[SCM] PostGIS branch stable-3.3 updated. 3.3.6-27-gd2a61b1ae
git at osgeo.org
git at osgeo.org
Fri Jul 26 10:53:04 PDT 2024
the project "PostGIS".
The branch, stable-3.3 has been updated
via d2a61b1ae7e121ceddf48e32c3a8dc24b6949bdb (commit)
from f09a1793b9b088cde7203a4a2b90f88faa1c990d (commit)
revisions in full, below.
commit d2a61b1ae7e121ceddf48e32c3a8dc24b6949bdb
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Jul 26 17:26:40 2024 +0200
Always report invalid non-null MBR of universal face
Even when no bbox is given to ValidateTopology.
Closes #5766 in 3.3 branch (3.3.7dev)
Includes regress test
diff --git a/NEWS b/NEWS
index 7f05ebb97..73a3914d4 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,7 @@ and PostgreSQL 15+.
* Bug Fixes and Enhancements *
+ - #5766, Always report invalid non-null MBR of universal face (Sandro Santilli)
- #5709, Fix loose mbr in topology.face on ST_ChangeEdgeGeom (Sandro Santilli)
- #5698, Fix robustness issue splitting line by vertex very close to endpoints,
affecting topology population functions (Sandro Santilli)
@@ -24,7 +25,6 @@ and PostgreSQL 15+.
- #5687, #5756 Support for PostgreSQL 17, revise postgis_get_full_version_schema()
to not rely on search_path
PostGIS 3.3.6
2024/02/07
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index a63cdfc78..8c2855bff 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -14,6 +14,8 @@
+-- #define POSTGIS_TOPOLOGY_DEBUG 1
-- Type returned by ValidateTopology
@@ -24,8 +26,7 @@ CREATE TYPE topology.ValidateTopology_ReturnType AS (
--- Return the exterior ring of a topology face
+-- Return the outermost ring of a topology face
CREATE OR REPLACE FUNCTION topology._ValidateTopologyGetFaceShellMaximalEdgeRing(atopology varchar, aface int)
RETURNS GEOMETRY AS
@@ -33,6 +34,7 @@ $BODY$
DECLARE
sql TEXT;
outsidePoint GEOMETRY;
+ leftmostEdge INT;
shell GEOMETRY;
BEGIN
@@ -51,42 +53,46 @@ BEGIN
EXECUTE sql USING aface INTO outsidePoint;
+ RAISE NOTICE 'Outside point of face %: %', aface, ST_AsText(outsidePoint);
+ IF outsidePoint IS NULL THEN
+ RETURN NULL;
+ END IF;
+ sql := format(
+ SELECT
+ CASE WHEN left_face = $1
+ THEN
+ edge_id
+ ELSE
+ -edge_id
+ END ring_id
+ FROM %1$I.edge
+ WHERE left_face = $1 or right_face = $1
+ ORDER BY
+ geom <-> $2
+ LIMIT 1
+ atopology
+ EXECUTE sql USING aface, outsidePoint INTO leftmostEdge;
+ RAISE NOTICE 'Leftmost edge of face %: %', aface, leftmostEdge;
+ IF leftmostEdge IS NULL THEN
+ RETURN NULL;
+ END IF;
sql := format(
WITH
- outside_point AS (
- SELECT ST_Translate(
- ST_StartPoint( ST_BoundingDiagonal(mbr) ),
- -1,
- -1
- FROM %1$I.face
- WHERE face_id = $1
- leftmost_edge AS (
- SELECT
- CASE WHEN left_face = $1
- THEN
- edge_id
- ELSE
- -edge_id
- END ring_id
- FROM %1$I.edge
- WHERE left_face = $1 or right_face = $1
- ORDER BY
-#if POSTGIS_PGSQL_VERSION < 95
- ST_Distance(geom, $2)
-#else
- geom <-> $2
-#endif
- LIMIT 1
edgering AS (
SELECT *
FROM
topology.GetRingEdges(
%1$L,
- (SELECT ring_id FROM leftmost_edge)
+ $1
SELECT
@@ -104,9 +110,9 @@ BEGIN
