[PostGIS] #5823: PostgreSQL 18 no longer compiles against postgis
trac at osgeo.org
Fri Dec 20 12:09:23 PST 2024
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.0
Component: postgis | Version: master
Keywords: |
Debbies compile of postgis started failing on
https://debbie.postgis.net/view/PostGIS/job/PostGIS_Regress_PGDEV_Weekly/23896/consoleFull
which happened after change in postgresql
Commit 5983a4cffc31640fda6643f10146a5b72b203eaa by drowley
Introduce CompactAttribute array in TupleDesc, take 2
The new compact_attrs array stores a few select fields from
FormData_pg_attribute in a more compact way, using only 16 bytes per
column instead of the 104 bytes that FormData_pg_attribute uses. Using
CompactAttribute allows performance-critical operations such as tuple
deformation to be performed without looking at the FormData_pg_attribute
element in TupleDesc which means fewer cacheline accesses.
For some workloads, tuple deformation can be the most CPU intensive part
of processing the query. Some testing with 16 columns on a table
where the first column is variable length showed around a 10% increase in
transactions per second for an OLAP type query performing aggregation on
the 16th column. However, in certain cases, the increases were much
higher, up to ~25% on one AMD Zen4 machine.
This also makes pg_attribute.attcacheoff redundant. A follow-on commit
will remove it, thus shrinking the FormData_pg_attribute struct by 4
bytes.
Author: David Rowley
Reviewed-by: Andres Freund, Victor Yegorov
Discussion:
https://postgr.es/m/CAApHDvrBztXP3yx=NKNmo3xwFAFhEdyPnvrDg3=M0RhDs+4vYw@mail.gmail.com
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5823>
