[SCM] PostGIS branch master updated. 3.4.0rc1-1110-g7db0f94d5
git at osgeo.org
git at osgeo.org
Thu May 16 06:35:59 PDT 2024
the project "PostGIS".
via 7db0f94d54f4203137ae933e6f414c34099eb89b (commit)
from a14fb0181ced7c447e08edae66e97d5f0afa3864 (commit)
revisions in full, below.
commit 7db0f94d54f4203137ae933e6f414c34099eb89b
Author: Sandro Santilli <strk at kbt.io>
Date: Thu May 16 15:35:31 2024 +0200
Convert more CU_ASSERT_STRING_EQUAL to ASSERT_STRING_EQUAL
Also tweaked just swapped obtained/expected
diff --git a/liblwgeom/cunit/cu_chaikin.c b/liblwgeom/cunit/cu_chaikin.c
index 60b398b3e..4dd95264b 100644
--- a/liblwgeom/cunit/cu_chaikin.c
+++ b/liblwgeom/cunit/cu_chaikin.c
@@ -27,7 +27,7 @@ static void do_test_chaikin(char *geom_txt,char *expected, int n_iterations, int
out_txt = lwgeom_to_wkt(geom_out, WKT_EXTENDED, 3, NULL);
if(strcmp(expected, out_txt))
printf("%s is not equal to %s\n", expected, out_txt);
- CU_ASSERT_STRING_EQUAL(expected, out_txt)
+ ASSERT_STRING_EQUAL(expected, out_txt);
lwfree(out_txt);
lwgeom_free(geom_in);
lwgeom_free(geom_out);
diff --git a/liblwgeom/cunit/cu_clean.c b/liblwgeom/cunit/cu_clean.c
index 315526559..00921d055 100644
--- a/liblwgeom/cunit/cu_clean.c
+++ b/liblwgeom/cunit/cu_clean.c
@@ -98,7 +98,7 @@ static void test_lwgeom_make_valid(void)
TODO: This doesn't work on windows returns in different order.
strk figure out why. For now will replace with normalized version
-/* CU_ASSERT_STRING_EQUAL(ewkt,
+/* ASSERT_STRING_EQUAL(ewkt,
"GEOMETRYCOLLECTION(POINT(0 0),MULTIPOLYGON(((5 5,0 0,0 10,5 5)),((5 5,10 10,10 0,5 5))),LINESTRING(10 0,10 10))");*/
gexp = lwgeom_from_wkt(
"GEOMETRYCOLLECTION(MULTIPOLYGON(((5 5,10 10,10 0,5 5)),((0 0,0 10,5 5,0 0))),LINESTRING(10 0,10 10),POINT(0 0))",
@@ -122,7 +122,7 @@ static void test_lwgeom_make_valid(void)
ewkt = lwgeom_to_ewkt(gout);
/* printf("c = %s\n", ewkt); */
- CU_ASSERT_STRING_EQUAL(ewkt,
+ ASSERT_STRING_EQUAL(ewkt,
"MULTIPOINT(0 0,1 1,2 2)");
lwfree(ewkt);
@@ -141,7 +141,7 @@ static void test_lwgeom_make_valid(void)
"POLYGON((10 22,10 32,20 32,20 22,10 22))");
lwfree(ewkt);
diff --git a/liblwgeom/cunit/cu_clip_by_rect.c b/liblwgeom/cunit/cu_clip_by_rect.c
index c4cf8b109..4ea34451a 100644
--- a/liblwgeom/cunit/cu_clip_by_rect.c
+++ b/liblwgeom/cunit/cu_clip_by_rect.c
@@ -30,7 +30,7 @@ static void test_lwgeom_clip_by_rect(void)
out = lwgeom_clip_by_rect(in, 5, 0, 10, 10);
tmp = lwgeom_to_ewkt(out);
/* printf("%s\n", tmp); */
- CU_ASSERT_STRING_EQUAL("LINESTRING(5 5,10 0)", tmp)
+ ASSERT_STRING_EQUAL(tmp, "LINESTRING(5 5,10 0)");
lwfree(tmp); lwgeom_free(out); lwgeom_free(in);
wkt = "LINESTRING EMPTY";
@@ -38,7 +38,7 @@ static void test_lwgeom_clip_by_rect(void)
- CU_ASSERT_STRING_EQUAL(wkt, tmp)
+ ASSERT_STRING_EQUAL(tmp, wkt);
wkt = "MULTIPOINT EMPTY";
@@ -46,7 +46,7 @@ static void test_lwgeom_clip_by_rect(void)
wkt = "MULTIPOINT(0 0, 6 6, 7 5)";
@@ -54,7 +54,7 @@ static void test_lwgeom_clip_by_rect(void)
- CU_ASSERT_STRING_EQUAL("MULTIPOINT(6 6,7 5)", tmp)
+ ASSERT_STRING_EQUAL(tmp, "MULTIPOINT(6 6,7 5)");
/* Disjoint polygon */
diff --git a/liblwgeom/cunit/cu_filterm.c b/liblwgeom/cunit/cu_filterm.c
index d516550a4..d675d9b4e 100644
--- a/liblwgeom/cunit/cu_filterm.c
+++ b/liblwgeom/cunit/cu_filterm.c
@@ -27,7 +27,7 @@ static void do_test_filterm(char *geom_txt,char *expected, double min, double ma
lwfree(out_txt);
diff --git a/liblwgeom/cunit/cu_force_dims.c b/liblwgeom/cunit/cu_force_dims.c
index 68a6862d3..274541428 100644
--- a/liblwgeom/cunit/cu_force_dims.c
+++ b/liblwgeom/cunit/cu_force_dims.c
@@ -29,7 +29,7 @@ test_force_2d(void)
geom = lwgeom_from_wkt("CIRCULARSTRINGM(-5 0 4,0 5 3,5 0 2,10 -5 1,15 0 0)", LW_PARSER_CHECK_NONE);
geom2d = lwgeom_force_2d(geom);
wkt_out = lwgeom_to_ewkt(geom2d);
- CU_ASSERT_STRING_EQUAL("CIRCULARSTRING(-5 0,0 5,5 0,10 -5,15 0)", wkt_out);
+ ASSERT_STRING_EQUAL("CIRCULARSTRING(-5 0,0 5,5 0,10 -5,15 0)", wkt_out);
lwgeom_free(geom);
lwgeom_free(geom2d);
lwfree(wkt_out);
@@ -39,7 +39,7 @@ test_force_2d(void)
"GEOMETRYCOLLECTION(POINT(0 0),LINESTRING(1 1,2 2),POLYGON((0 0,0 1,1 1,1 0,0 0)),CURVEPOLYGON(CIRCULARSTRING(0 0,1 1,2 2,1 1,0 0)))",
wkt_out);
lwgeom_free(geom);
@@ -57,7 +57,7 @@ test_force_3dm(void)
geom = lwgeom_from_wkt("CIRCULARSTRING(-5 0 4,0 5 3,5 0 2,10 -5 1,15 0 0)", LW_PARSER_CHECK_NONE);
geom3dm = lwgeom_force_3dm(geom, 1);
wkt_out = lwgeom_to_ewkt(geom3dm);
- CU_ASSERT_STRING_EQUAL("CIRCULARSTRINGM(-5 0 1,0 5 1,5 0 1,10 -5 1,15 0 1)", wkt_out);
+ ASSERT_STRING_EQUAL("CIRCULARSTRINGM(-5 0 1,0 5 1,5 0 1,10 -5 1,15 0 1)", wkt_out);
lwgeom_free(geom);
lwgeom_free(geom3dm);
lwfree(wkt_out);
@@ -73,7 +73,7 @@ test_force_3dz(void)
geom = lwgeom_from_wkt("CIRCULARSTRING(-5 0,0 5,5 0,10 -5,15 0)", LW_PARSER_CHECK_NONE);
geom3dz = lwgeom_force_3dz(geom, -99);
wkt_out = lwgeom_to_ewkt(geom3dz);
- CU_ASSERT_STRING_EQUAL("CIRCULARSTRING(-5 0 -99,0 5 -99,5 0 -99,10 -5 -99,15 0 -99)", wkt_out);
+ ASSERT_STRING_EQUAL("CIRCULARSTRING(-5 0 -99,0 5 -99,5 0 -99,10 -5 -99,15 0 -99)", wkt_out);
lwgeom_free(geom);
lwgeom_free(geom3dz);
lwfree(wkt_out);
@@ -81,7 +81,7 @@ test_force_3dz(void)
geom3dz = lwgeom_force_3dz(geom, 0.0);
- CU_ASSERT_STRING_EQUAL("CIRCULARSTRING(-5 0 0,0 5 0,5 0 0,10 -5 0,15 0 0)", wkt_out);
+ ASSERT_STRING_EQUAL("CIRCULARSTRING(-5 0 0,0 5 0,5 0 0,10 -5 0,15 0 0)", wkt_out);
lwgeom_free(geom);
lwfree(wkt_out);
@@ -97,7 +97,7 @@ test_force_4d(void)
geom = lwgeom_from_wkt("POINT(1 2)", LW_PARSER_CHECK_NONE);
geom4d = lwgeom_force_4d(geom, 3, 4);
wkt_out = lwgeom_to_ewkt(geom4d);
- CU_ASSERT_STRING_EQUAL("POINT(1 2 3 4)", wkt_out);
+ ASSERT_STRING_EQUAL("POINT(1 2 3 4)", wkt_out);
lwgeom_free(geom);
lwgeom_free(geom4d);
lwfree(wkt_out);
diff --git a/liblwgeom/cunit/cu_force_sfs.c b/liblwgeom/cunit/cu_force_sfs.c
