[SCM] PostGIS branch master updated. 3.5.0-143-ge377830c8
git at osgeo.org
git at osgeo.org
Mon Dec 16 07:27:39 PST 2024
the project "PostGIS".
via e377830c8c13e5bfecb7e40e8fc5c9d8a7a6cee4 (commit)
via f013e36bfc1bf87a0e6918842e6c3c0899e728f1 (commit)
from 57c599f8c477f7a392b05b8f1e8ce101b3133069 (commit)
revisions in full, below.
commit e377830c8c13e5bfecb7e40e8fc5c9d8a7a6cee4
Author: DeepL <noreply-mt-deepl at weblate.org>
Date: Mon Dec 16 15:21:20 2024 +0000
Translated PostGIS Manual using Weblate (German)
Currently translated at 50.5% (2911 of 5756 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/de/
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index af5eb5222..b307992a0 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2024-11-19 11:58+0000\n"
"PO-Revision-Date: 2024-12-16 15:27+0000\n"
-"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
"Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/de/>\n"
"Language: de\n"
@@ -31630,6 +31630,8 @@ msgid ""
"Returns a single-band raster containing the rendered version of all incoming "
"geometries, each with its associated value."
msgstr ""
+"Gibt ein einbandiges Raster zurück, das die gerenderte Version aller "
+"eingehenden Geometrien enthält, jede mit ihrem zugehörigen Wert."
#. Tag: para
#, no-c-format
commit f013e36bfc1bf87a0e6918842e6c3c0899e728f1
Author: Andreas Schild <andreas.schild at bfw.gv.at>
Date: Mon Dec 16 15:15:29 2024 +0000
index 8026772d6..af5eb5222 100644
@@ -9,8 +9,8 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-12-16 15:15+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2024-12-16 15:27+0000\n"
+"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
"Language: de\n"
@@ -29208,9 +29208,9 @@ msgid ""
"Behavior changed in GEOS 3.11 so offset curves now have the same direction "
"as the input line, for both positive and negative offsets."
msgstr ""
-"Das Verhalten wurde in GEOS 3.11 geändert, so dass die Offset-Kurven nun die "
-"gleiche Richtung wie die Eingabelinie haben, sowohl für positive als auch "
-"für negative Offsets."
+"Durch die Änderung des Verhaltens in GEOS 3.11 haben versetzte Kurven nun "
+"die gleiche Richtung wie die Eingabelinie, sowohl bei positiven als auch bei "
+"negativen Versetzungen."
#. Tag: para
#, no-c-format
@@ -31622,7 +31622,7 @@ msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid "Aggregate. Renders PostGIS geometries into a new raster."
-msgstr ""
+msgstr "Aggregiert. Wandelt PostGIS-Geometrien in einen neuen Raster um."
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/de/postgis-manual.po | 12 +++++++-----
1 file changed, 7 insertions(+), 5 deletions(-)
hooks/post-receive
