[PostGIS] #5802: CREATE OPERATOR = not marked as changed
PostGIS trac at osgeo.org
Sun Dec 22 00:13:47 PST 2024
  Reporter:  robe        |      Owner:  robe
      Type:  defect      |     Status:  closed
  Priority:  medium      |  Milestone:  PostGIS 3.5.1
 Component:  postgis     |    Version:  3.5.x
Resolution:  worksforme  |   Keywords:
Changes (by robe):
 * resolution:   => worksforme
 * status:  assigned => closed
Comment:
 Okay it appears our update logic is smart enough to do the right thing,
 not sure how though.
 But I checked:
 CREATE EXTENSION postgis VERSION "3.4.4dev";
 And confirmed the negator operator for = does not exist.
 I checked after:
 ALTER EXTENSION postgis UPDATE VERSION "3.5.1dev";
 and the negator showed, even though we didn't update the message still
 says 0.9.0
 -- Availability: 0.9.0
 CREATE OPERATOR = (
         LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_eq,
         COMMUTATOR = '=', NEGATOR = '<>',
         RESTRICT = contsel, JOIN = contjoinsel, HASHES, MERGES
 I'm not going to bother messing with this.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5802#comment:1>
