[PostGIS] #5775: ST_AsGeoJSONAgg which is aggregate version of ST_AsGeoJSON
trac at osgeo.org
Sat Aug 31 06:10:25 PDT 2024
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.0
Component: postgis | Version: master
Keywords: |
I was thinking about this some, and realized when I want to use
ST_AsGeoJSON, I usually combine it with something like jsonb_buildobject
or json_buildobject, cause ST_AsGeoJSON has no version that supports
aggregates like ST_AsMVT has.
Wouldn't it be nice if one could do this:
SELECT ST_AsGeoJSONAgg(t.*, id_column => 'id')::json
FROM ( VALUES (1, 'one', 'POINT(1 1)'::geometry),
(2, 'two', 'POINT(2 2)'),
(3, 'three', 'POINT(3 3)')
) as t(id, name, geom);
and it would output the same result as what this does
SELECT json_build_object(
'type', 'FeatureCollection',
'features', json_agg(ST_AsGeoJSON(t.*, id_column => 'id')::json)
Now sadly we can't overload ST_AsGeoJSON here, for the same reason
we couldn't overload ST_Union,
cause the above would be ambiguous as to if you want to aggregate or do
row by row.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5775>
