[SCM] PostGIS branch master updated. 3.5.0-121-g275a3d687
Mon Dec 16 05:51:28 PST 2024
the project "PostGIS".
       via  275a3d687a48cc7b965f505d9ad4769425c57aa6 (commit)
       via  9bf12ee0df8407355d49a89564de0fbf89d21ab3 (commit)
      from  cff7ee1ece464f4a3a1644f3b1a06c4fdfbdb1d8 (commit)
revisions in full, below.
commit 275a3d687a48cc7b965f505d9ad4769425c57aa6
Author: DeepL <noreply-mt-deepl at weblate.org>
Date:   Mon Dec 16 13:49:20 2024 +0000
    Translated PostGIS Manual using Weblate (German)
    Currently translated at 50.1% (2886 of 5756 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/de/
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index e3343982a..919268030 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-11-19 11:58+0000\n"
 "PO-Revision-Date: 2024-12-16 13:51+0000\n"
-"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
 "Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/de/>\n"
 "Language: de\n"
@@ -18206,6 +18206,9 @@ msgid ""
 "If <parameter>minSizeX</parameter> is greater than 0, parts are sorted out "
 "if their width is smaller than <parameter>minSizeX</parameter>."
 msgstr ""
+"Wenn <parameter>minSizeX</parameter> größer als 0 ist, werden Teile "
+"aussortiert, wenn ihre Breite kleiner ist als "
+"<parameter>minSizeX</parameter>."
 #. Tag: para
 #, no-c-format
commit 9bf12ee0df8407355d49a89564de0fbf89d21ab3
Author: Andreas Schild <andreas.schild at bfw.gv.at>
Date:   Mon Dec 16 13:48:54 2024 +0000
index 023dd8f73..e3343982a 100644
@@ -9,7 +9,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-12-16 13:43+0000\n"
+"PO-Revision-Date: 2024-12-16 13:51+0000\n"
@@ -18197,6 +18197,8 @@ msgid ""
 "It evaluates only geometries of type (MULTI)POLYGON and (MULTI)LINESTRING. "
 "Other geometries remain unchanged."
 msgstr ""
+"Es wertet nur Geometrien vom Typ (MULTI)POLYGON und (MULTI)LINESTRING aus. "
+"Andere Geometrien bleiben unverändert."
 #. Tag: para
 #, no-c-format
@@ -18211,6 +18213,9 @@ msgid ""
 "If <parameter>minSizeY</parameter> is greater than 0, parts are sorted out "
 "if their height is smaller than <parameter>minSizeY</parameter>."
 msgstr ""
+"Wenn <parameter>minSizeY</parameter> größer als 0 ist, werden Teile "
+"ausgeschlossen, wenn ihre Höhe kleiner als <parameter>minSizeY</parameter> "
+"ist."
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/de/postgis-manual.po | 12 ++++++++++--
 1 file changed, 10 insertions(+), 2 deletions(-)
hooks/post-receive
