[PostGIS] #5766: ValidateTopology(varchar toponame, geometry bbox) return error when sending with bbox, but not with out bbox
PostGIS trac at osgeo.org
Fri Jul 26 06:50:58 PDT 2024
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  assigned
  Priority:  medium             |  Milestone:  PostGIS 3.4.3
 Component:  topology           |    Version:  3.4.x
Resolution:                     |   Keywords:
Changes (by strk):
 * status:  new => assigned
Comment:
 Instructions missed the need to run `make` at least once before running
 the test, but I finally got it run and with the addition of -v I can see
 the error:
 PostgreSQL 16.3 (Debian 16.3-1.pgdg120+1) on x86_64-pc-linux-gnu, compiled
 by gcc (Debian 12.2.0-14) 12.2.0, 64-bit
   Postgis 3.5.0dev - (3.4.0rc1-1172-g37fb070ef) - 2024-06-07 07:32:13
   scripts 3.5.0dev 3.4.0rc1-1172-g37fb070ef
   GEOS: 3.13.0dev-CAPI-1.19.0
   PROJ: 9.1.1
 Running tests
  after-create-script src/test/sql/regress
 /../../../../resolve_overlap_and_gap-static.sql .. ok
  after-create-script src/test/sql/regress/../../../../install-runtime-
 deps.sql .. ok
  ./src/test/sql/regress/rog_overlay_test_13c ... failed (diff expected
 obtained: /tmp/pgis_reg/test_3_diff)
 --- ./src/test/sql/regress/rog_overlay_test_13c_expected        2024-07-26
 12:43:59.396411133 +0200
 +++ /tmp/pgis_reg/test_3_out    2024-07-26 15:50:16.054497640 +0200
 @@ -1,3 +1,4 @@
 +ValidateTopology with bb|face has wrong mbr|0|
  num surfaces total no simplify|15
  num surfaces total no simplify below 5.0|0
  num surfaces total|14
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5766#comment:5>
