[PostGIS] #5758: Documentation bug in SQL query example for ST_AsMVTGeom
trac at osgeo.org
Wed Jul 3 23:36:31 PDT 2024
Reporter: azakh | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.4.3
Component: documentation | Version: 3.4.x
Keywords: MVT, ST_AsMVTGeom |
Currently:
SELECT ST_AsMVTGeom(
ST_Transform( geom, 3857 ),
ST_TileEnvelope(12, 513, 412), extent => 4096, buffer => 64)
AS geom
FROM data
WHERE geom && ST_TileEnvelope(12, 513, 412, margin => (64.0 / 4096))
Should be:
AS geom
FROM data
WHERE ST_Transform(geom, 3857) && ST_TileEnvelope(12, 513, 412, margin
=> (64.0 / 4096))
Namely, the `geom` column should be transformed both in SELECT and WHERE
clauses.
Related issue: https://trac.osgeo.org/postgis/ticket/5198
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5758>
