[PostGIS] #5759: 3.5.0-alpha1 fails to build due to test failures
trac at osgeo.org
Fri Jul 5 03:37:02 PDT 2024
Reporter: Bas Couwenberg | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.5.0
Component: build | Version: master
Resolution: fixed | Keywords:
Changes (by Sandro Santilli <strk@…>):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"8a73af4b367a18db35213f65ded961daddb2c3fa/git"
8a73af4b/git]:
{{{#!CommitTicketReference repository="git"
revision="8a73af4b367a18db35213f65ded961daddb2c3fa"
Do not check woodpecker configuration if not found
It isn't found in distribution tarball.
Closes #5759
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5759#comment:3>
