[SCM] PostGIS branch master updated. 3.5.0alpha2-39-g17e8bf342
Mon Aug 26 19:45:37 PDT 2024
the project "PostGIS".
       via  17e8bf342362fc9b4ecf6d05ce4fde2837af6194 (commit)
      from  907df5ff97242a1e16e0d9ef08929531301dadf1 (commit)
revisions in full, below.
commit 17e8bf342362fc9b4ecf6d05ce4fde2837af6194
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Tue Aug 27 01:32:22 2024 +0000
    Translated PostGIS Manual using Weblate (Japanese)
    Currently translated at 100.0% (5749 of 5749 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 5e39c807b..5ede8ba4a 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -8,10 +8,10 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-07-05 06:17+0000\n"
-"PO-Revision-Date: 2024-08-03 09:45+0000\n"
-"Last-Translator: Yoichi Kayama <yoichi.kayama at gmail.com>\n"
-"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
-"manual/ja/>\n"
+"PO-Revision-Date: 2024-08-27 02:45+0000\n"
+"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
+"postgis-manual/ja/>\n"
 "Language: ja\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
@@ -28105,6 +28105,11 @@ msgid ""
 "geometry. For outer hulls a value of 0.0 produces the convex hull (for a "
 "single polygon); for inner hulls it produces a triangle."
 msgstr ""
+"頂点数の減少は<varname>vertex_fraction</varname>パラメータで制御できます。0か"
+"ら1の範囲を取ります。小さい値では簡略化が進み、頂点数が減り、凹性が下がります"
+"。外側の凹包も内側の凹包も、vertex_fraction値が1."
+"0では、元のジオメトリが生成されます。0.0では、外側の凹包については凸包 "
+"(単一ポリゴンの場合)が生成され、内側の凹包については三角形が生成されます。"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/ja/postgis-manual.po | 13 +++++++++----
 1 file changed, 9 insertions(+), 4 deletions(-)
hooks/post-receive
