Re: [PostGIS] #5767: 3.2 branch does not build against PG16: error: too few arguments to function ‘get_guc_variables’
trac at osgeo.org
Sat Jul 27 00:03:00 PDT 2024
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.2.8
Component: build | Version: 3.2.x
Resolution: | Keywords:
Comment (by robe):
This support was only carried for PostGIS 3.3 and 3.4.
We should put a configure check that 3.2 is not supported on PG 16.
Already documented in
See the matrix -
https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
and the docs -
https://postgis.net/docs/manual-3.2/postgis_installation.html#install_requirements
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5767#comment:1>
