeric.h"
+#include "access/htup_details.h"
+/* PostGIS */
+#include "lwgeom_geos.h"
+#include "liblwgeom.h"
+#include "liblwgeom_internal.h"
+#include "lwgeom_itree.h"
+#include "lwgeom_geos_prepared.h"
+#include "lwgeom_accum.h"
+/* Prototypes for SQL-bound functions */
+Datum relate_full(PG_FUNCTION_ARGS);
+Datum relate_pattern(PG_FUNCTION_ARGS);
+Datum disjoint(PG_FUNCTION_ARGS);
+Datum touches(PG_FUNCTION_ARGS);
+Datum ST_Intersects(PG_FUNCTION_ARGS);
+Datum crosses(PG_FUNCTION_ARGS);
+Datum contains(PG_FUNCTION_ARGS);
+Datum within(PG_FUNCTION_ARGS);
+Datum containsproperly(PG_FUNCTION_ARGS);
+Datum covers(PG_FUNCTION_ARGS);
+Datum overlaps(PG_FUNCTION_ARGS);
+Datum coveredby(PG_FUNCTION_ARGS);
+Datum ST_Equals(PG_FUNCTION_ARGS);
+ * Utility to quickly check for polygonal geometries
+static inline char
+is_poly(const GSERIALIZED* g)
+ int type = gserialized_get_type(g);
+ return type == POLYGONTYPE || type == MULTIPOLYGONTYPE;
+ * Utility to quickly check for point geometries
+static inline char
+is_point(const GSERIALIZED* g)
+ return type == POINTTYPE || type == MULTIPOINTTYPE;
+PG_FUNCTION_INFO_V1(ST_Intersects);
+ SHARED_GSERIALIZED *shared_geom1 = ToastCacheGetGeometry(fcinfo, 0);
+ SHARED_GSERIALIZED *shared_geom2 = ToastCacheGetGeometry(fcinfo, 1);
+ const GSERIALIZED *geom1 = shared_gserialized_get(shared_geom1);
+ const GSERIALIZED *geom2 = shared_gserialized_get(shared_geom2);
+ int result;
+ GBOX box1, box2;
+ PrepGeomCache *prep_cache;
+ gserialized_error_if_srid_mismatch(geom1, geom2, __func__);
+ /* A.Intersects(Empty) == FALSE */
+ if ( gserialized_is_empty(geom1) || gserialized_is_empty(geom2) )
+ PG_RETURN_BOOL(false);
+ * Short-circuit 1: if geom2 bounding box does not overlap
+ * geom1 bounding box we can return FALSE.
+ if ( gserialized_get_gbox_p(geom1, &box1) &&
+ gserialized_get_gbox_p(geom2, &box2) )
+ if ( gbox_overlaps_2d(&box1, &box2) == LW_FALSE )
+ * Short-circuit 2: if the geoms are a point and a polygon,
+ * call the itree_pip_intersects function.
