[PostGIS] #5757: pgSQL 17 json support prevents compile
trac at osgeo.org
Tue Jul 2 21:51:54 PDT 2024
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.4.3
Component: postgis | Version: 3.4.x
Keywords: |
Okay they had put back that SQL JSON support back in PG17. So need to
change that IF DEF, cause now even master doesn't work against released
PG17
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5757>
