[PostGIS] #5759: 3.5.0-alpha1 fails to build due to test failures
trac at osgeo.org
Thu Jul 4 22:03:12 PDT 2024
Reporter: Bas Couwenberg | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.4.3
Component: postgis | Version: 3.4.x
Keywords: |
The Debian package build for 3.5.0-alpha1 failed due to test failures:
! find . -name '*.c' -o -name '*.h' -o -name '*.proto' | \
grep -v lwin_wkt_lex.c | \
grep -v lwin_wkt_parse | \
grep -v lookup3 | \
grep -v vector_tile.pb-c | \
grep -v postgis/sqldefines.h | \
grep -v deps/ | \
xargs grep -n '[[:space:]]$'
./utils/check_news.sh .
PASS: NEWS file entries are in good order
./utils/check_tests_enabled.sh .
All tests enabled in topology/test/tests.mk
All tests enabled in regress/loader/tests.mk
All tests enabled in regress/dumper/tests.mk
All tests enabled in sfcgal/regress/tests.mk.in
All tests enabled in regress/core/tests.mk.in
All tests enabled in raster/test/regress/tests.mk
./utils/check_lang_enabled.sh .
grep: ./.woodpecker/docs.yml: No such file or directory
FAIL: de is not enabled in ./.woodpecker/docs.yml
FAIL: es is not enabled in ./.woodpecker/docs.yml
FAIL: fr is not enabled in ./.woodpecker/docs.yml
FAIL: it_IT is not enabled in ./.woodpecker/docs.yml
FAIL: ja is not enabled in ./.woodpecker/docs.yml
FAIL: ka is not enabled in ./.woodpecker/docs.yml
FAIL: ko_KR is not enabled in ./.woodpecker/docs.yml
FAIL: pl is not enabled in ./.woodpecker/docs.yml
FAIL: pt_BR is not enabled in ./.woodpecker/docs.yml
FAIL: ro is not enabled in ./.woodpecker/docs.yml
FAIL: ru is not enabled in ./.woodpecker/docs.yml
FAIL: uk is not enabled in ./.woodpecker/docs.yml
FAIL: zh_Hans is not enabled in ./.woodpecker/docs.yml
make[2]: *** [GNUmakefile:290: check-lang-enabled] Error 13
make[2]: Leaving directory '/build/postgis-3.5.0~alpha1+dfsg'
The .woodpecker directory is no longer present in the release tarball.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5759>
