[SCM] PostGIS branch master updated. 3.5.0-146-gd8adefa91
git at osgeo.org
git at osgeo.org
Mon Dec 16 07:45:55 PST 2024
the project "PostGIS".
via d8adefa9122cb491ad22e89dc03533fbcc657b77 (commit)
from 133f4a1fb4af57deabcde712e95e67ead844a59b (commit)
revisions in full, below.
commit d8adefa9122cb491ad22e89dc03533fbcc657b77
Author: DeepL <noreply-mt-deepl at weblate.org>
Date: Mon Dec 16 15:30:30 2024 +0000
Translated PostGIS Manual using Weblate (German)
Currently translated at 50.6% (2914 of 5756 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/de/
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index d7e98f3f4..3c87088a2 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -9,7 +9,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2024-11-19 11:58+0000\n"
-"PO-Revision-Date: 2024-12-16 15:30+0000\n"
+"PO-Revision-Date: 2024-12-16 15:45+0000\n"
"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
"Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/de/>\n"
@@ -35654,6 +35654,12 @@ msgid ""
"varname> is set to TRUE, then touched pixels are included, otherwise only if "
"the center of the pixel is in the geometry it is included."
msgstr ""
+"Gibt das von der Eingabegeometrie abgeschnittene Raster zurück. Wenn die "
+"Bandnummer nicht angegeben ist, werden alle Bänder verarbeitet. Wenn "
+"<varname>crop</varname> nicht angegeben oder TRUE ist, wird das "
+"Ausgaberaster beschnitten. Wenn <varname>touched</varname> auf TRUE gesetzt "
+"ist, werden berührte Pixel einbezogen, andernfalls nur, wenn der Mittelpunkt "
+"des Pixels in der Geometrie liegt."
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/de/postgis-manual.po | 8 +++++++-
1 file changed, 7 insertions(+), 1 deletion(-)
hooks/post-receive