atopology
- --RAISE DEBUG 'SQL: %', sql;
+ RAISE DEBUG 'SQL: %', sql;
- EXECUTE sql USING aface, outsidePoint
+ EXECUTE sql USING leftmostEdge
INTO shell;
-- TODO: check if the ring is not closed
@@ -489,20 +495,15 @@ BEGIN
found_rings := found_rings + 1;
-#ifdef POSTGIS_TOPOLOGY_DEBUG
- RAISE DEBUG 'Ring % - faces:[%]',
- rec.ring_id,
- array_to_string(rec.side_faces, ',')
-#endif /* POSTGIS_TOPOLOGY_DEBUG */
-- Check that there's a single face advertised
IF array_upper(rec.side_faces,1) != 1
THEN --{
- RAISE DEBUG 'Side faces found on ring %: %', rec.ring_id,
- rec.side_faces;
+ RAISE DEBUG 'Ring % - mixed side faces:[%]',
+ rec.ring_id,
+ array_to_string(rec.side_faces, ',')
retrec.error = 'mixed face labeling in ring';
retrec.id1 = rec.ring_id;
@@ -541,6 +542,14 @@ BEGIN
END IF;
END IF;
+#ifdef POSTGIS_TOPOLOGY_DEBUG
+ RAISE DEBUG 'Ring % - side faces:[%] - %',
+ rec.ring_id,
+ array_to_string(rec.side_faces, ','),
+ CASE WHEN is_shell THEN 'shell (will end in shell_check)' ELSE 'hole' END
+#endif /* POSTGIS_TOPOLOGY_DEBUG */
IF is_shell THEN --{ It's a shell (CCW)
-- Check that a single face is ever used
-- for each distinct CCW ring (shell)
@@ -935,29 +944,47 @@ BEGIN
f.face_id = sc.face_id
+ GET DIAGNOSTICS affected_rows = ROW_COUNT;
+ RAISE DEBUG 'Constructed geometries of % faces (found shells)',
+ affected_rows;
DROP TABLE pg_temp.shell_check;
+ -- Add to face_check any missing face whose mbr overlaps
+ -- the given one.
+ -- This is done to still be able to check MBR consistency
+ -- See https://trac.osgeo.org/postgis/ticket/5766#comment:6
+ INSERT INTO pg_temp.face_check
+ SELECT face_id,
+ CASE WHEN face_id = 0 THEN
+ NULL
+ ELSE
+ topology._ValidateTopologyGetFaceShellMaximalEdgeRing(toponame, face_id)
+ END as real_shell,
+ mbr
+ FROM face
+ WHERE ( bbox IS NULL OR mbr && bbox )
+ AND (
+ CASE WHEN invalid_faces IS NOT NULL THEN
+ NOT face_id = ANY(invalid_faces)
+ ELSE
+ TRUE
+ END
+ AND face_id NOT IN (
+ SELECT face_id FROM pg_temp.face_check
- IF bbox IS NOT NULL
- THEN --{
- INSERT INTO pg_temp.face_check
- SELECT face_id,
- topology._ValidateTopologyGetFaceShellMaximalEdgeRing(toponame, face_id),
- mbr
- FROM face
- WHERE mbr && bbox
- AND (
- CASE WHEN invalid_faces IS NOT NULL THEN
- NOT face_id = ANY(invalid_faces)
- ELSE
- TRUE
- END
- AND face_id NOT IN (
- SELECT face_id FROM pg_temp.face_check
- END IF; --}
+ RAISE DEBUG 'Added % missing faces in face_check table',
+ affected_rows;
-- Build a gist index on geom
CREATE INDEX ON face_check USING gist (shell);
@@ -975,26 +1002,53 @@ BEGIN
affected_rows := affected_rows + 1;
- IF rec.shell IS NULL OR ST_IsEmpty(rec.shell)
- THEN
- -- Face missing !
- retrec.error := 'face has no rings';
- retrec.id1 := rec.face_id;
- retrec.id2 := NULL;
- RETURN NEXT retrec;
- END IF;
+ IF rec.face_id != 0 THEN -- {
- IF NOT ST_Equals(rec.mbr, ST_Envelope(rec.shell))
- THEN
+ -- Real face need have rings and matching MBR
+ IF rec.shell IS NULL OR ST_IsEmpty(rec.shell)
+ THEN
+ -- Face missing !
