[SCM] PostGIS branch master updated. 3.4.0rc1-1241-gbc5a580f9
git at osgeo.org
git at osgeo.org
Mon Jul 1 13:41:05 PDT 2024
the project "PostGIS".
via bc5a580f99eb24df5b15833f668c47ddb63c248e (commit)
from c297c559f4fe85639e4eda5b7bb53ff50d188f27 (commit)
revisions in full, below.
commit bc5a580f99eb24df5b15833f668c47ddb63c248e
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Jul 1 22:40:30 2024 +0200
[woodie] Keep an eye on Georgian translation too
diff --git a/.woodpecker/docs-localized.yml.in b/.woodpecker/docs-localized.yml.in
index 8f114be9f..0f4823b56 100644
--- a/.woodpecker/docs-localized.yml.in
+++ b/.woodpecker/docs-localized.yml.in
@@ -9,4 +9,4 @@
path:
include:
- "doc/po/@LANG@/*.po"
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 45e3c229f..31d75a690 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -151,6 +151,18 @@ steps:
include:
- "doc/po/pl/*.po"
+ check-xml-ka:
+ image: *test_image
+ pull: true
+ commands:
+ - make -C build-docs/doc/po/ka local-check-xml
+ depends_on: prepare
+ when:
+ - event: push
+ path:
+ include:
+ - "doc/po/ka/*.po"
check-xml-ko_KR:
image: *test_image
pull: true
@@ -296,6 +308,18 @@ steps:
include:
- "doc/po/pl/*.po"
+ html-ka:
+ pull: true
+ commands:
+ - make -C build-docs/doc/po/ka local-html
+ depends_on: check-xml-ka
+ when:
+ - event: push
+ path:
+ include:
html-ko_KR:
image: *test_image
pull: true
@@ -441,6 +465,18 @@ steps:
include:
- "doc/po/pl/*.po"
+ cheatsheets-ka:
+ pull: true
+ commands:
+ - make -C build-docs/doc/po/ka local-cheatsheets
+ when:
+ - event: push
+ path:
+ include:
cheatsheets-ko_KR:
image: *test_image
pull: true
@@ -586,6 +622,18 @@ steps:
include:
- "doc/po/pl/*.po"
+ check-cheatsheets-ka:
+ pull: true
+ commands:
+ - make -C build-docs/doc/po/ka local-check-cheatsheets
+ depends_on: [ cheatsheets-ka, build-cheatsheets ]
+ when:
+ - event: push
+ path:
+ include:
check-cheatsheets-ko_KR:
image: *test_image
pull: true
@@ -731,6 +779,18 @@ steps:
include:
- "doc/po/pl/*.po"
+ pdf-ka:
+ pull: true
+ commands:
+ - make -C build-docs/doc/po/ka local-pdf
+ depends_on: [ build-images, check-xml-ka ]
+ when:
+ - event: push
+ path:
+ include:
pdf-ko_KR:
image: *test_image
pull: true
Summary of changes:
.woodpecker/docs-localized.yml.in | 2 +-
.woodpecker/docs.yml | 60 +++++++++++++++++++++++++++++++++++++++
2 files changed, 61 insertions(+), 1 deletion(-)
hooks/post-receive