+ if ((is_point(geom1) && is_poly(geom2)) ||
+ (is_point(geom2) && is_poly(geom1)))
+ SHARED_GSERIALIZED *shared_gpoly = is_poly(geom1) ? shared_geom1 : shared_geom2;
+ SHARED_GSERIALIZED *shared_gpoint = is_point(geom1) ? shared_geom1 : shared_geom2;
+ const GSERIALIZED *gpoint = shared_gserialized_get(shared_gpoint);
+ LWGEOM *lwpt = lwgeom_from_gserialized(gpoint);
+ IntervalTree *itree = GetIntervalTree(fcinfo, shared_gpoly);
+ bool result = itree_pip_intersects(itree, lwpt);
+ lwgeom_free(lwpt);
+ PG_RETURN_BOOL(result);
+ initGEOS(lwpgnotice, lwgeom_geos_error);
+ prep_cache = GetPrepGeomCache(fcinfo, shared_geom1, shared_geom2);
+ if ( prep_cache && prep_cache->prepared_geom )
+ GEOSGeometry *g = prep_cache->gcache.argnum == 1
+ ? POSTGIS2GEOS(geom2)
+ : POSTGIS2GEOS(geom1);
+ if (!g) HANDLE_GEOS_ERROR("Geometry could not be converted to GEOS");
+ result = GEOSPreparedIntersects(prep_cache->prepared_geom, g);
+ GEOSGeom_destroy(g);
+ else
+ GEOSGeometry *g1, *g2;
+ g1 = POSTGIS2GEOS(geom1);
+ if (!g1) HANDLE_GEOS_ERROR("First argument geometry could not be converted to GEOS");
+ g2 = POSTGIS2GEOS(geom2);
+ if (!g2)
+ GEOSGeom_destroy(g1);
+ HANDLE_GEOS_ERROR("Second argument geometry could not be converted to GEOS");
+ result = GEOSIntersects(g1, g2);
+ GEOSGeom_destroy(g2);
+ if (result == 2) HANDLE_GEOS_ERROR("GEOSIntersects");
+PG_FUNCTION_INFO_V1(ST_Equals);
+ char result;
+ GBOX box1, box2;
+ /* Empty == Empty */
+ if ( gserialized_is_empty(geom1) && gserialized_is_empty(geom2) )
+ PG_RETURN_BOOL(true);
+ * Short-circuit: If geom1 and geom2 do not have the same bounding box
+ * we can return FALSE.
+ if ( gbox_same_2d_float(&box1, &box2) == LW_FALSE )
+ * Short-circuit: if geom1 and geom2 are binary-equivalent, we can return
+ * TRUE. This is much faster than doing the comparison using GEOS.
+ if (VARSIZE(geom1) == VARSIZE(geom2) && !memcmp(geom1, geom2, VARSIZE(geom1))) {
+ if (!g2)
+ result = GEOSEquals(g1, g2);
+ if (result == 2) HANDLE_GEOS_ERROR("GEOSEquals");
+PG_FUNCTION_INFO_V1(touches);
+ char result;
+ GBOX box1, box2;
+ /* A.Touches(Empty) == FALSE */
+ result = GEOSPreparedTouches(prep_cache->prepared_geom, g);
+ else
+ if (!g2)
+ result = GEOSTouches(g1, g2);
+ if (result == 2) HANDLE_GEOS_ERROR("GEOSTouches");
+PG_FUNCTION_INFO_V1(disjoint);
+ char result;
+ GBOX box1, box2;
+ /* A.Disjoint(Empty) == TRUE */
+ * geom1 bounding box we can return TRUE.
+ result = GEOSPreparedDisjoint(prep_cache->prepared_geom, g);
+ else
+ if (!g2)
+ result = GEOSDisjoint(g1, g2);
+ if (result == 2) HANDLE_GEOS_ERROR("GEOSDisjoint");
+ * ST_Overlaps(geometry, geometry)
+PG_FUNCTION_INFO_V1(overlaps);
+ char result;
+ GBOX box1, box2;
+ /* A.Overlaps(Empty) == FALSE */
+ if ( ! gbox_overlaps_2d(&box1, &box2) )
+ result = GEOSPreparedOverlaps(prep_cache->prepared_geom, g);
+ else
+ if (!g2)
+ result = GEOSOverlaps(g1, g2);
+ if (result == 2) HANDLE_GEOS_ERROR("GEOSOverlaps");
+ * ST_Crosses(geometry, geometry)
+PG_FUNCTION_INFO_V1(crosses);
+ int result;
+ GBOX box1, box2;
+ /* A.Crosses(Empty) == FALSE */
+ result = GEOSPreparedCrosses(prep_cache->prepared_geom, g);
+ else
+ if (!g2)
+ result = GEOSCrosses(g1, g2);
+ if (result == 2) HANDLE_GEOS_ERROR("GEOSCrosses");
+ * ST_Contains(geometry, geometry)
+PG_FUNCTION_INFO_V1(contains);
+ int result;
+ GBOX box1, box2;
+ /* A.Contains(Empty) == FALSE */
+ if (gserialized_is_empty(geom1) || gserialized_is_empty(geom2))
+ POSTGIS_DEBUGF(3, "Contains: type1: %d, type2: %d", gserialized_get_type(geom1), gserialized_get_type(geom2));
+ ** Short-circuit 1: if geom2 bounding box is not completely inside
+ ** geom1 bounding box we can return FALSE.
