[SCM] PostGIS branch stable-3.5 updated. 3.5.0-35-gbae6e7c80
Sun Dec 22 00:28:01 PST 2024
the project "PostGIS".
The branch, stable-3.5 has been updated
       via  bae6e7c80377a289e30c2b9d5ef444fcdef63347 (commit)
       via  460c1e967a8b409ac152fd2c0638cab772e1b7fe (commit)
       via  b787a825782b23ed56ea95398f4d1ad354a910db (commit)
      from  f0cd0e1067a2e682b2377ea0b8e4d5f3e533f93b (commit)
revisions in full, below.
commit bae6e7c80377a289e30c2b9d5ef444fcdef63347
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Dec 22 03:27:53 2024 -0500
    Prepping for PostGIS 3.5.1 release
diff --git a/NEWS b/NEWS
index 207f4f20a..eac1e04d8 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
 PostGIS 3.5.1
-xxxx/xx/xx
+2024/12/22
 To take advantage of all postgis_sfcgal extension features SFCGAL 1.5+ is needed.
 PostgreSQL 12-17 required. GEOS 3.8+ required. Proj 6.1+ required.
@@ -7,14 +7,14 @@ PostgreSQL 12-17 required. GEOS 3.8+ required. Proj 6.1+ required.
 * Bug fixes *
 - #5677, Retain SRID during unary union (Paul Ramsey)
-- #5792, Prevent topology corruption with TopoGeo_addPoint near almost
+- #5792, [topology] Prevent topology corruption with TopoGeo_addPoint near almost
          collinear edges (Sandro Santilli)
-- #5795, Fix ST_NewEdgesSplit can cause invalid topology
+- #5795, [topology] Fix ST_NewEdgesSplit can cause invalid topology
          (Björn Harrtell)
 - #5794, Fix crash in TopoGeo_addPoint (Sandro Santilli)
 - #5785, [raster] ST_MapAlgebra segfaults when expression references
          a supernumerary rast argument (Dian M Fay)
-- #5787, Check that ST_ChangeEdgeGeom doesn't change winding of rings
+- #5787, [topology] Check that ST_ChangeEdgeGeom doesn't change winding of rings
          (Sandro Santilli)
 - #5791, Add legacy stubs for old transaction functions
          to allow pg_upgrade (Regina Obe)
@@ -29,9 +29,9 @@ PostgreSQL 12-17 required. GEOS 3.8+ required. Proj 6.1+ required.
 * Enhancements *
   - #5782, Improve robustness of min distance calculation (Sandro Santilli)
-  - Speedup topology building when closing large rings with many
-    hooles (Björn Harrtell)
-  - #5810, Update tiger geocoder to handle TIGER 2024 data (Regina Obe)
+  - [topology] Speedup topology building when closing large rings with many
+    holes (Björn Harrtell)
+  - #5810, [tiger_geocoder] Update tiger geocoder to handle TIGER 2024 data (Regina Obe)
 * Breaking Changes *
diff --git a/README.postgis b/README.postgis
index 740c19207..25c5220c3 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.5.0
-:Date: 2024-09-25
+:Version: 3.5.1
+:Date: 2024-12-22
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index 11992b780..b010fbb8a 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=5
-POSTGIS_MICRO_VERSION=1dev
+POSTGIS_MICRO_VERSION=1
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 87f924d51..71f01aaf0 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,6 +2,51 @@
 <appendix xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://docbook.org/ns/docbook" version="5.0" xml:id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
+        <section>
+            <title>PostGIS 3.5.1</title>
+            <para>2024/09/25</para>
+            <para>This version requires PostgreSQL 12-17, GEOS 3.8 or higher, and Proj 6.1+.
+            To take advantage of all features, GEOS 3.12+ is needed.
