[PostGIS] #5730: CirrusCI fails building vector_tile.pb-c.c
trac at osgeo.org
Thu May 16 01:57:06 PDT 2024
Reporter: strk | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: Website Management, Bots
Component: QA/buildbots | Version: master
Keywords: |
From https://cirrus-ci.com/task/4514659120709632?logs=test#L3911
E0000 00:00:1715847348.638439 52830 command_line_interface.cc:1534]
Built-in generator --c_out specifies a maximum edition PROTO3 which is not
the protoc maximum 2023.
E0000 00:00:1715847348.638406 52834 command_line_interface.cc:1534]
make[1]: *** [vector_tile.pb-c.c] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5730>