+ if (gserialized_get_gbox_p(geom1, &box1) &&
+ gserialized_get_gbox_p(geom2, &box2))
+ if (!gbox_contains_2d(&box1, &box2))
+ ** Short-circuit 2: if geom2 is a point and geom1 is a polygon
+ ** call the point-in-polygon function.
+ if (is_poly(geom1) && is_point(geom2))
+ const GSERIALIZED *gpoint = shared_gserialized_get(shared_geom2);
+ IntervalTree *itree = GetIntervalTree(fcinfo, shared_geom1);
+ bool result = itree_pip_contains(itree, lwpt);
+ prep_cache = GetPrepGeomCache(fcinfo, shared_geom1, NULL);
+ if ( prep_cache && prep_cache->prepared_geom && prep_cache->gcache.argnum == 1 )
+ g1 = POSTGIS2GEOS(geom2);
+ if (!g1)
+ HANDLE_GEOS_ERROR("Geometry could not be converted to GEOS");
+ result = GEOSPreparedContains( prep_cache->prepared_geom, g1);
+ else
+ if (!g2)
+ result = GEOSContains( g1, g2);
+ if (result == 2) HANDLE_GEOS_ERROR("GEOSContains");
+ PG_RETURN_BOOL(result > 0);
+ * ST_Within(geometry, geometry)
+PG_FUNCTION_INFO_V1(within);
+ int result;
+ GBOX box1, box2;
+ if (!gbox_within_2d(&box1, &box2))
+ ** Short-circuit 2: if geom2 is a polygon and geom1 is a point
+ if (is_poly(geom2) && is_point(geom1))
+ const GSERIALIZED *gpoint = shared_gserialized_get(shared_geom1);
+ IntervalTree *itree = GetIntervalTree(fcinfo, shared_geom2);
+ if ( prep_cache && prep_cache->prepared_geom && prep_cache->gcache.argnum == 2 )
+ if (!g1)
+ result = GEOSPreparedContains(prep_cache->prepared_geom, g1);
+ else
+ if (!g2)
+ result = GEOSWithin(g1, g2);
+ if ( result == 2 ) HANDLE_GEOS_ERROR("GEOSWithin");
+ * ST_ContainsProperly(geometry, geometry)
+PG_FUNCTION_INFO_V1(containsproperly);
+ char result;
+ GBOX box1, box2;
+ /* A.ContainsProperly(Empty) == FALSE */
+ * Short-circuit: if geom2 bounding box is not completely inside
+ if ( ! gbox_contains_2d(&box1, &box2) )
+ prep_cache = GetPrepGeomCache(fcinfo, shared_geom1, 0);
+ GEOSGeometry *g = POSTGIS2GEOS(geom2);
+ if (!g) HANDLE_GEOS_ERROR("First argument geometry could not be converted to GEOS");
+ result = GEOSPreparedContainsProperly( prep_cache->prepared_geom, g);
+ else
+ if (!g2)
+ result = GEOSRelatePattern(g1, g2, "T**FF*FF*");
+ if (result == 2) HANDLE_GEOS_ERROR("GEOSContainProperly");
+ * ST_Covers(geometry, geometry)
+ * http://lin-ear-th-inking.blogspot.com/2007/06/subtleties-of-ogc-covers-spatial.html
+PG_FUNCTION_INFO_V1(covers);
+ int result;
+ GBOX box1, box2;
+ POSTGIS_DEBUGF(3, "Covers: type1: %d, type2: %d", gserialized_get_type(geom1), gserialized_get_type(geom2));
+ /* A.Covers(Empty) == FALSE */
+ * Short-circuit 1: if geom2 bounding box is not completely inside
+ * Short-circuit 2: if geom2 is a point and geom1 is a polygon
+ * call the point-in-polygon function.
