[PostGIS] #5766: ValidateTopology(varchar toponame, geometry bbox) return error when sending with bbox, but not with out bbox
trac at osgeo.org
Thu Jul 25 21:01:45 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.4.3
Component: topology | Version: 3.4.x
Resolution: | Keywords:
Description changed by Lars Aksel Opsahl:
Old description:
> When calling with boxx I het this error 'face has wrong mbr|0|'
> topology.ValidateTopology('gronn_2023_v9_nosimlify_004','0103000020A21000000100000005000000FC60C227D47F09409A564F720FB64D40FC60C227D47F0940B6D8185120874E40EBF20689D0021D40B6D8185120874E40EBF20689D0021D409A564F720FB64D40FC60C227D47F09409A564F720FB64D40');
> If I call without it returns no errors
> SELECT 'ValidateTopology without bb', * FROM
> topology.ValidateTopology('gronn_2023_v9_nosimlify_004');
> This test code can be found in
> src/test/sql/regress/run_resolve_test.sh --nodrop
> ./src/test/sql/regress/rog_overlay_test_13c.sql; \
> Test add in this [https://gitlab.com/nibioopensource/resolve-overlap-and-
> gap/-/commit/5584a4e781c847c28fb1f1ef48bf97d2c86d35e9] in branch
> gap/-/tree/performance_and_robustnes_spike_remove?ref_type=heads]
New description:
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5766#comment:2>
