[SCM] PostGIS branch stable-3.4 updated. 3.4.2-38-g58bcf7f1c
Thu May 2 20:25:44 PDT 2024
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  58bcf7f1c656b8c61b05a390335ef0ccd42dc59e (commit)
      from  d0036abbd7b438049806c255af4e07d6826cfa05 (commit)
revisions in full, below.
commit 58bcf7f1c656b8c61b05a390335ef0ccd42dc59e
Author: Regina Obe <lr at pcorp.us>
Date:   Thu May 2 23:25:39 2024 -0400
    Add note about behavior change caused by GEOS. Closes #5725 for PostGIS 3.4.3
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index f6040a5e4..8692212fa 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -1970,6 +1970,7 @@ key=value pairs to tweak operations as follows:
                 </para>
             <para>Performed by the GEOS module.</para>
+            <para role="changed">Behavior changed in GEOS 3.11 so offset curves now have the same direction as the input line, for both positive and negative offsets.</para>
             <para role="availability" conformance="2.0">Availability: 2.0</para>
             <para role="enhanced" conformance="2.5">Enhanced: 2.5 - added support for GEOMETRYCOLLECTION and MULTILINESTRING</para>
Summary of changes:
 doc/reference_processing.xml | 1 +
 1 file changed, 1 insertion(+)
hooks/post-receive