+            To take advantage of all SFCGAL features, SFCGAL 1.5.0+ is needed.</para>
+            <simplesect>
+                <title>Breaking Changes</title>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/#5677">#5677</ulink>, Retain SRID during unary union (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/#5792">#5792</ulink>, [topology] Prevent topology corruption with TopoGeo_addPoint near almost
+                        collinear edges (Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/#5795">#5795</ulink>, [topology] Fix ST_NewEdgesSplit can cause invalid topology
+                        (Björn Harrtell)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/#5794">#5794</ulink>, [topology] Fix crash in TopoGeo_addPoint (Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/#5785">#5785</ulink>, [raster] ST_MapAlgebra segfaults when expression references
+                        a supernumerary rast argument (Dian M Fay)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/#5787">#5787</ulink>, Check that ST_ChangeEdgeGeom doesn't change winding of rings
+                        (Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/#5791">#5791</ulink>, Add legacy stubs for old transaction functions
+                        to allow pg_upgrade (Regina Obe)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/#5800">#5800</ulink>, PROJ compiled version reading the wrong minor and micro
+                        (Regina Obe)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/#5790">#5790</ulink>, Non-schema qualified calls causing issue with
+                        materialized views (Regina Obe)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/#5812">#5812</ulink>, Performance regression in ST_Within (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/#5815">#5815</ulink>, Remove hash/merge promise from <> operator (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/#5823">#5823</ulink>, Build support for Pg18 (Paul Ramsey)</para>
+            </simplesect>
+            <simplesect>
+                <title>Enhancements</title>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/#5782">#5782</ulink>, Improve robustness of min distance calculation (Sandro Santilli)</para>
+                <para>[topology] Speedup topology building when closing large rings with many
+                    holes (Björn Harrtell)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/#5810">#5810</ulink>, Update tiger geocoder to handle TIGER 2024 data (Regina Obe)</para>
+            </simplesect>
+            <simplesect>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/#5799">#5799</ulink>, make ST_TileEnvelope clip envelopes to tile plane
+           extent (Paul Ramsey)</para>
+            </simplesect>
+        </section>
         <section>
             <title>PostGIS 3.5.0</title>
commit 460c1e967a8b409ac152fd2c0638cab772e1b7fe
Date:   Sun Dec 22 00:59:32 2024 -0500
    Fix ST_AsMVTGeom example.  Closes #5758 for PostGIS 3.5.1
diff --git a/doc/reference_output.xml b/doc/reference_output.xml
index 50e7f7370..2e719d0f4 100644
--- a/doc/reference_output.xml
+++ b/doc/reference_output.xml
@@ -1395,7 +1395,7 @@ SELECT ST_AsText(ST_AsMVTGeom(
  MULTIPOLYGON(((5 4096,10 4091,10 4096,5 4096)),((5 4096,0 4101,0 4096,5 4096)))
 		</programlisting>
-    <para>Canonical example for a Web Mercator tile using a computed tile bounds to query and clip geometry.
+    <para>Canonical example for a Web Mercator tile using a computed tile bounds to query and clip geometry. This assumes the data.geom column has srid of 4326.
     </para>
 		<programlisting><![CDATA[
@@ -1403,7 +1403,7 @@ SELECT ST_AsMVTGeom(
             ST_Transform( geom, 3857 ),
             ST_TileEnvelope(12, 513, 412), extent => 4096, buffer => 64) AS geom
   FROM data
-  WHERE geom && ST_TileEnvelope(12, 513, 412, margin => (64.0 / 4096))
+  WHERE geom && ST_Transform(ST_TileEnvelope(12, 513, 412, margin => (64.0 / 4096)),4326)
 ]]></programlisting>
commit b787a825782b23ed56ea95398f4d1ad354a910db
Date:   Sun Dec 22 00:18:17 2024 -0500
    Add micro version upgrades for soon to be released micros
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 8d8d5993d..8764f7e3c 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -71,6 +71,7 @@ UPGRADEABLE_VERSIONS = \
 	3.0.9 \
 	3.0.10 \
 	3.0.11 \
+	3.0.12 \
 	3.1.0 \
 	3.1.1 \
 	3.1.2	\
@@ -84,6 +85,7 @@ UPGRADEABLE_VERSIONS = \
 	3.1.9 \
 	3.1.10 \
 	3.1.11 \
+	3.1.12 \
 	3.2.0 \
 	3.2.1 \
 	3.2.2 \
@@ -92,6 +94,7 @@ UPGRADEABLE_VERSIONS = \
 	3.2.5 \
 	3.2.6 \
 	3.2.7 \
+	3.2.8 \
 	3.3.0 \
 	3.3.1 \
 	3.3.2 \
@@ -100,8 +103,10 @@ UPGRADEABLE_VERSIONS = \
 	3.3.5 \
 	3.3.6 \
 	3.3.7 \
+	3.3.8 \
 	3.4.0 \
 	3.4.1 \
 	3.4.2 \
 	3.4.3 \
+	3.4.4 \
 	3.5.0
Summary of changes:
 NEWS                               | 14 ++++++------
 README.postgis                     |  4 ++--
 Version.config                     |  2 +-
 doc/reference_output.xml           |  4 ++--
 doc/release_notes.xml              | 45 ++++++++++++++++++++++++++++++++++++++
 extensions/upgradeable_versions.mk |  5 +++++
 6 files changed, 62 insertions(+), 12 deletions(-)
hooks/post-receive