+ bool result = itree_pip_covers(itree, lwpt);
+ GEOSGeometry *g1 = POSTGIS2GEOS(geom2);
+ result = GEOSPreparedCovers( prep_cache->prepared_geom, g1);
+ else
+ if (!g2)
+ result = GEOSRelatePattern( g1, g2, "******FF*" );
+ if (result == 2) HANDLE_GEOS_ERROR("GEOSCovers");
+ * ST_CoveredBy(geometry, geometry)
+ * Described at:
+PG_FUNCTION_INFO_V1(coveredby);
+ int result;
+ GBOX box1, box2;
+ POSTGIS_DEBUGF(3, "CoveredBy: type1: %d, type2: %d", gserialized_get_type(geom1), gserialized_get_type(geom2));
+ /* A.CoveredBy(Empty) == FALSE */
+ * Short-circuit 1: if geom1 bounding box is not completely inside
+ * geom2 bounding box we can return FALSE.
+ if ( ! gbox_within_2d(&box1, &box2) )
+ * Short-circuit 2: if geom1 is a point and geom2 is a polygon
+ if (is_point(geom1) && is_poly(geom2))
+ if ( prep_cache && prep_cache->prepared_geom && prep_cache->gcache.argnum == 2)
+ else
+ if (!g2)
+ result = GEOSCoveredBy(g1, g2);
+ if (result == 2) HANDLE_GEOS_ERROR("GEOSCoveredBy");
+PG_FUNCTION_INFO_V1(relate_pattern);
+ text *patt = PG_GETARG_TEXT_P(2);
+ char *pstr = text_to_cstring(patt);
+ char result;
+ size_t i;
+#if POSTGIS_GEOS_VERSION >= 31300
+#endif
+ ** Need to make sure 't' and 'f' are upper-case before handing to GEOS
+ for ( i = 0; i < strlen(pstr); i++ )
+ if ( pstr[i] == 't' ) pstr[i] = 'T';
+ if ( pstr[i] == 'f' ) pstr[i] = 'F';
+ result = GEOSPreparedRelatePattern(prep_cache->prepared_geom, g, pstr);
+ else
+#endif
+ if (!g2)
+ result = GEOSRelatePattern(g1, g2, pstr);
+ pfree(pstr);
+ if (result == 2) HANDLE_GEOS_ERROR("GEOSRelatePattern");
+PG_FUNCTION_INFO_V1(relate_full);
+ GSERIALIZED *geom1 = PG_GETARG_GSERIALIZED_P(0);
+ GSERIALIZED *geom2 = PG_GETARG_GSERIALIZED_P(1);
+ char *relate_str;
+ text *result;
+ int bnr = GEOSRELATE_BNR_OGC;
+ /* TODO handle empty */
+ if ( PG_NARGS() > 2 )
+ bnr = PG_GETARG_INT32(2);
+ if (!g1)
+ HANDLE_GEOS_ERROR("First argument geometry could not be converted to GEOS");
+ if (!g2)
+ POSTGIS_DEBUG(3, "constructed geometries ");
+ POSTGIS_DEBUGF(3, "%s", GEOSGeomToWKT(g1));
+ POSTGIS_DEBUGF(3, "%s", GEOSGeomToWKT(g2));
+ relate_str = GEOSRelateBoundaryNodeRule(g1, g2, bnr);
+ if (!relate_str) HANDLE_GEOS_ERROR("GEOSRelate");
+ result = cstring_to_text(relate_str);
+ GEOSFree(relate_str);
+ PG_FREE_IF_COPY(geom1, 0);
+ PG_FREE_IF_COPY(geom2, 1);
+ PG_RETURN_TEXT_P(result);
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index e8524bd1f..e62a2c1c8 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4492,8 +4492,8 @@ CREATE OR REPLACE FUNCTION ST_Relate(geom1 geometry, geom2 geometry, integer)
LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
_COST_HIGH;
