[PostGIS] #5699: ERROR: XX000: SQL/MM Spatial exception - geometry crosses an edge
trac at osgeo.org
Wed May 8 01:43:20 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.4.3
Component: topology | Version: 3.4.x
Resolution: fixed | Keywords: robustness
Comment (by strk):
Replying to [comment:20 strk]:
> For the record: the test put in place for this ticket passed just fine
with GEOS-3.8 (pre-OverlayNG) and without the change of snapping all
edges.
The reason for this is just because GEOS-3.8 is unable to detect the
invalidity. Follow up discussion in
https://trac.osgeo.org/postgis/ticket/5722#comment:18
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5699#comment:22>