index 73026e994..a9d355ab1 100644
--- a/liblwgeom/cunit/cu_force_sfs.c
+++ b/liblwgeom/cunit/cu_force_sfs.c
@@ -28,7 +28,7 @@ static void do_geom_test(char * in, char * out)
if (strcmp(tmp, out))
fprintf(stderr, "\nIn: %s\nOut: %s\nExp: %s\n",
in, tmp, out);
- CU_ASSERT_STRING_EQUAL(tmp, out);
+ ASSERT_STRING_EQUAL(tmp, out);
lwfree(tmp);
lwgeom_free(h);
diff --git a/liblwgeom/cunit/cu_gserialized1.c b/liblwgeom/cunit/cu_gserialized1.c
index 66cc0a55e..47fb42e02 100644
--- a/liblwgeom/cunit/cu_gserialized1.c
+++ b/liblwgeom/cunit/cu_gserialized1.c
@@ -280,7 +280,7 @@ static void test_lwgeom_from_gserialized(void)
out_ewkt = lwgeom_to_ewkt(geom2);
/* printf("\n in = %s\nout = %s\n", in_ewkt, out_ewkt); */
- CU_ASSERT_STRING_EQUAL(in_ewkt, out_ewkt);
+ ASSERT_STRING_EQUAL(in_ewkt, out_ewkt);
/* either both or none of the bboxes are null */
CU_ASSERT( (geom->bbox != NULL) || (geom2->bbox == NULL) );
@@ -522,7 +522,7 @@ static void do_lwgeom_swap_ordinates(char *in, char *out)
if (strcmp(t, out))
fprintf(stderr, "\nIn: %s\nOut: %s\nTheo: %s\n", in, t, out);
- CU_ASSERT_STRING_EQUAL(t, out)
+ ASSERT_STRING_EQUAL(t, out);
lwgeom_free(g);
lwfree(t);
@@ -731,7 +731,7 @@ static void test_lwgeom_clone(void)
out_ewkt = lwgeom_to_ewkt(cloned);
if (strcmp(in_ewkt, out_ewkt))
fprintf(stderr, "\nExp: %s\nObt: %s\n", in_ewkt, out_ewkt);
lwfree(out_ewkt);
lwgeom_free(cloned);
lwgeom_free(geom);
@@ -757,7 +757,7 @@ static void test_lwgeom_force_clockwise(void)
out_ewkt = lwgeom_to_ewkt(geom);
lwfree(out_ewkt);
lwgeom_free(geom);
@@ -769,7 +769,7 @@ static void test_lwgeom_force_clockwise(void)
lwfree(out_ewkt);
lwgeom_free(geom);
@@ -781,7 +781,7 @@ static void test_lwgeom_force_clockwise(void)
lwfree(out_ewkt);
lwgeom_free(geom);
@@ -793,7 +793,7 @@ static void test_lwgeom_force_clockwise(void)
lwfree(out_ewkt);
lwgeom_free(geom);
@@ -962,7 +962,7 @@ static void test_lwgeom_as_curve(void)
lwfree(out_ewkt);
lwgeom_free(geom);
lwgeom_free(geom2);
@@ -973,7 +973,7 @@ static void test_lwgeom_as_curve(void)
lwfree(out_ewkt);
lwgeom_free(geom);
lwgeom_free(geom2);
@@ -984,7 +984,7 @@ static void test_lwgeom_as_curve(void)
lwfree(out_ewkt);
lwgeom_free(geom);
lwgeom_free(geom2);
@@ -995,7 +995,7 @@ static void test_lwgeom_as_curve(void)
lwfree(out_ewkt);
lwgeom_free(geom);
lwgeom_free(geom2);
diff --git a/liblwgeom/cunit/cu_gserialized2.c b/liblwgeom/cunit/cu_gserialized2.c
index 1f86dd080..6df3aa1f8 100644
--- a/liblwgeom/cunit/cu_gserialized2.c
+++ b/liblwgeom/cunit/cu_gserialized2.c
@@ -228,7 +228,7 @@ static void test_lwgeom_from_gserialized2(void)
g2 = gserialized2_from_lwgeom(geom2, &size2);
CU_ASSERT_EQUAL(g1->gflags, g2->gflags);
diff --git a/liblwgeom/cunit/cu_homogenize.c b/liblwgeom/cunit/cu_homogenize.c
index 2fbda97e4..556f3dc4d 100644
--- a/liblwgeom/cunit/cu_homogenize.c
+++ b/liblwgeom/cunit/cu_homogenize.c
in, tmp, out);
lwfree(tmp);
lwgeom_free(g);
/* See http://trac.osgeo.org/postgis/ticket/1104 */
diff --git a/liblwgeom/cunit/cu_in_encoded_polyline.c b/liblwgeom/cunit/cu_in_encoded_polyline.c
index 597493c81..f76b726f9 100644
--- a/liblwgeom/cunit/cu_in_encoded_polyline.c
+++ b/liblwgeom/cunit/cu_in_encoded_polyline.c
@@ -31,7 +31,7 @@ static void do_encoded_polyline_test(char * in, int precision, char * out)
if (strcmp(h, out))
fprintf(stderr, "\nIn: %s\nOut: %s\nTheo: %s\n", in, h, out);
- CU_ASSERT_STRING_EQUAL(h, out);
+ ASSERT_STRING_EQUAL(h, out);
lwgeom_free(g);
if ( h ) lwfree(h);
diff --git a/liblwgeom/cunit/cu_in_geojson.c b/liblwgeom/cunit/cu_in_geojson.c
index 439cf9bf4..b333aa4c2 100644
--- a/liblwgeom/cunit/cu_in_geojson.c
+++ b/liblwgeom/cunit/cu_in_geojson.c
@@ -38,11 +38,11 @@ static void do_geojson_test(const char * exp, char * in, char * exp_srs)
if (strcmp(h, exp))
fprintf(stderr, "\nIn: %s\nExp: %s\nObt: %s\n", in, exp, h);
- CU_ASSERT_STRING_EQUAL(h, exp);
+ ASSERT_STRING_EQUAL(h, exp);
else
if ( exp_srs )
@@ -55,7 +55,7 @@ static void do_geojson_test(const char * exp, char * in, char * exp_srs)
else if (strcmp(srs, exp_srs))
fprintf(stderr, "\nIn: %s\nExp: %s\nObt: %s\n", in, exp_srs, srs);
- CU_ASSERT_STRING_EQUAL(srs, exp_srs);
+ ASSERT_STRING_EQUAL(srs, exp_srs);
else if ( srs )
diff --git a/liblwgeom/cunit/cu_in_twkb.c b/liblwgeom/cunit/cu_in_twkb.c
index 6dcc39a96..5e0f0cfd0 100644
--- a/liblwgeom/cunit/cu_in_twkb.c
+++ b/liblwgeom/cunit/cu_in_twkb.c
@@ -98,101 +98,101 @@ static void test_twkb_in_point(void)
cu_twkb_in("POINT(0 0 0 0)");
// printf("old: %s\nnew: %s\n",hex_a, hex_b);
- CU_ASSERT_STRING_EQUAL(hex_a, hex_b);
+ ASSERT_STRING_EQUAL(hex_a, hex_b);
cu_twkb_in("POINT(1 1)");
cu_twkb_in("POINT EMPTY");
static void test_twkb_in_linestring(void)
cu_twkb_in("LINESTRING(0 0,1 1)");
cu_twkb_in("LINESTRING(0 0 1,1 1 2,2 2 3)");
cu_twkb_in("LINESTRING EMPTY");
static void test_twkb_in_polygon(void)
cu_twkb_in("POLYGON((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0))");
cu_twkb_in("POLYGON((0 0 0 1,0 1 0 2,1 1 0 3,1 0 0 4,0 0 0 5))");
cu_twkb_in("POLYGON EMPTY");
static void test_twkb_in_multipoint(void)
cu_twkb_in("MULTIPOINT Z EMPTY");
cu_twkb_in("MULTIPOINT(1 2, EMPTY, 5 6)");
// printf(" 1st: %s\n 2nd: %s\n", hex_a, hex_b);
cu_twkb_in("MULTIPOINT(0 0 0,0 1 0,1 1 0,1 0 0,0 0 1)");
cu_twkb_in("MULTIPOINT(1 2 3, 1 2 3, 4 5 6, -3 -4 -5, -10 -5 -1)");
static void test_twkb_in_multilinestring(void)
cu_twkb_in("MULTILINESTRING((0 0,0 1),(1 1, 10 10))");
cu_twkb_in("MULTILINESTRING((0 0,0 1),EMPTY,(1 1, 10 10))");
cu_twkb_in("MULTILINESTRING((0 0 200000,0 1 10),(1 100000000 23, 10 10 45))");
cu_twkb_in("MULTILINESTRING EMPTY");
static void test_twkb_in_multipolygon(void)
cu_twkb_in("MULTIPOLYGON(((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)),((-1 -1 0,-1 2 0,2 2 0,2 -1 0,-1 -1 0),(0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)))");
