[SCM] PostGIS branch master updated. 3.5.0alpha2-48-gc99603a93
Fri Aug 30 02:23:20 PDT 2024
the project "PostGIS".
       via  c99603a93c6d023da50a6366d267bd6288c756c3 (commit)
       via  cfba2e2f84b323cc9bbdedbb5cc64a4f8260c726 (commit)
      from  49883c5c83de221354e0bf6327b606288048ee8f (commit)
revisions in full, below.
commit c99603a93c6d023da50a6366d267bd6288c756c3
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Aug 30 11:23:07 2024 +0200
    Remove trailing blanks from file
diff --git a/liblwgeom/cunit/cu_remove_irrelevant_points_for_view.c b/liblwgeom/cunit/cu_remove_irrelevant_points_for_view.c
index 4d25f540f..b3bbcbcd0 100644
--- a/liblwgeom/cunit/cu_remove_irrelevant_points_for_view.c
+++ b/liblwgeom/cunit/cu_remove_irrelevant_points_for_view.c
@@ -35,7 +35,7 @@ static void test_lwgeom_remove_irrelevant_points_for_view(void)
 	wkt = lwgeom_to_ewkt(geom);
 	in_wkt = "POLYGON((15 30,30 0,0 0,15 30))";
 	ASSERT_STRING_EQUAL(wkt, in_wkt);
 	lwfree(wkt);
 	lwgeom_free(geom);
 	lwfree(bbox);
commit cfba2e2f84b323cc9bbdedbb5cc64a4f8260c726
Date:   Fri Aug 30 11:22:43 2024 +0200
    Fix 'check-no-trailing-blanks' target for out-of-tree builds
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 9964d099e..cd8db87a5 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -90,7 +90,7 @@ check-unit check-regress: all
 check-regress: export POSTGIS_REGRESS_DB ?= postgis_reg-$(POSTGIS_MAJOR_VERSION).$(POSTGIS_MINOR_VERSION)
 check-no-trailing-blanks:
-	! find . -name '*.c' -o -name '*.h' -o -name '*.proto' | \
+	! find $(top_srcdir) -name '*.c' -o -name '*.h' -o -name '*.proto' | \
 		grep -v lwin_wkt_lex.c | \
 		grep -v lwin_wkt_parse | \
 		grep -v lookup3 | \
Summary of changes:
 GNUmakefile.in                                         | 2 +-
 liblwgeom/cunit/cu_remove_irrelevant_points_for_view.c | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