--- PostGIS equivalent function: relate(geom1 geometry, geom2 geometry,text)
-CREATE OR REPLACE FUNCTION ST_Relate(geom1 geometry, geom2 geometry,text)
+-- PostGIS equivalent function: relate(geom1 geometry, geom2 geometry, text)
+CREATE OR REPLACE FUNCTION ST_Relate(geom1 geometry, geom2 geometry, text)
RETURNS boolean
AS 'MODULE_PATHNAME','relate_pattern'
diff --git a/raster/rt_core/rt_wkb.c b/raster/rt_core/rt_wkb.c
index 7fcf3ed3c..84b7ed55b 100644
--- a/raster/rt_core/rt_wkb.c
+++ b/raster/rt_core/rt_wkb.c
@@ -353,7 +353,7 @@ rt_raster_from_wkb(const uint8_t* wkb, uint32_t wkbsize) {
if (!rast->numBands) {
/* Here ptr should have been left to right after last used byte */
if (ptr < wkbend) {
- rtwarn("%" PRIu64 " bytes of WKB remained unparsed", wkbend - ptr);
+ rtwarn("%zu bytes of WKB remained unparsed", wkbend - ptr);
else if (ptr > wkbend) {
/* Easier to get a segfault before I guess */
diff --git a/regress/core/relate.sql b/regress/core/relate.sql
index 07e2233db..a7172a40d 100644
--- a/regress/core/relate.sql
+++ b/regress/core/relate.sql
@@ -23,8 +23,8 @@ SELECT '22', ST_Relate('LINESTRING(100 140,100 40)','MULTIPOLYGON(((20 80,180 79
SELECT '23', ST_Relate('LINESTRING(100 140,100 40)','MULTIPOLYGON(((20 80,180 80,100 0,20 80)),((20 160,180 160,100 80,20 160)))');
SELECT '24', ST_Relate('LINESTRING(110 60,20 150,200 150,110 60)','POLYGON((20 20,200 20,110 110,20 20))');
SELECT '25', ST_Relate('LINESTRING(0 0,0 50,50 50,50 0,0 0)','MULTILINESTRING((0 0,0 50),(0 50,50 50),(50 50,50 0),(50 0,0 0))');
-SELECT '26', ST_Relate('LINESTRING(40 180,140 180)','MULTIPOLYGON(((20 320,180 320,180 180,20 180,20 320)),((20 180,20 80,180 80,180 180,20 180)))');
-SELECT '27', ST_Relate('LINESTRING(40 180,140 180)','MULTIPOLYGON(((20 320,180 320,180 180,20 180,20 320)),((60 180,60 80,180 80,180 180,60 180)))');
+SELECT '26', ST_Relate('LINESTRING(40 180,140 180)','GEOMETRYCOLLECTION(POLYGON((20 320,180 320,180 180,20 180,20 320)),POLYGON((20 180,20 80,180 80,180 180,20 180)))');
+SELECT '27', ST_Relate('LINESTRING(40 180,140 180)','GEOMETRYCOLLECTION(POLYGON((20 320,180 320,180 180,20 180,20 320)),POLYGON((60 180,60 80,180 80,180 180,60 180)))');
SELECT '28', ST_Relate('LINESTRING(0 0,60 0,60 60,60 0,120 0)','MULTILINESTRING((0 0,60 0),(60 0,120 0),(60 0,60 60))');
SELECT '29', ST_Relate('LINESTRING(60 0,20 80,100 80,80 120,40 140)','LINESTRING(140 300,220 160,260 200,240 260)');
SELECT '30', ST_Relate('LINESTRING(60 0,20 80,100 80,80 120,40 140)','LINESTRING(60 40,140 40,140 160,0 160)');
@@ -253,8 +253,8 @@ SELECT '252', ST_Relate('MULTILINESTRING((20 110,200 110,200 160),(110 110,200 1