//printf("old: %s\nnew: %s\n",hex_a, hex_b);
cu_twkb_in("MULTIPOLYGON EMPTY");
static void test_twkb_in_collection(void)
cu_twkb_in("GEOMETRYCOLLECTION(MULTIPOLYGON(((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0))),POLYGON((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)),POINT(1 1 1),LINESTRING(0 0 0, 1 1 1))");
cu_twkb_in("GEOMETRYCOLLECTION(POLYGON((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)),POINT(1 1 1))");
cu_twkb_in("GEOMETRYCOLLECTION EMPTY");
cu_twkb_in("GEOMETRYCOLLECTION(POINT(1 2 3), LINESTRING EMPTY, POINT(4 5 6))");
cu_twkb_in("GEOMETRYCOLLECTION(POINT(1 2 3), POINT EMPTY, POINT(4 5 6))");
@@ -205,17 +205,17 @@ static void test_twkb_in_precision(void)
for ( precision = 1; precision <= 6; precision++ )
/* Go back to default precision */
diff --git a/liblwgeom/cunit/cu_in_wkb.c b/liblwgeom/cunit/cu_in_wkb.c
index 56cb1f015..e63eba7d7 100644
--- a/liblwgeom/cunit/cu_in_wkb.c
+++ b/liblwgeom/cunit/cu_in_wkb.c
@@ -105,59 +105,59 @@ static void test_wkb_in_point(void)
cu_wkb_in("POINT(0 0 0 0)");
cu_wkb_in("SRID=4;POINTM(1 1 1)");
cu_wkb_in("POINT EMPTY");
cu_wkb_in("SRID=4326;POINT EMPTY");
cu_wkb_in("POINT Z EMPTY");
cu_wkb_in("POINT M EMPTY");
cu_wkb_in("POINT ZM EMPTY");
static void test_wkb_in_linestring(void)
cu_wkb_in("LINESTRING(0 0,1 1)");
cu_wkb_in("LINESTRING(0 0 1,1 1 2,2 2 3)");
static void test_wkb_in_polygon(void)
cu_wkb_in("SRID=4;POLYGON((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0))");
cu_wkb_in("SRID=14;POLYGON((0 0 0 1,0 1 0 2,1 1 0 3,1 0 0 4,0 0 0 5))");
cu_wkb_in("SRID=4;POLYGON((0 0 0 1,0 1 0 2,1 1 0 3,1 0 0 4,0 0 0 5))");
cu_wkb_in("POLYGON EMPTY");
static void test_wkb_in_multipoint(void)
cu_wkb_in("SRID=4;MULTIPOINT(0 0 0,0 1 0,1 1 0,1 0 0,0 0 1)");
cu_wkb_in("MULTIPOINT(0 0 0, 0.26794919243112270647255365849413 1 3)");
static void test_wkb_in_multilinestring(void) {}
@@ -165,45 +165,45 @@ static void test_wkb_in_multilinestring(void) {}
static void test_wkb_in_multipolygon(void)
cu_wkb_in("SRID=14;MULTIPOLYGON(((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)),((-1 -1 0,-1 2 0,2 2 0,2 -1 0,-1 -1 0),(0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)))");
static void test_wkb_in_collection(void)
cu_wkb_in("SRID=14;GEOMETRYCOLLECTION(POLYGON((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)),POINT(1 1 1))");
cu_wkb_in("GEOMETRYCOLLECTION EMPTY");
cu_wkb_in("SRID=14;GEOMETRYCOLLECTION(MULTIPOLYGON(((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0))),POLYGON((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)),POINT(1 1 1),LINESTRING(0 0 0, 1 1 1))");
static void test_wkb_in_circularstring(void)
cu_wkb_in("CIRCULARSTRING(0 -2,-2 0,0 2,2 0,0 -2)");
cu_wkb_in("CIRCULARSTRING(-5 0 0 4, 0 5 1 3, 5 0 2 2, 10 -5 3 1, 15 0 4 0)");
cu_wkb_in("SRID=43;CIRCULARSTRING(-5 0 0 4, 0 5 1 3, 5 0 2 2, 10 -5 3 1, 15 0 4 0)");
static void test_wkb_in_compoundcurve(void)
cu_wkb_in("COMPOUNDCURVE(CIRCULARSTRING(0 0 0, 0.26794919243112270647255365849413 1 3, 0.5857864376269049511983112757903 1.4142135623730950488016887242097 1),(0.5857864376269049511983112757903 1.4142135623730950488016887242097 1,2 0 0,0 0 0))");
static void test_wkb_in_curvpolygon(void)
cu_wkb_in("CURVEPOLYGON(CIRCULARSTRING(-2 0 0 0,-1 -1 1 2,0 0 2 4,1 -1 3 6,2 0 4 8,0 2 2 4,-2 0 0 0),(-1 0 1 2,0 0.5 2 4,1 0 3 6,0 1 3 4,-1 0 1 2))");
static void test_wkb_in_multicurve(void) {}
diff --git a/liblwgeom/cunit/cu_in_wkt.c b/liblwgeom/cunit/cu_in_wkt.c
index dc25093e1..646cd9266 100644
--- a/liblwgeom/cunit/cu_in_wkt.c
+++ b/liblwgeom/cunit/cu_in_wkt.c
@@ -79,7 +79,7 @@ static void test_wkt_in_point(void)
s = "POINT(1 2) foobar";
r = cu_wkt_in(s, WKT_SFSQL);
- CU_ASSERT_STRING_EQUAL("parse error - invalid geometry", r);
+ ASSERT_STRING_EQUAL("parse error - invalid geometry", r);
lwfree(r);
s = "POINT(1e700 0)";
@@ -89,23 +89,23 @@ static void test_wkt_in_point(void)
s = "POINT(0 0)";
- CU_ASSERT_STRING_EQUAL(r,s);
+ ASSERT_STRING_EQUAL(r,s);
lwfree(r);
s = "POINT EMPTY";
lwfree(r);
s = "POINT M EMPTY";
r = cu_wkt_in(s, WKT_ISO);
lwfree(r);
s = "point(nan 10)";
cu_strtolower(r);
lwfree(r);
// printf("\nIN: %s\nOUT: %s\n",s,r);
@@ -115,42 +115,42 @@ static void test_wkt_in_linestring(void)
s = "LINESTRING EMPTY";
lwfree(r);
s = "LINESTRING(0 0,1 1)";
lwfree(r);
s = "LINESTRING(0 0 0,1 1 1)";
r = cu_wkt_in(s, WKT_EXTENDED);
lwfree(r);
s = "LINESTRING M (0 0 0,1 1 1)";
lwfree(r);
s = "LINESTRING ZM (0 0 0 1,1 1 1 1,2 2 2 2,0.141231 4 5 4)";
lwfree(r);
s = "LINESTRINGM(0 0 0,1 1 1)";
lwfree(r);
s = "LINESTRING ZM EMPTY";
lwfree(r);
s = "LINESTRING Z (0 0 0 1, 0 1 0 1)";
- CU_ASSERT_STRING_EQUAL(r,"can not mix dimensionality in a geometry");
+ ASSERT_STRING_EQUAL(r,"can not mix dimensionality in a geometry");
//printf("\nIN: %s\nOUT: %s\n",s,r);
lwfree(r);
@@ -160,17 +160,17 @@ static void test_wkt_in_polygon(void)
s = "POLYGON((0 0,0 1,1 1,0 0))";
lwfree(r);
s = "POLYGON Z ((0 0,0 10,10 10,10 0,0 0),(1 1 1,1 2 1,2 2 1,2 1 1,1 1 1))";
lwfree(r);
s = "POLYGON Z ((0 0,0 10,10 10,10 0,0 0),(1 1,1 2,2 2,2 1,1 1))";
lwfree(r);
@@ -183,19 +183,19 @@ static void test_wkt_in_multipoint(void)
// s = "MULTIPOINT(-1 -2 -3,5.4 6.6 7.77,-5.4 -6.6 -7.77,1000000 1e-06 -1000000,-1.3e-06 -1.4e-05 0)";
// r = cu_wkt_in(s, WKT_EXTENDED);
- // CU_ASSERT_STRING_EQUAL(r,s);
+ // ASSERT_STRING_EQUAL(r,s);
// lwfree(r);
s = "MULTIPOINT(0 0)";
lwfree(r);
s = "MULTIPOINT(0 0,1 1)";
lwfree(r);
@@ -204,7 +204,7 @@ static void test_wkt_in_multilinestring(void)
s = "MULTILINESTRING((0 0,1 1),(1 1,2 2),(3 3,3 3,3 3,2 2,2 1))";
lwfree(r);
@@ -214,19 +214,19 @@ static void test_wkt_in_multipolygon(void)
s = "MULTIPOLYGON(((0 0,0 1,1 1,0 0)))";
lwfree(r);
s = "MULTIPOLYGON(((0 0,0 10,10 10,0 0),(1 1,1 2,2 2,1 1)),((-10 -10,-10 -5,-5 -5,-10 -10)))";
