[PostGIS] #5755: pg17 + sid + amd64 + Postgis 3.4.2 = test failed
PostGIS trac at osgeo.org
Mon Jul 1 12:39:39 PDT 2024
 Reporter:  ImreSamu           |      Owner:  pramsey
     Type:  defect             |     Status:  new
 Priority:  high               |  Milestone:  PostGIS 3.4.3
Component:  postgis            |    Version:  3.4.x
 Keywords:  pg17, sid, debian  |
 original problem: Christoph Berg - pgsql-pkg-debian mailing list:
 https://www.postgresql.org/message-
 id/flat/ZoLWQ7txLAyyFKZ_%40msg.df7cb.de#536570f7d70962aaee45c05a8a6109b1
 errors:
 14:08:23 2024-05-23 12:08:15.648 UTC [24862] buildd at postgisreg-3.4
 ERROR: RASTERfromGDALRaster: Could not open bytea with GDAL. Check that
 the bytea is of a GDAL supported format
 14:08:23 2024-05-23 12:08:15.648 UTC [24862] buildd at postgis_reg-3.4
  ERROR: RASTER_fromGDALRaster: Could not open bytea with GDAL. Check that
 https://pgdgbuild.dus.dg-i.net/job/postgis-binaries-
 beta/93/architecture=amd64,distribution=sid/console
 debian - postgis -jenkins matrix:
 - **pg17 + sid + amd64 = Failed**
 - pg17 + sid + arm64 = OK
 - pg17 + bullseye, bookworm, trixie: OK
 https://pgdgbuild.dus.dg-i.net/view/Binaries-Beta/job/postgis-binaries-
 beta/
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5755>
