[SCM] PostGIS branch master updated. 3.5.0-141-g57c599f8c
git at osgeo.org
git at osgeo.org
Mon Dec 16 07:15:04 PST 2024
the project "PostGIS".
via 57c599f8c477f7a392b05b8f1e8ce101b3133069 (commit)
via b532e740a99954b541273bb293e62cba534c1d71 (commit)
from 78b97de3ad7ede0a95eab991ce5984dacbb5bfb6 (commit)
revisions in full, below.
commit 57c599f8c477f7a392b05b8f1e8ce101b3133069
Author: DeepL <noreply-mt-deepl at weblate.org>
Date: Mon Dec 16 15:08:40 2024 +0000
Translated PostGIS Manual using Weblate (German)
Currently translated at 50.5% (2909 of 5756 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/de/
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index 4dc554639..8026772d6 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2024-11-19 11:58+0000\n"
"PO-Revision-Date: 2024-12-16 15:15+0000\n"
-"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
"Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/de/>\n"
"Language: de\n"
@@ -29208,6 +29208,9 @@ msgid ""
"Behavior changed in GEOS 3.11 so offset curves now have the same direction "
"as the input line, for both positive and negative offsets."
msgstr ""
+"Das Verhalten wurde in GEOS 3.11 geändert, so dass die Offset-Kurven nun die "
+"gleiche Richtung wie die Eingabelinie haben, sowohl für positive als auch "
+"für negative Offsets."
#. Tag: para
#, no-c-format
commit b532e740a99954b541273bb293e62cba534c1d71
Author: Andreas Schild <andreas.schild at bfw.gv.at>
Date: Mon Dec 16 15:08:30 2024 +0000
index d75b23b74..4dc554639 100644
@@ -9,8 +9,8 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-12-16 14:49+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2024-12-16 15:15+0000\n"
+"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
"Language: de\n"
@@ -19275,9 +19275,9 @@ msgid ""
"Setting for whole database cluster. Requires super user access. Also note "
"that database, session, and user settings override this."
msgstr ""
-"Einstellung für den gesamten Datenbank-Cluster. Erfordert Superuser-Zugriff. "
-"Beachten Sie auch, dass Datenbank-, Sitzungs- und Benutzereinstellungen "
-"Vorrang vor dieser Einstellung haben."
+"Für den gesamten Datenbank-Cluster aktivieren. Erfordert Superuser-Zugriff. "
+"Beachten Sie auch, dass Datenbank-, Sitzungs- und Benutzereinstellungen dies "
+"überschreiben."
#. Tag: refpurpose
#, fuzzy, no-c-format
@@ -22268,6 +22268,10 @@ msgid ""
"web.archive.org/web/20160827203903/http://boundlessgeo.com/2012/07/making-"
"geography-faster/\">Making Geography faster</link> for details."
msgstr ""
+"Erweitert: 2.1.0 verbesserte die Geschwindigkeit für Geographie. Weitere "
+"Details finden Sie unter <link xlink:href=\"https://web.archive.org/web/"
+"20160827203903/http://boundlessgeo.com/2012/07/making-geography-faster/\""
+">Making Geography faster</link>."
#. Tag: para
#, no-c-format
@@ -25403,6 +25407,8 @@ msgstr "3D-Geometrien werden unterstützt:"
#, no-c-format
msgid "Options argument can be used to add BBOX and CRS in GeoJSON output:"
msgstr ""
+"Das Argument options kann verwendet werden, um BBOX oder CRS in der GeoJSON-"
+"Ausgabe hinzuzufügen:"
#. Tag: para
Summary of changes:
doc/po/de/postgis-manual.po | 17 +++++++++++++----
1 file changed, 13 insertions(+), 4 deletions(-)
hooks/post-receive
