[SCM] PostGIS branch master updated. 3.5.0alpha2-40-g2260a5043
Wed Aug 28 03:43:34 PDT 2024
the project "PostGIS".
       via  2260a504389889bbc91cb1293bfc7aae861719fd (commit)
      from  17e8bf342362fc9b4ecf6d05ce4fde2837af6194 (commit)
revisions in full, below.
commit 2260a504389889bbc91cb1293bfc7aae861719fd
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Aug 28 12:43:12 2024 +0200
    Add more printf attribute specifications and fix related warnings
diff --git a/libpgcommon/lwgeom_pg.c b/libpgcommon/lwgeom_pg.c
index ba4d80e11..eb7dea249 100644
--- a/libpgcommon/lwgeom_pg.c
+++ b/libpgcommon/lwgeom_pg.c
@@ -350,6 +350,8 @@ pg_free(void *ptr)
 	pfree(ptr);
+static void pg_error(const char *fmt, va_list ap) __attribute__ (( format(printf, 1, 0) ));
 static void
@@ -361,6 +363,8 @@ pg_error(const char *fmt, va_list ap)
 	ereport(ERROR, (errmsg_internal("%s", errmsg)));
+static void pg_warning(const char *fmt, va_list ap) __attribute__ (( format(printf, 1, 0) ));
 static void
@@ -372,6 +376,8 @@ pg_warning(const char *fmt, va_list ap)
 	ereport(WARNING, (errmsg_internal("%s", errmsg)));
+static void pg_notice(const char *fmt, va_list ap) __attribute__ (( format(printf, 1, 0) ));
 static void
@@ -383,6 +389,8 @@ pg_notice(const char *fmt, va_list ap)
 	ereport(NOTICE, (errmsg_internal("%s", errmsg)));
+static void pg_debug(int level, const char *fmt, va_list ap) __attribute__ (( format(printf, 2, 0) ));
 static void
diff --git a/libpgcommon/lwgeom_pg.h b/libpgcommon/lwgeom_pg.h
index b6f6973c2..37875599f 100644
--- a/libpgcommon/lwgeom_pg.h
+++ b/libpgcommon/lwgeom_pg.h
@@ -252,9 +252,9 @@ Datum LWGEOM_getBBOX(PG_FUNCTION_ARGS);
 Datum LWGEOM_addBBOX(PG_FUNCTION_ARGS);
 Datum LWGEOM_dropBBOX(PG_FUNCTION_ARGS);
-void lwpgerror(const char *fmt, ...);
-void lwpgnotice(const char *fmt, ...);
-void lwpgwarning(const char *fmt, ...);
+void lwpgerror(const char *fmt, ...) __attribute (( format(printf, 1, 2) ));
+void lwpgnotice(const char *fmt, ...) __attribute (( format(printf, 1, 2) ));
+void lwpgwarning(const char *fmt, ...) __attribute (( format(printf, 1, 2) ));
 Datum CallerFInfoFunctionCall3(PGFunction func, FmgrInfo *flinfo, Oid collation, Datum arg1, Datum arg2, Datum arg3);
diff --git a/postgis/lwgeom_window.c b/postgis/lwgeom_window.c
index ddff4685c..eebd6ec57 100644
--- a/postgis/lwgeom_window.c
+++ b/postgis/lwgeom_window.c
@@ -142,12 +142,12 @@ Datum ST_ClusterDBSCAN(PG_FUNCTION_ARGS)
 		/* Validate input parameters */
 		if (tolerance_is_null || tolerance < 0)
-			lwpgerror("Tolerance must be a positive number", tolerance);
+			lwpgerror("Tolerance must be a positive number, got %g", tolerance);
 			PG_RETURN_NULL();
 		if (minpoints_is_null || minpoints < 0)
-			lwpgerror("Minpoints must be a positive number", minpoints);
+			lwpgerror("Minpoints must be a positive number, got %d", minpoints);
 		initGEOS(lwpgnotice, lwgeom_geos_error);
@@ -228,7 +228,7 @@ Datum ST_ClusterWithinWin(PG_FUNCTION_ARGS)
 			PG_RETURN_NULL();
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 3a3441480..d8b4782a8 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -1525,7 +1525,7 @@ cb_getNodeWithinDistance2D(const LWT_BE_TOPOLOGY *topo,
     else
       lwpgwarning("liblwgeom-topo invoked 'getNodeWithinDistance2D' "
-                  "backend callback with limit=%d and no fields",
+                  "backend callback with limit=%ld and no fields",
                   elems_requested);
       appendStringInfo(sql, "*");
Summary of changes:
 libpgcommon/lwgeom_pg.c     | 8 ++++++++
 libpgcommon/lwgeom_pg.h     | 6 +++---
 postgis/lwgeom_window.c     | 6 +++---
 topology/postgis_topology.c | 2 +-
 4 files changed, 15 insertions(+), 7 deletions(-)
hooks/post-receive