SELECT '253', ST_Relate('MULTILINESTRING((20 160,70 110,150 110,200 160),(110 110,20 110,50 80,70 110,200 110))','MULTIPOLYGON(((110 110,20 20,200 20,110 110)),((110 110,20 200,200 200,110 110)))');
SELECT '254', ST_Relate('MULTILINESTRING((20 110,200 110),(110 110,20 170,20 130,200 90))','MULTIPOLYGON(((110 110,20 20,200 20,110 110)),((110 110,20 200,200 200,110 110)))');
SELECT '255', ST_Relate('LINESTRING(0 0,0 50,50 50,50 0,0 0)','MULTILINESTRING((0 0,0 50),(0 50,50 50),(50 50,50 0),(50 0,0 0))');
-SELECT '256', ST_Relate('LINESTRING(40 180,140 180)','MULTIPOLYGON(((20 320,180 320,180 180,20 180,20 320)),((20 180,20 80,180 80,180 180,20 180)))');
-SELECT '257', ST_Relate('LINESTRING(40 180,140 180)','MULTIPOLYGON(((20 320,180 320,180 180,20 180,20 320)),((60 180,60 80,180 80,180 180,60 180)))');
+SELECT '256', ST_Relate('LINESTRING(40 180,140 180)','GEOMETRYCOLLECTION(POLYGON((20 320,180 320,180 180,20 180,20 320)),POLYGON((20 180,20 80,180 80,180 180,20 180)))');
+SELECT '257', ST_Relate('LINESTRING(40 180,140 180)','GEOMETRYCOLLECTION(POLYGON((20 320,180 320,180 180,20 180,20 320)),POLYGON((60 180,60 80,180 80,180 180,60 180)))');
SELECT '258', ST_Relate('LINESTRING(0 0,60 0,60 60,60 0,120 0)','MULTILINESTRING((0 0,60 0),(60 0,120 0),(60 0,60 60))');
SELECT '259', ST_Relate('LINESTRING(40 40,120 120)','LINESTRING(40 40,60 120)');
SELECT '260', ST_Relate('LINESTRING(40 40,120 120)','LINESTRING(60 240,40 40)');
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index d2dfe71a7..3dd65b92f 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -132,7 +132,6 @@ TESTS += \
$(top_srcdir)/regress/core/unaryunion \
$(top_srcdir)/regress/core/union \
$(top_srcdir)/regress/core/clean \
- $(top_srcdir)/regress/core/relate_bnr \
$(top_srcdir)/regress/core/delaunaytriangles \
$(top_srcdir)/regress/core/clipbybox2d \
$(top_srcdir)/regress/core/subdivide \
@@ -178,6 +177,11 @@ ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 31200),1)
$(top_srcdir)/regress/core/coverage
endif
+ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" "<=" 31200),1)
+ TESTS += \
+ $(top_srcdir)/regress/core/relate_bnr
+endif
ifeq ($(INTERRUPTTESTS),yes)
# Allow CI servers to configure --with-interrupt-tests
TESTS += \
Summary of changes:
NEWS | 15 +-
liblwgeom/gbox.c | 12 +
liblwgeom/liblwgeom.h.in | 5 +
liblwgeom/lwgeom_geos.h | 2 -
postgis/Makefile.in | 1 +
postgis/lwgeom_geos.c | 855 +--------------------------------
postgis/lwgeom_geos_predicates.c | 993 +++++++++++++++++++++++++++++++++++++++
postgis/postgis.sql.in | 4 +-
raster/rt_core/rt_wkb.c | 2 +-
regress/core/relate.sql | 8 +-
regress/core/tests.mk.in | 6 +-
11 files changed, 1042 insertions(+), 861 deletions(-)
create mode 100644 postgis/lwgeom_geos_predicates.c
hooks/post-receive
