[PostGIS] #5766: ValidateTopology(varchar toponame, geometry bbox) return error when sending with bbox, but not with out bbox
PostGIS trac at osgeo.org
Fri Jul 26 08:31:03 PDT 2024
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  assigned
  Priority:  medium             |  Milestone:  PostGIS 3.4.3
 Component:  topology           |    Version:  3.4.x
Resolution:                     |   Keywords:
Comment (by strk):
 PR fixing the false negative when bbox is not passed is here:
 https://git.osgeo.org/gitea/postgis/postgis/pulls/209
 Rewording the face0 case would require documenting another message in the
 errors table of https://postgis.net/docs/ValidateTopology.html and I'm not
 sure it's worth it ("wrong MBR" is still valid in this case, after all)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5766#comment:7>