lwfree(r);
s = "SRID=4;MULTIPOLYGON(((0 0,0 1,1 1,0 0)))";
lwfree(r);
@@ -237,32 +237,32 @@ static void test_wkt_in_collection(void)
s = "SRID=5;GEOMETRYCOLLECTION(POINT(0 0),LINESTRING(1 0,0 0),CIRCULARSTRING(0 0,0 1,1 1,0 1,2 2))";
lwfree(r);
s = "GEOMETRYCOLLECTION(POINT(0 0),POINT EMPTY,LINESTRING(1 0,0 0),POLYGON EMPTY,CIRCULARSTRING(0 0,0 1,1 1,0 1,2 2))";
lwfree(r);
s = "GEOMETRYCOLLECTION Z (POINT Z (0 0 0))";
lwfree(r);
s = "GEOMETRYCOLLECTION M (MULTILINESTRING M ((0 0 5,2 0 5),(1 1 5,2 2 5)))";
lwfree(r);
/* See http://trac.osgeo.org/postgis/ticket/1455#comment:3 */
s = "GEOMETRYCOLLECTION Z (MULTILINESTRING Z ((0 0 5,2 0 5),(1 1 5,2 2 5)))";
lwfree(r);
@@ -271,7 +271,7 @@ static void test_wkt_in_circularstring(void)
s = "CIRCULARSTRING(0 0,0 1,1 1,0 1,2 2)";
lwfree(r);
@@ -279,13 +279,13 @@ static void test_wkt_in_compoundcurve(void)
s = "SRID=4326;COMPOUNDCURVEM(CIRCULARSTRINGM(0 0 2,1 1 2,1 0 2),(1 0 2,0 1 2))";
lwfree(r);
s = "COMPOUNDCURVE Z (CIRCULARSTRING Z (0 0 0,0 1 0,1 1 0,0 0 0,2 2 0),(2 2 0,0 0 1,1 1 1,2 2 1))";
lwfree(r);
@@ -294,7 +294,7 @@ static void test_wkt_in_curvpolygon(void)
s = "CURVEPOLYGON(COMPOUNDCURVE(CIRCULARSTRING(0 0,0 1,1 1,2 2,0 0),(0 0,1 1,2 2)),CIRCULARSTRING(0 0,0 1,1 1,0 0,2 2),(0 0,1 1,2 1))";
lwfree(r);
@@ -303,7 +303,7 @@ static void test_wkt_in_multicurve(void)
s = "SRID=4326;MULTICURVE(COMPOUNDCURVE(CIRCULARSTRING(0 0,1 1,1 0),(1 0,0 1)))";
lwfree(r);
@@ -312,7 +312,7 @@ static void test_wkt_in_multisurface(void)
lwfree(r);
@@ -321,7 +321,7 @@ static void test_wkt_in_tin(void)
s = "TIN(((0 1 2,3 4 5,6 7 8,0 1 2)),((0 1 2,3 4 5,6 7 8,9 10 11,0 1 2)))";
- CU_ASSERT_STRING_EQUAL(r,"triangle must have exactly 4 points");
+ ASSERT_STRING_EQUAL(r,"triangle must have exactly 4 points");
lwfree(r);
@@ -330,19 +330,19 @@ static void test_wkt_in_polyhedralsurface(void)
s = "POLYHEDRALSURFACE(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))";
lwfree(r);
s = "POLYHEDRALSURFACE Z (((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))";
lwfree(r);
s = "POLYHEDRALSURFACE(((0 1 2,3 4 5,6 7,0 1 2)))";
lwfree(r);
@@ -411,13 +411,13 @@ static void test_wkt_leak(void)
/* OSS-FUZZ: https://trac.osgeo.org/postgis/ticket/4537 */
char *wkt = "TINEMPTY,";
char *err = cu_wkt_in(wkt, WKT_EXTENDED);
- CU_ASSERT_STRING_EQUAL(err, "parse error - invalid geometry");
+ ASSERT_STRING_EQUAL(err, "parse error - invalid geometry");
lwfree(err);
/* OSS-FUZZ: https://trac.osgeo.org/postgis/ticket/4545 */
wkt = "GEOMeTRYCOLLECTION(POLYHEDRALSURFACEEMPTY ";
lwfree(err);
diff --git a/liblwgeom/cunit/cu_misc.c b/liblwgeom/cunit/cu_misc.c
index 3e49d5f8f..37b83de23 100644
--- a/liblwgeom/cunit/cu_misc.c
+++ b/liblwgeom/cunit/cu_misc.c
@@ -29,7 +29,7 @@ static void test_misc_simplify(void)
geom = lwgeom_from_wkt("LINESTRING(0 0,0 10,0 51,50 20,30 20,7 32)", LW_PARSER_CHECK_NONE);
geom2d = lwgeom_simplify(geom, 2, LW_FALSE);
- CU_ASSERT_STRING_EQUAL("LINESTRING(0 0,0 51,50 20,30 20,7 32)",wkt_out);
+ ASSERT_STRING_EQUAL("LINESTRING(0 0,0 51,50 20,30 20,7 32)",wkt_out);
lwgeom_free(geom);
lwfree(wkt_out);
@@ -37,7 +37,7 @@ static void test_misc_simplify(void)
geom = lwgeom_from_wkt("MULTILINESTRING((0 0,0 10,0 51,50 20,30 20,7 32))", LW_PARSER_CHECK_NONE);
- CU_ASSERT_STRING_EQUAL("MULTILINESTRING((0 0,0 51,50 20,30 20,7 32))",wkt_out);
+ ASSERT_STRING_EQUAL("MULTILINESTRING((0 0,0 51,50 20,30 20,7 32))",wkt_out);
lwgeom_free(geom);
lwfree(wkt_out);
@@ -45,7 +45,7 @@ static void test_misc_simplify(void)
geom = lwgeom_from_wkt("POLYGON((0 0,1 1,1 3,0 4,-2 3,-1 1,0 0))", LW_PARSER_CHECK_NONE);
geom2d = lwgeom_simplify(geom, 1, LW_FALSE);
- CU_ASSERT_STRING_EQUAL("POLYGON((0 0,0 4,-2 3,0 0))", wkt_out);
+ ASSERT_STRING_EQUAL("POLYGON((0 0,0 4,-2 3,0 0))", wkt_out);
lwgeom_free(geom);
lwfree(wkt_out);
@@ -129,7 +129,7 @@ static void test_misc_wkb(void)
static char *wkb = "010A0000000200000001080000000700000000000000000000C00000000000000000000000000000F0BF000000000000F0BF00000000000000000000000000000000000000000000F03F000000000000F0BF000000000000004000000000000000000000000000000000000000000000004000000000000000C00000000000000000010200000005000000000000000000F0BF00000000000000000000000000000000000000000000E03F000000000000F03F00000000000000000000000000000000000000000000F03F000000000000F0BF0000000000000000";
LWGEOM *geom = lwgeom_from_hexwkb(wkb, LW_PARSER_CHECK_ALL);
char *str = lwgeom_to_wkt(geom, WKB_ISO, 8, 0);
- CU_ASSERT_STRING_EQUAL(str, "CURVEPOLYGON(CIRCULARSTRING(-2 0,-1 -1,0 0,1 -1,2 0,0 2,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0))");
+ ASSERT_STRING_EQUAL(str, "CURVEPOLYGON(CIRCULARSTRING(-2 0,-1 -1,0 0,1 -1,2 0,0 2,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0))");
lwfree(str);
lwgeom_free(geom);
@@ -149,7 +149,7 @@ static void test_grid(void)
geomgrid = lwgeom_grid(geom, &grid);
str = lwgeom_to_ewkt(geomgrid);
- CU_ASSERT_STRING_EQUAL(str, "MULTIPOLYGON EMPTY");
+ ASSERT_STRING_EQUAL(str, "MULTIPOLYGON EMPTY");
lwfree(str);
lwgeom_free(geom);
lwgeom_free(geomgrid);
@@ -284,9 +284,9 @@ static void test_optionlist(void)
value = option_list_search(olist, "key1");
// printf("value: %s\n", value);
- CU_ASSERT_STRING_EQUAL("value1", value);
+ ASSERT_STRING_EQUAL("value1", value);
value = option_list_search(olist, "key2");
- CU_ASSERT_STRING_EQUAL("value2", value);
+ ASSERT_STRING_EQUAL("value2", value);
value = option_list_search(olist, "key3");
CU_ASSERT_EQUAL(NULL, value);
@@ -310,8 +310,8 @@ static void test_optionlist(void)
option_list_gdal_parse(input, olist);
sz = option_list_length(olist);
CU_ASSERT_EQUAL(2, sz);
- CU_ASSERT_STRING_EQUAL("key1=value1", olist[0]);
- CU_ASSERT_STRING_EQUAL("key2='value2 value3'", olist[1]);
+ ASSERT_STRING_EQUAL("key1=value1", olist[0]);
