[SCM] PostGIS branch master updated. 3.5.0-150-g9c155bcd4
Mon Dec 16 08:02:46 PST 2024
the project "PostGIS".
       via  9c155bcd4695f1481f54f2076f91708c640a17f0 (commit)
       via  a45f2ea3d2c608b903193c268d188b732d6f6194 (commit)
      from  85d7a7eff13ccffecbb8d21e704b65af59bbaec4 (commit)
revisions in full, below.
commit 9c155bcd4695f1481f54f2076f91708c640a17f0
Author: DeepL <noreply-mt-deepl at weblate.org>
Date:   Mon Dec 16 16:01:26 2024 +0000
    Translated PostGIS Manual using Weblate (German)
    Currently translated at 50.6% (2916 of 5756 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/de/
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index 65b1d3de8..3b731682c 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-11-19 11:58+0000\n"
 "PO-Revision-Date: 2024-12-16 16:02+0000\n"
-"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
 "Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/de/>\n"
 "Language: de\n"
@@ -13306,6 +13306,9 @@ msgid ""
 "starts at 1. Returns NULL if the geometry is not a CompoundCurve or the "
 "index is out of range."
 msgstr ""
+"Gibt die N-te Komponentengeometrie einer CompoundCurve zurück. Der Index "
+"beginnt bei 1. Gibt NULL zurück, wenn die Geometrie keine CompoundCurve ist "
+"oder der Index außerhalb des Bereichs liegt."
 #. Tag: refpurpose
 #, fuzzy, no-c-format
commit a45f2ea3d2c608b903193c268d188b732d6f6194
Author: Andreas Schild <andreas.schild at bfw.gv.at>
Date:   Mon Dec 16 16:00:41 2024 +0000
index e64e6ef9d..65b1d3de8 100644
@@ -9,8 +9,8 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-12-16 16:00+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2024-12-16 16:02+0000\n"
+"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
 "Language: de\n"
@@ -8576,18 +8576,17 @@ msgid ""
 "xlink:href=\"https://gitlab.com/sfcgal/SFCGAL/\">https://gitlab.com/sfcgal/"
 "SFCGAL/</link>."
 msgstr ""
-"SFCGAL, 1.4.1 oder höher ist erforderlich und 1.5.0+ ist erforderlich, um "
-"alle Funktionen nutzen zu können. SFCGAL kann verwendet werden, um "
-"zusätzliche 2D- und 3D-Analysefunktionen für PostGIS cf <xref linkend="
-"\"reference_sfcgal\"/> bereitzustellen. Außerdem kann SFCGAL anstelle von "
-"GEOS für einige 2D-Funktionen verwendet werden, die von beiden Backends "
-"bereitgestellt werden (z. B. ST_Intersection oder ST_Area). Eine PostgreSQL-"
-"Konfigurationsvariable <code>postgis.backend</code> erlaubt es dem "
-"Endbenutzer zu kontrollieren, welches Backend er verwenden möchte, wenn "
-"SFCGAL installiert ist (GEOS als Standard). Hinweis: SFCGAL 1.2 benötigt "
-"mindestens CGAL 4.3 und Boost 1.54 (vgl. <link xlink:href=\"https://sfcgal."
-"org\">https://sfcgal.org</link>) <link xlink:href=\"https://gitlab.com/"
-"sfcgal/SFCGAL/\">https://gitlab.com/sfcgal/SFCGAL/</link>."
+"SFCGAL, 1.4.1 oder höher ist nötig, und 1.5.0+ erforderlich um alle "
+"Funktionen nutzen zu können. SFCGAL kann verwendet werden, um zusätzliche 2D-"
+" und 3D-Analysefunktionen für PostGIS cf <xref linkend=\"reference_sfcgal\"/"
+"> bereitzustellen. Außerdem kann SFCGAL anstelle von GEOS für einige 2D-"
+"Funktionen verwendet werden, die von beiden Backends bereitgestellt werden ("
+"z. B. ST_Intersection oder ST_Area). Die PostgreSQL-Konfigurationsvariable "
+"<code>postgis.backend</code> erlaubt es dem Endbenutzer das Backend "
+"auszuwählen, falls SFCGAL installiert ist (GEOS ist Standard). Hinweis: "
+"SFCGAL 1.2 benötigt mindestens CGAL 4.3 und Boost 1.54 (cf <link xlink:href="
+"\"https://sfcgal.org\">https://sfcgal.org</link>) <link xlink:href=\"https"
+"://gitlab.com/sfcgal/SFCGAL/\">https://gitlab.com/sfcgal/SFCGAL/</link>."
 #. Tag: para
Summary of changes:
 doc/po/de/postgis-manual.po | 28 +++++++++++++++-------------
 1 file changed, 15 insertions(+), 13 deletions(-)
hooks/post-receive
