[SCM] PostGIS branch master updated. 3.5.0alpha2-6-g5d5ed3b14
git at osgeo.org
git at osgeo.org
Wed Jul 10 10:41:36 PDT 2024
the project "PostGIS".
via 5d5ed3b148d8d647eabaea6ea41c377dee674832 (commit)
from 6c135f9ca3a9b60889eae2bc2adc67350e0c0e4a (commit)
revisions in full, below.
commit 5d5ed3b148d8d647eabaea6ea41c377dee674832
Author: Regina Obe <lr at pcorp.us>
Date: Wed Jul 10 13:40:01 2024 -0400
Put back topology tests, CI changes
but disable topology extension regress on winnie
References #5727 for PostGIS 3.5.0
Have tools.yml also use repo.osgeo.org instead of docker.osgeo.org
diff --git a/.woodpecker/tools.yml b/.woodpecker/tools.yml
index df9b86dfd..6a8bd160c 100644
--- a/.woodpecker/tools.yml
+++ b/.woodpecker/tools.yml
@@ -2,7 +2,7 @@ when:
event: [push, pull_request, tag]
steps:
build:
- image: docker.osgeo.org/postgis/build-test:trisquel11
+ image: repo.osgeo.org/postgis/build-test:trisquel11
pull: true
commands:
- sh ci/dronie/postgis_tools.sh
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 4bcf71ba4..6a9b528cd 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -78,7 +78,8 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/lib -L${PROJECTS
--with-libiconv=${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE} \
--with-gui --with-gettext=no \
--with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
- --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE} --with-library-minor-version
+ --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE} --with-library-minor-version \
+ --without-topology
#exit
else
LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/bin -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
@@ -89,7 +90,8 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/bin -L${PROJECTS
+ --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE} \
fi;
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index fa6b9b49a..cbe263369 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -74,6 +74,7 @@ TESTS += \
$(top_srcdir)/topology/test/regress/topoelementarray_agg.sql \
$(top_srcdir)/topology/test/regress/topoelement_cast.sql \
$(top_srcdir)/topology/test/regress/topoelement.sql \
+ $(top_srcdir)/topology/test/regress/topogeo_addlinestring_robust.sql \
$(top_srcdir)/topology/test/regress/topogeo_addlinestring.sql \
$(top_srcdir)/topology/test/regress/topogeo_addpoint_merge_edges.sql \
$(top_srcdir)/topology/test/regress/topogeo_addpoint.sql \
Summary of changes:
.woodpecker/tools.yml | 2 +-
ci/winnie/regress_postgis.sh | 6 ++++--
topology/test/tests.mk | 1 +
3 files changed, 6 insertions(+), 3 deletions(-)
hooks/post-receive