+ ASSERT_STRING_EQUAL("key2='value2 value3'", olist[1]);
@@ -325,11 +325,11 @@ static void test_stringlist(void)
stringlist_add_string_nosort(&s, "second string");
stringlist_add_string_nosort(&s, "third string");
CU_ASSERT_EQUAL(stringlist_length(&s), 3);
- CU_ASSERT_STRING_EQUAL(stringlist_get(&s, 0), "first string");
+ ASSERT_STRING_EQUAL(stringlist_get(&s, 0), "first string");
stringlist_add_string_nosort(&s, "an initial string");
stringlist_sort(&s);
- CU_ASSERT_STRING_EQUAL(stringlist_get(&s, 0), "an initial string");
- CU_ASSERT_STRING_EQUAL(stringlist_find(&s, "third string"), "third string");
+ ASSERT_STRING_EQUAL(stringlist_get(&s, 0), "an initial string");
+ ASSERT_STRING_EQUAL(stringlist_find(&s, "third string"), "third string");
CU_ASSERT_EQUAL(stringlist_find(&s, "nothing_matches"), NULL);
stringlist_add_string_nosort(&s, "fourth string");
stringlist_add_string_nosort(&s, "fifth string");
@@ -337,7 +337,7 @@ static void test_stringlist(void)
stringlist_add_string_nosort(&s, "seventh string");
stringlist_add_string_nosort(&s, "eighth string");
- CU_ASSERT_STRING_EQUAL(stringlist_find(&s, "fifth string"), "fifth string");
+ ASSERT_STRING_EQUAL(stringlist_find(&s, "fifth string"), "fifth string");
stringlist_release(&s);
diff --git a/liblwgeom/cunit/cu_node.c b/liblwgeom/cunit/cu_node.c
index 9308341ba..19dc21064 100644
--- a/liblwgeom/cunit/cu_node.c
+++ b/liblwgeom/cunit/cu_node.c
@@ -39,7 +39,7 @@ static void test_lwgeom_node(void)
out = lwgeom_node(in);
CU_ASSERT_FATAL(out != NULL);
- CU_ASSERT_STRING_EQUAL("MULTILINESTRING((0 2.5,-10 5),(0 0,0 2.5),(0 2.5,0 5),(10 0,0 2.5))", tmp)
+ ASSERT_STRING_EQUAL(tmp, "MULTILINESTRING((0 2.5,-10 5),(0 0,0 2.5),(0 2.5,0 5),(10 0,0 2.5))");
wkt = "MULTILINESTRING((0 0,5 5,10 0, 11 0, 20 0),(10 0, 12 0, 22 0))";
@@ -48,7 +48,7 @@ static void test_lwgeom_node(void)
- CU_ASSERT_STRING_EQUAL("MULTILINESTRING((0 0,5 5,10 0),(10 0,11 0,12 0,20 0),(20 0,22 0))", tmp);
+ ASSERT_STRING_EQUAL(tmp, "MULTILINESTRING((0 0,5 5,10 0),(10 0,11 0,12 0,20 0),(20 0,22 0))");
wkt = "MULTILINESTRING((0 0,5 5,10 0, 11 0, 20 0),(22 0, 12 0, 10 0),(0 5, 5 0))";
@@ -57,9 +57,9 @@ static void test_lwgeom_node(void)
-"MULTILINESTRING((0 0,2.5 2.5),(0 5,2.5 2.5),(2.5 2.5,5 5,10 0),(10 0,11 0,12 0,20 0),(20 0,22 0),(2.5 2.5,5 0))",
- tmp);
+ "MULTILINESTRING((0 0,2.5 2.5),(0 5,2.5 2.5),(2.5 2.5,5 5,10 0),(10 0,11 0,12 0,20 0),(20 0,22 0),(2.5 2.5,5 0))"
/* See https://trac.osgeo.org/postgis/ticket/5685 */
diff --git a/liblwgeom/cunit/cu_out_twkb.c b/liblwgeom/cunit/cu_out_twkb.c
index 5c2602e53..31858e2b4 100644
--- a/liblwgeom/cunit/cu_out_twkb.c
+++ b/liblwgeom/cunit/cu_out_twkb.c
@@ -89,85 +89,85 @@ static void test_twkb_out_point(void)
cu_twkb("POINT EMPTY", 0, 0, 0, 0);
- CU_ASSERT_STRING_EQUAL(s,"0110");
+ ASSERT_STRING_EQUAL(s,"0110");
cu_twkb("POINT(0 0)", 0, 0, 0, 0);
- CU_ASSERT_STRING_EQUAL(s,"01000000");
+ ASSERT_STRING_EQUAL(s,"01000000");
cu_twkb("POINT(0 0 0 0)", 0, 0, 0, 0);
- CU_ASSERT_STRING_EQUAL(s,"01080300000000");
+ ASSERT_STRING_EQUAL(s,"01080300000000");
/* Point with bounding box */
cu_twkb("POINT(0 0)", 0, 0, 0, TWKB_BBOX);
- CU_ASSERT_STRING_EQUAL(s,"0101000000000000");
+ ASSERT_STRING_EQUAL(s,"0101000000000000");
// printf("TWKB: %s\n",s);
/* Adding a size paramters to X/Y */
cu_twkb("POINT(0 0)", 0, 0, 0, TWKB_SIZE);
- CU_ASSERT_STRING_EQUAL(s,"0102020000");
+ ASSERT_STRING_EQUAL(s,"0102020000");
/* Adding a size paramters to X/Y/M */
cu_twkb("POINTM(0 0 0)", 0, 0, 0, TWKB_SIZE);
- CU_ASSERT_STRING_EQUAL(s,"010A0203000000");
+ ASSERT_STRING_EQUAL(s,"010A0203000000");
/* Adding a size paramters to X/Y/Z/M */
cu_twkb("POINT(0 0 0 0)", 0, 0, 0, TWKB_SIZE);
- CU_ASSERT_STRING_EQUAL(s,"010A030400000000");
+ ASSERT_STRING_EQUAL(s,"010A030400000000");
/* Since the third dimension is Z it shall get a precision of 1 decimal (third argument) */
cu_twkb("POINTZ(1 1 1)", 0,1,2, 0);
- CU_ASSERT_STRING_EQUAL(s,"010845020214");
+ ASSERT_STRING_EQUAL(s,"010845020214");
/* Since the third dimension is M it shall get a precision of 2 decimals (fourth argument) */
cu_twkb("POINTM(1 1 1)", 0,1,2, 0);
// printf("\n%s\n", s);
- CU_ASSERT_STRING_EQUAL(s,"0108460202C801");
+ ASSERT_STRING_EQUAL(s,"0108460202C801");
static void test_twkb_out_linestring(void)
cu_twkb("LINESTRING(0 0,1 1)", 0, 0, 0, 0);
- CU_ASSERT_STRING_EQUAL(s,"02000200000202");
+ ASSERT_STRING_EQUAL(s,"02000200000202");
cu_twkb("LINESTRING(0 0 1,1 1 2,2 2 3)", 0, 0, 0, 0);
- CU_ASSERT_STRING_EQUAL(s,"02080103000002020202020202");
+ ASSERT_STRING_EQUAL(s,"02080103000002020202020202");
/* Line with bounding box */
cu_twkb("LINESTRING(0 0,1 1,2 2)", 0, 0, 0, TWKB_BBOX);
- CU_ASSERT_STRING_EQUAL(s,"02010004000403000002020202");
+ ASSERT_STRING_EQUAL(s,"02010004000403000002020202");
cu_twkb("LINESTRING EMPTY", 0, 0, 0, 0);
- CU_ASSERT_STRING_EQUAL(s,"0210");
+ ASSERT_STRING_EQUAL(s,"0210");
static void test_twkb_out_polygon(void)
cu_twkb("SRID=4;POLYGON((0 0 0, 0 1 0,1 1 0,1 0 0, 0 0 0))", 0, 0, 0, 0);
- CU_ASSERT_STRING_EQUAL(s,"0308010105000000000200020000000100010000");
+ ASSERT_STRING_EQUAL(s,"0308010105000000000200020000000100010000");
cu_twkb("SRID=14;POLYGON((0 0 0 1, 0 1 0 2,1 1 0 3,1 0 0 4, 0 0 0 5))", 0, 0, 0, 0);
- CU_ASSERT_STRING_EQUAL(s,"03080301050000000200020002020000020001000201000002");
+ ASSERT_STRING_EQUAL(s,"03080301050000000200020002020000020001000201000002");
cu_twkb("POLYGON EMPTY", 0, 0, 0, 0);
- CU_ASSERT_STRING_EQUAL(s,"0310");
+ ASSERT_STRING_EQUAL(s,"0310");
static void test_twkb_out_multipoint(void)
cu_twkb("MULTIPOINT(0 0 0, 0 1 0,1 1 0,1 0 0, 0 0 0)", 0, 0, 0, 0);
- CU_ASSERT_STRING_EQUAL(s,"04080105000000000200020000000100010000");
+ ASSERT_STRING_EQUAL(s,"04080105000000000200020000000100010000");