+ retrec.error := 'face has no rings';
+ retrec.id1 := rec.face_id;
+ retrec.id2 := NULL;
+ RETURN NEXT retrec;
+ END IF;
+ IF NOT ST_Equals(rec.mbr, ST_Envelope(rec.shell))
+ THEN
- RAISE DEBUG 'MBR expected:% obtained:%', ST_AsEWKT(ST_Envelope(rec.shell)), ST_AsEWKT(ST_Envelope(rec.mbr));
+ RAISE DEBUG 'MBR expected:% obtained:%', ST_AsEWKT(ST_Envelope(rec.shell)), ST_AsEWKT(ST_Envelope(rec.mbr));
- -- Inconsistent MBR!
- retrec.error := 'face has wrong mbr';
- END IF;
+ -- Inconsistent MBR!
+ retrec.error := 'face has wrong mbr';
+ END IF;
+ ELSE --}{
+ -- Universal face need have no shell rings and NULL MBR
+ IF rec.shell IS NOT NULL OR NOT ST_IsEmpty(rec.shell)
+ THEN
+ retrec.error := 'universal face has shell rings';
+ END IF;
+ IF rec.mbr IS NOT NULL
+ THEN
+ -- TODO: make the message more specific about universal face ?
+ END IF;
+ END IF; --}
END LOOP; --}
diff --git a/topology/test/regress/validatetopology.sql b/topology/test/regress/validatetopology.sql
index 8a23aed2e..173e4a5b1 100644
--- a/topology/test/regress/validatetopology.sql
+++ b/topology/test/regress/validatetopology.sql
@@ -206,5 +206,19 @@ SELECT '#5548.1', * FROM topology.ValidateTopology('t5548',
ST_MakeEnvelope(2,2,4,4));
ROLLBACK;
+-- See https://trac.osgeo.org/postgis/ticket/5766
+BEGIN;
+SELECT NULL FROM topology.CreateTopology('t5766');
+SELECT NULL FROM topology.TopoGeo_addPolygon('t5766', 'POLYGON((0 0, 1 2, 2 0,0 0))');
+UPDATE t5766.face SET mbr = ST_MakeEnvelope(0,0,2,2) WHERE face_id = 0; -- bbox matching leftmost ring
+SELECT '#5766.1', 'no bbox', (array_agg(v))[1] FROM topology.ValidateTopology('t5766') v;
+SELECT '#5766.1', 'overlapping bbox', (array_agg(v))[1] FROM topology.ValidateTopology('t5766', 'POINT(1 1)') v;
+SELECT '#5766.1', 'disjoint bbox', (array_agg(v))[1] FROM topology.ValidateTopology('t5766', 'POINT(3 0)') v;
+UPDATE t5766.face SET mbr = ST_MakeEnvelope(0,0,1,2) WHERE face_id = 0; -- bbox not matching leftmost ring
+SELECT '#5766.2', 'no bbox', (array_agg(v))[1] FROM topology.ValidateTopology('t5766') v;
+SELECT '#5766.2', 'overlapping bbox', (array_agg(v))[1] FROM topology.ValidateTopology('t5766', 'POINT(1 1)') v;
+SELECT '#5766.2', 'disjoint bbox', (array_agg(v))[1] FROM topology.ValidateTopology('t5766', 'POINT(3 0)') v;
+ROLLBACK;
SELECT NULL FROM topology.DropTopology('city_data');
diff --git a/topology/test/regress/validatetopology_expected b/topology/test/regress/validatetopology_expected
index 82242d0a4..da497ee20 100644
--- a/topology/test/regress/validatetopology_expected
+++ b/topology/test/regress/validatetopology_expected
@@ -40,3 +40,9 @@
#5403.0|1
#5548.0|1
#5548.1|face without edges|1|
+#5766.1|no bbox|("face has wrong mbr",0,)
+#5766.1|overlapping bbox|("face has wrong mbr",0,)
+#5766.1|disjoint bbox|
+#5766.2|no bbox|("face has wrong mbr",0,)
+#5766.2|overlapping bbox|("face has wrong mbr",0,)
+#5766.2|disjoint bbox|
Summary of changes:
NEWS | 2 +-
topology/sql/manage/ValidateTopology.sql.in | 210 +++++++++++++++---------
topology/test/regress/validatetopology.sql | 14 ++
topology/test/regress/validatetopology_expected | 6 +
4 files changed, 153 insertions(+), 79 deletions(-)
hooks/post-receive
