[PostGIS] #5815: hash operator error
trac at osgeo.org
Wed Dec 11 12:58:28 PST 2024
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.5.1
Component: postgis | Version: 3.4.x
Resolution: | Keywords:
Comment (by pramsey):
New and exciting error. On 3.4 it's a different error. So this may have
never worked, and is now just failing in a different way.
postgis34=# WITH lines AS (SELECT ST_GeomFromText('LINESTRING(1 2, 3 4)')
AS geom
UNION ALL
SELECT ST_GeomFromText('LINESTRING(6 5, 7 8)') AS geom
SELECT t1.geom, t2.geom
FROM lines AS t1, lines AS t2
WHERE t1.geom <> t2.geom;
ERROR: operator is not unique: geometry <> geometry
LINE 7: WHERE t1.geom <> t2.geom; ^
HINT: Could not choose a best candidate operator. You might need to add
explicit type casts.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5815#comment:4>