cu_twkb("MULTIPOINT(0 0 0, 0.26794919243112270647255365849413 1 3)",7 ,7 , 0, 0);
//printf("WKB: %s",s);
- CU_ASSERT_STRING_EQUAL(s,"E4081D02000000888BC70280DAC409808ECE1C");
+ ASSERT_STRING_EQUAL(s,"E4081D02000000888BC70280DAC409808ECE1C");
@@ -176,21 +176,21 @@ static void test_twkb_out_multilinestring(void) {}
static void test_twkb_out_multipolygon(void)
cu_twkb("MULTIPOLYGON(((0 0 0, 0 1 0,1 1 0,1 0 0, 0 0 0)),((-1 -1 0,-1 2 0,2 2 0,2 -1 0,-1 -1 0),(0 0 0, 0 1 0,1 1 0,1 0 0, 0 0 0)))", 0, 0, 0, 0);
- CU_ASSERT_STRING_EQUAL(s,"060801020105000000000200020000000100010000020501010000060006000000050005000005020200000200020000000100010000");
+ ASSERT_STRING_EQUAL(s,"060801020105000000000200020000000100010000020501010000060006000000050005000005020200000200020000000100010000");
static void test_twkb_out_collection(void)
cu_twkb("GEOMETRYCOLLECTION(LINESTRING(1 1, 2 2), LINESTRING(3 3, 4 4), LINESTRING(5 5, 6 6))", 0, 0, 0, 0);
- CU_ASSERT_STRING_EQUAL(s,"07000302000202020202020002060602020200020A0A0202");
+ ASSERT_STRING_EQUAL(s,"07000302000202020202020002060602020200020A0A0202");
cu_twkb("GEOMETRYCOLLECTION(POLYGON((0 0 0, 0 1 0,1 1 0,1 0 0, 0 0 0)),POINT(1 1 1))", 0, 0, 0, 0);
- CU_ASSERT_STRING_EQUAL(s,"070801020308010105000000000200020000000100010000010801020202");
+ ASSERT_STRING_EQUAL(s,"070801020308010105000000000200020000000100010000010801020202");
cu_twkb("GEOMETRYCOLLECTION EMPTY", 0, 0, 0, 0);
- CU_ASSERT_STRING_EQUAL(s,"0710");
+ ASSERT_STRING_EQUAL(s,"0710");
static void test_twkb_out_idlist(void)
@@ -202,8 +202,8 @@ static void test_twkb_out_idlist(void)
cu_twkb_idlist("MULTIPOINT(1 1, 0 0)",idlist, 0, 0, 0, 0);
// printf("WKT: %s\n",w);
- CU_ASSERT_STRING_EQUAL(s,"040402040802020101");
- CU_ASSERT_STRING_EQUAL(w,"MULTIPOINT(1 1,0 0)");
+ ASSERT_STRING_EQUAL(s,"040402040802020101");
+ ASSERT_STRING_EQUAL(w,"MULTIPOINT(1 1,0 0)");
04 06 multipoint, size/idlist
@@ -218,8 +218,8 @@ static void test_twkb_out_idlist(void)
cu_twkb_idlist("MULTIPOINT(1 1, 0 0)",idlist, 0, 0, 0, TWKB_SIZE);
- CU_ASSERT_STRING_EQUAL(s,"04060702040802020101");
+ ASSERT_STRING_EQUAL(s,"04060702040802020101");
04 07 multipoint, bbox/size/idlist
@@ -235,8 +235,8 @@ static void test_twkb_out_idlist(void)
cu_twkb_idlist("MULTIPOINT(1 1, 0 0)",idlist, 0, 0, 0, TWKB_SIZE | TWKB_BBOX);
- CU_ASSERT_STRING_EQUAL(s,"04070B0002000202040802020101");
+ ASSERT_STRING_EQUAL(s,"04070B0002000202040802020101");
0704 geometrycollection, idlist
@@ -249,8 +249,8 @@ static void test_twkb_out_idlist(void)
idlist[1] = 4;
cu_twkb_idlist("GEOMETRYCOLLECTION(POINT(1 1),POINT(0 0))",idlist, 0, 0, 0, 0);
- CU_ASSERT_STRING_EQUAL(s,"07040204080100020201000000");
- CU_ASSERT_STRING_EQUAL(w,"GEOMETRYCOLLECTION(POINT(1 1),POINT(0 0))");
+ ASSERT_STRING_EQUAL(s,"07040204080100020201000000");
+ ASSERT_STRING_EQUAL(w,"GEOMETRYCOLLECTION(POINT(1 1),POINT(0 0))");
0706 geometrycollection, size/idlist
@@ -264,8 +264,8 @@ static void test_twkb_out_idlist(void)
idlist[1] = 4;
cu_twkb_idlist("GEOMETRYCOLLECTION(POINT(1 1),POINT(0 0))",idlist, 0, 0, 0, TWKB_SIZE);
- CU_ASSERT_STRING_EQUAL(s,"07060D02040801020202020102020000");
+ ASSERT_STRING_EQUAL(s,"07060D02040801020202020102020000");
diff --git a/liblwgeom/cunit/cu_out_wkb.c b/liblwgeom/cunit/cu_out_wkb.c
index 236c53aff..1232fde61 100644
--- a/liblwgeom/cunit/cu_out_wkb.c
+++ b/liblwgeom/cunit/cu_out_wkb.c
@@ -78,10 +78,10 @@ static void cu_wkb_empty_point_check(char *hex)
static void test_wkb_out_point(void)
cu_wkb("POINT(0 0 0 0)");
- CU_ASSERT_STRING_EQUAL(s,"00C00000010000000000000000000000000000000000000000000000000000000000000000");
+ ASSERT_STRING_EQUAL(s,"00C00000010000000000000000000000000000000000000000000000000000000000000000");
cu_wkb("SRID=4;POINTM(1 1 1)");
- CU_ASSERT_STRING_EQUAL(s,"0060000001000000043FF00000000000003FF00000000000003FF0000000000000");
+ ASSERT_STRING_EQUAL(s,"0060000001000000043FF00000000000003FF00000000000003FF0000000000000");
cu_wkb("POINT EMPTY");
cu_wkb_empty_point_check(s);
@@ -102,47 +102,47 @@ static void test_wkb_out_point(void)
static void test_wkb_out_linestring(void)
cu_wkb("LINESTRING(0 0,1 1)");
- CU_ASSERT_STRING_EQUAL(s,"000000000200000002000000000000000000000000000000003FF00000000000003FF0000000000000");
+ ASSERT_STRING_EQUAL(s,"000000000200000002000000000000000000000000000000003FF00000000000003FF0000000000000");
cu_wkb("LINESTRING(0 0 1,1 1 2,2 2 3)");
- CU_ASSERT_STRING_EQUAL(s,"008000000200000003000000000000000000000000000000003FF00000000000003FF00000000000003FF00000000000004000000000000000400000000000000040000000000000004008000000000000");
+ ASSERT_STRING_EQUAL(s,"008000000200000003000000000000000000000000000000003FF00000000000003FF00000000000003FF00000000000004000000000000000400000000000000040000000000000004008000000000000");
cu_wkb("LINESTRING EMPTY");
- CU_ASSERT_STRING_EQUAL(s,"000000000200000000");
+ ASSERT_STRING_EQUAL(s,"000000000200000000");
static void test_wkb_out_polygon(void)
cu_wkb("SRID=4;POLYGON((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0))");
- CU_ASSERT_STRING_EQUAL(s,"00A000000300000004000000010000000500000000000000000000000000000000000000000000000000000000000000003FF000000000000000000000000000003FF00000000000003FF000000000000000000000000000003FF000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000");
+ ASSERT_STRING_EQUAL(s,"00A000000300000004000000010000000500000000000000000000000000000000000000000000000000000000000000003FF000000000000000000000000000003FF00000000000003FF000000000000000000000000000003FF000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000");
cu_wkb("SRID=14;POLYGON((0 0 0 1,0 1 0 2,1 1 0 3,1 0 0 4,0 0 0 5))");
