[SCM] PostGIS branch master updated. 3.5.0-177-g65ed8aa88
Thu Dec 19 17:13:00 PST 2024
the project "PostGIS".
       via  65ed8aa8895046fb933ecb46076e013471896756 (commit)
      from  1f45896bf73896b472730bfd7c4eb50c18d4a2b4 (commit)
revisions in full, below.
commit 65ed8aa8895046fb933ecb46076e013471896756
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Dec 19 17:12:56 2024 -0800
    Improve doc to state ST_RemoveRepeatedPoints distance is 2D
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index 83d7e94d5..da11f0e24 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -1681,7 +1681,7 @@ UPDATE sometable
           <funcprototype>
             <funcdef>geometry <function>ST_RemoveRepeatedPoints</function></funcdef>
             <paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
-            <paramdef choice="opt"><type>float8</type> <parameter>tolerance</parameter></paramdef>
+            <paramdef choice="opt"><type>float8</type> <parameter>tolerance = 0.0</parameter></paramdef>
           </funcprototype>
         </funcsynopsis>
       </refsynopsisdiv>
@@ -1695,8 +1695,10 @@ UPDATE sometable
                 The endpoints of LineStrings are preserved.
         </para>
-        <para>If the <parameter>tolerance</parameter> parameter is provided, vertices within the tolerance distance
-        of one another are considered to be duplicates.</para>
+        <para>If a non-zero <parameter>tolerance</parameter> parameter is provided, vertices within the tolerance distance
+        of one another are considered to be duplicates.
+		The distance is computed in 2D (XY plane).
+		</para>
         <para role="enhanced" conformance="3.2.0">Enhanced: 3.2.0</para>
         <para role="availability" conformance="2.2.0">Availability: 2.2.0</para>
Summary of changes:
 doc/reference_editor.xml | 8 +++++---
 1 file changed, 5 insertions(+), 3 deletions(-)
hooks/post-receive
