[PostGIS] #5815: hash operator error
trac at osgeo.org
Thu Dec 12 08:10:15 PST 2024
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.5.1
Component: postgis | Version: 3.4.x
Resolution: | Keywords:
Comment (by robe):
Replying to [comment:4 pramsey]:
> New and exciting error. On 3.4 it's a different error. So this may have
never worked, and is now just failing in a different way.
> postgis34=# WITH lines AS (SELECT ST_GeomFromText('LINESTRING(1 2, 3
4)') AS geom
> UNION ALL
> SELECT ST_GeomFromText('LINESTRING(6 5, 7 8)') AS geom
> SELECT t1.geom, t2.geom
> FROM lines AS t1, lines AS t2
> WHERE t1.geom <> t2.geom;
> ERROR: operator is not unique: geometry <> geometry
> LINE 7: WHERE t1.geom <> t2.geom; ^
> HINT: Could not choose a best candidate operator. You might need to add
explicit type casts.
I think the addition of the operator you added in 3.5, that was the error
we used to get
see
https://git.osgeo.org/gitea/postgis/postgis/src/branch/stable-3.5/NEWS#L111
So I think the fix for #5175 is what is causing this error
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5815#comment:5>