- CU_ASSERT_STRING_EQUAL(s,"00E00000030000000E00000001000000050000000000000000000000000000000000000000000000003FF000000000000000000000000000003FF0000000000000000000000000000040000000000000003FF00000000000003FF0000000000000000000000000000040080000000000003FF00000000000000000000000000000000000000000000040100000000000000000000000000000000000000000000000000000000000004014000000000000");
+ ASSERT_STRING_EQUAL(s,"00E00000030000000E00000001000000050000000000000000000000000000000000000000000000003FF000000000000000000000000000003FF0000000000000000000000000000040000000000000003FF00000000000003FF0000000000000000000000000000040080000000000003FF00000000000000000000000000000000000000000000040100000000000000000000000000000000000000000000000000000000000004014000000000000");
cu_wkb("SRID=4;POLYGON((0 0 0 1,0 1 0 2,1 1 0 3,1 0 0 4,0 0 0 5))");
- CU_ASSERT_STRING_EQUAL(s,"00E00000030000000400000001000000050000000000000000000000000000000000000000000000003FF000000000000000000000000000003FF0000000000000000000000000000040000000000000003FF00000000000003FF0000000000000000000000000000040080000000000003FF00000000000000000000000000000000000000000000040100000000000000000000000000000000000000000000000000000000000004014000000000000");
+ ASSERT_STRING_EQUAL(s,"00E00000030000000400000001000000050000000000000000000000000000000000000000000000003FF000000000000000000000000000003FF0000000000000000000000000000040000000000000003FF00000000000003FF0000000000000000000000000000040080000000000003FF00000000000000000000000000000000000000000000040100000000000000000000000000000000000000000000000000000000000004014000000000000");
cu_wkb("POLYGON EMPTY");
- CU_ASSERT_STRING_EQUAL(s,"000000000300000000");
+ ASSERT_STRING_EQUAL(s,"000000000300000000");
* POLYGON with EMPTY shell
* See http://http://trac.osgeo.org/postgis/ticket/937
cu_wkb_from_hexwkb("01030000000100000000000000");
static void test_wkb_out_multipoint(void)
cu_wkb("SRID=4;MULTIPOINT(0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)");
- CU_ASSERT_STRING_EQUAL(s,"00A000000400000004000000050080000001000000000000000000000000000000000000000000000000008000000100000000000000003FF0000000000000000000000000000000800000013FF00000000000003FF0000000000000000000000000000000800000013FF0000000000000000000000000000000000000000000000080000001000000000000000000000000000000000000000000000000");
+ ASSERT_STRING_EQUAL(s,"00A000000400000004000000050080000001000000000000000000000000000000000000000000000000008000000100000000000000003FF0000000000000000000000000000000800000013FF00000000000003FF0000000000000000000000000000000800000013FF0000000000000000000000000000000000000000000000080000001000000000000000000000000000000000000000000000000");
cu_wkb("MULTIPOINT(0 0 0, 0.26794919243112270647255365849413 1 3)");
- CU_ASSERT_STRING_EQUAL(s,"008000000400000002008000000100000000000000000000000000000000000000000000000000800000013FD126145E9ECD563FF00000000000004008000000000000");
+ ASSERT_STRING_EQUAL(s,"008000000400000002008000000100000000000000000000000000000000000000000000000000800000013FD126145E9ECD563FF00000000000004008000000000000");
cu_wkb("MULTIPOINT EMPTY");
- CU_ASSERT_STRING_EQUAL(s,"000000000400000000");
+ ASSERT_STRING_EQUAL(s,"000000000400000000");
static void test_wkb_out_multilinestring(void) {}
@@ -150,50 +150,50 @@ static void test_wkb_out_multilinestring(void) {}
static void test_wkb_out_multipolygon(void)
cu_wkb("SRID=14;MULTIPOLYGON(((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)),((-1 -1 0,-1 2 0,2 2 0,2 -1 0,-1 -1 0),(0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)))");
- CU_ASSERT_STRING_EQUAL(s,"00A00000060000000E000000020080000003000000010000000500000000000000000000000000000000000000000000000000000000000000003FF000000000000000000000000000003FF00000000000003FF000000000000000000000000000003FF00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000800000030000000200000005BFF0000000000000BFF00000000000000000000000000000BFF0000000000000400000000000000000000000000000004000000000000000400000000000000000000000000000004000000000000000BFF00000000000000000000000000000BFF0000000000000BFF000000000000000000000000000000000000500000000000000000000000000000000000000000000000000000000000000003FF000000000000000000000000000003FF00000000000003FF000000000000000000000000000003FF000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000");
+ ASSERT_STRING_EQUAL(s,"00A00000060000000E000000020080000003000000010000000500000000000000000000000000000000000000000000000000000000000000003FF000000000000000000000000000003FF00000000000003FF000000000000000000000000000003FF00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000800000030000000200000005BFF0000000000000BFF00000000000000000000000000000BFF0000000000000400000000000000000000000000000004000000000000000400000000000000000000000000000004000000000000000BFF00000000000000000000000000000BFF0000000000000BFF000000000000000000000000000000000000500000000000000000000000000000000000000000000000000000000000000003FF000000000000000000000000000003FF00000000000003FF000000000000000000000000000003FF000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000");
cu_wkb("MULTIPOLYGON EMPTY");
- CU_ASSERT_STRING_EQUAL(s,"000000000600000000");
+ ASSERT_STRING_EQUAL(s,"000000000600000000");
static void test_wkb_out_collection(void)
cu_wkb("SRID=14;GEOMETRYCOLLECTION(POLYGON((0 0 0,0 1 0,1 1 0,1 0 0,0 0 0)),POINT(1 1 1))");
- CU_ASSERT_STRING_EQUAL(s,"00A00000070000000E000000020080000003000000010000000500000000000000000000000000000000000000000000000000000000000000003FF000000000000000000000000000003FF00000000000003FF000000000000000000000000000003FF00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000800000013FF00000000000003FF00000000000003FF0000000000000");
+ ASSERT_STRING_EQUAL(s,"00A00000070000000E000000020080000003000000010000000500000000000000000000000000000000000000000000000000000000000000003FF000000000000000000000000000003FF00000000000003FF000000000000000000000000000003FF00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000800000013FF00000000000003FF00000000000003FF0000000000000");
