[SCM] PostGIS branch master updated. 3.5.0-123-g74ce199ea
git at osgeo.org
git at osgeo.org
Mon Dec 16 06:08:40 PST 2024
the project "PostGIS".
via 74ce199eaf43e6873bd46a4333485f3564181b83 (commit)
via 31b74105d9987fe61125f25c758b7b4f586396f8 (commit)
from 275a3d687a48cc7b965f505d9ad4769425c57aa6 (commit)
revisions in full, below.
commit 74ce199eaf43e6873bd46a4333485f3564181b83
Author: DeepL <noreply-mt-deepl at weblate.org>
Date: Mon Dec 16 14:08:17 2024 +0000
Translated PostGIS Manual using Weblate (German)
Currently translated at 50.2% (2892 of 5756 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/de/
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index ec98c7328..9efbb958e 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2024-11-19 11:58+0000\n"
"PO-Revision-Date: 2024-12-16 14:08+0000\n"
-"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
"Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/de/>\n"
"Language: de\n"
@@ -18260,7 +18260,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "a POLYGON EMPTY, or"
-msgstr ""
+msgstr "a POLYGON EMPTY, oder"
#. Tag: para
#, no-c-format
commit 31b74105d9987fe61125f25c758b7b4f586396f8
Author: Andreas Schild <andreas.schild at bfw.gv.at>
Date: Mon Dec 16 13:53:03 2024 +0000
index 919268030..ec98c7328 100644
@@ -9,8 +9,8 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-12-16 13:51+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2024-12-16 14:08+0000\n"
+"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
"Language: de\n"
@@ -18207,8 +18207,8 @@ msgid ""
"if their width is smaller than <parameter>minSizeX</parameter>."
msgstr ""
"Wenn <parameter>minSizeX</parameter> größer als 0 ist, werden Teile "
-"aussortiert, wenn ihre Breite kleiner ist als "
-"<parameter>minSizeX</parameter>."
+"ausgeschlossen, wenn ihre Breite kleiner als <parameter>minSizeX</parameter> "
+"ist."
#. Tag: para
#, no-c-format
@@ -18226,6 +18226,8 @@ msgid ""
"Both <parameter>minSizeX</parameter> and <parameter>minSizeY</parameter> are "
"measured in coordinate system units of the geometry."
msgstr ""
+"Sowohl <parameter>minSizeX</parameter> als auch <parameter>minSizeY</"
+"parameter> werden in den Koordinatensystemeinheiten der Geometrie gemessen."
#. Tag: para
#, no-c-format
@@ -18233,16 +18235,18 @@ msgid ""
"For polygon types, evaluation is done separately for each ring which can "
"lead to one of the following results:"
msgstr ""
+"Bei Polygonen wird die Auswertung für jeden Ring getrennt vorgenommen, was "
+"zu einem der folgenden Ergebnisse führen kann:"
#. Tag: para
#, no-c-format
msgid "the original geometry,"
-msgstr ""
+msgstr "die ursprüngliche Geometrie,"
#. Tag: para
#, no-c-format
msgid "a POLYGON with all rings with less vertices,"
-msgstr ""
+msgstr "ein POLYGON mit allen Ringen, die weniger Scheitelpunkte haben"
#. Tag: para
#, no-c-format
@@ -18250,6 +18254,8 @@ msgid ""
"a POLYGON with a reduced number of interior rings (having possibly less "
"vertices),"
msgstr ""
+"ein POLYGON mit einer reduzierten Anzahl an inneren Ringen (möglicherweise "
+"mit weniger Scheitelpunkten),"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/de/postgis-manual.po | 18 ++++++++++++------
1 file changed, 12 insertions(+), 6 deletions(-)
hooks/post-receive