cu_wkb("GEOMETRYCOLLECTION EMPTY");
- CU_ASSERT_STRING_EQUAL(s,"000000000700000000");
+ ASSERT_STRING_EQUAL(s,"000000000700000000");
cu_wkb("GEOMETRYCOLLECTION(LINESTRING EMPTY)");
- CU_ASSERT_STRING_EQUAL(s,"000000000700000001000000000200000000");
+ ASSERT_STRING_EQUAL(s,"000000000700000001000000000200000000");
cu_wkb("GEOMETRYCOLLECTION(LINESTRING EMPTY, MULTILINESTRING(EMPTY,EMPTY))");
// printf("%s\n",s );
- CU_ASSERT_STRING_EQUAL(s,"000000000700000002000000000200000000000000000500000002000000000200000000000000000200000000");
+ ASSERT_STRING_EQUAL(s,"000000000700000002000000000200000000000000000500000002000000000200000000000000000200000000");
static void test_wkb_out_circularstring(void)
cu_wkb("CIRCULARSTRING(0 -2,-2 0,0 2,2 0,0 -2)");
- CU_ASSERT_STRING_EQUAL(s,"0000000008000000050000000000000000C000000000000000C000000000000000000000000000000000000000000000004000000000000000400000000000000000000000000000000000000000000000C000000000000000");
+ ASSERT_STRING_EQUAL(s,"0000000008000000050000000000000000C000000000000000C000000000000000000000000000000000000000000000004000000000000000400000000000000000000000000000000000000000000000C000000000000000");
cu_wkb("CIRCULARSTRING(-5 0 0 4, 0 5 1 3, 5 0 2 2, 10 -5 3 1, 15 0 4 0)");
- CU_ASSERT_STRING_EQUAL(s,"00C000000800000005C014000000000000000000000000000000000000000000004010000000000000000000000000000040140000000000003FF0000000000000400800000000000040140000000000000000000000000000400000000000000040000000000000004024000000000000C01400000000000040080000000000003FF0000000000000402E000000000000000000000000000040100000000000000000000000000000");
+ ASSERT_STRING_EQUAL(s,"00C000000800000005C014000000000000000000000000000000000000000000004010000000000000000000000000000040140000000000003FF0000000000000400800000000000040140000000000000000000000000000400000000000000040000000000000004024000000000000C01400000000000040080000000000003FF0000000000000402E000000000000000000000000000040100000000000000000000000000000");
cu_wkb("SRID=43;CIRCULARSTRING(-5 0 0 4, 0 5 1 3, 5 0 2 2, 10 -5 3 1, 15 0 4 0)");
- CU_ASSERT_STRING_EQUAL(s,"00E00000080000002B00000005C014000000000000000000000000000000000000000000004010000000000000000000000000000040140000000000003FF0000000000000400800000000000040140000000000000000000000000000400000000000000040000000000000004024000000000000C01400000000000040080000000000003FF0000000000000402E000000000000000000000000000040100000000000000000000000000000");
+ ASSERT_STRING_EQUAL(s,"00E00000080000002B00000005C014000000000000000000000000000000000000000000004010000000000000000000000000000040140000000000003FF0000000000000400800000000000040140000000000000000000000000000400000000000000040000000000000004024000000000000C01400000000000040080000000000003FF0000000000000402E000000000000000000000000000040100000000000000000000000000000");
static void test_wkb_out_compoundcurve(void)
cu_wkb("COMPOUNDCURVE(CIRCULARSTRING(0 0 0, 0.26794919243112270647255365849413 1 3, 0.5857864376269049511983112757903 1.4142135623730950488016887242097 1),(0.5857864376269049511983112757903 1.4142135623730950488016887242097 1,2 0 0,0 0 0))");
- CU_ASSERT_STRING_EQUAL(s,"0080000009000000020080000008000000030000000000000000000000000000000000000000000000003FD126145E9ECD563FF000000000000040080000000000003FE2BEC3330188673FF6A09E667F3BCD3FF00000000000000080000002000000033FE2BEC3330188673FF6A09E667F3BCD3FF0000000000000400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000");
+ ASSERT_STRING_EQUAL(s,"0080000009000000020080000008000000030000000000000000000000000000000000000000000000003FD126145E9ECD563FF000000000000040080000000000003FE2BEC3330188673FF6A09E667F3BCD3FF00000000000000080000002000000033FE2BEC3330188673FF6A09E667F3BCD3FF0000000000000400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000");
static void test_wkb_out_curvpolygon(void)
cu_wkb("CURVEPOLYGON(CIRCULARSTRING(-2 0 0 0,-1 -1 1 2,0 0 2 4,1 -1 3 6,2 0 4 8,0 2 2 4,-2 0 0 0),(-1 0 1 2,0 0.5 2 4,1 0 3 6,0 1 3 4,-1 0 1 2))");
- CU_ASSERT_STRING_EQUAL(s,"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");
+ ASSERT_STRING_EQUAL(s,"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");
static void test_wkb_out_multicurve(void) {}
@@ -203,7 +203,7 @@ static void test_wkb_out_multisurface(void) {}
static void test_wkb_out_polyhedralsurface(void)
// cu_wkb("POLYHEDRALSURFACE(((0 0 0 0,0 0 1 0,0 1 0 2,0 0 0 0)),((0 0 0 0,0 1 0 0,1 0 0 4,0 0 0 0)),((0 0 0 0,1 0 0 0,0 0 1 6,0 0 0 0)),((1 0 0 0,0 1 0 0,0 0 1 0,1 0 0 0)))");
-// CU_ASSERT_STRING_EQUAL(s, t);
+// ASSERT_STRING_EQUAL(s, t);
// printf("\nnew: %s\nold: %s\n",s,t);
diff --git a/liblwgeom/cunit/cu_out_wkt.c b/liblwgeom/cunit/cu_out_wkt.c
index 5dd4bc574..39c61f32a 100644
--- a/liblwgeom/cunit/cu_out_wkt.c
+++ b/liblwgeom/cunit/cu_out_wkt.c
@@ -59,24 +59,24 @@ static char* cu_wkt(char *wkt, uint8_t variant)
static void test_wkt_out_point(void)
- CU_ASSERT_STRING_EQUAL(cu_wkt("POINT(0.1111 0.1111 0.1111 0)",WKT_ISO), "POINT ZM (0.1111 0.1111 0.1111 0)");
- CU_ASSERT_STRING_EQUAL(cu_wkt("POINT(0 0 0 0)",WKT_EXTENDED), "POINT(0 0 0 0)");
- CU_ASSERT_STRING_EQUAL(cu_wkt("POINT(0 0 0 0)",WKT_SFSQL), "POINT(0 0)");
+ ASSERT_STRING_EQUAL(cu_wkt("POINT(0.1111 0.1111 0.1111 0)",WKT_ISO), "POINT ZM (0.1111 0.1111 0.1111 0)");
+ ASSERT_STRING_EQUAL(cu_wkt("POINT(0 0 0 0)",WKT_EXTENDED), "POINT(0 0 0 0)");
+ ASSERT_STRING_EQUAL(cu_wkt("POINT(0 0 0 0)",WKT_SFSQL), "POINT(0 0)");
- CU_ASSERT_STRING_EQUAL(cu_wkt("POINTM(0 0 0)",WKT_ISO), "POINT M (0 0 0)");
- CU_ASSERT_STRING_EQUAL(cu_wkt("POINTM(0 0 0)",WKT_EXTENDED), "POINTM(0 0 0)");
- CU_ASSERT_STRING_EQUAL(cu_wkt("POINTM(0 0 0)",WKT_SFSQL), "POINT(0 0)");
+ ASSERT_STRING_EQUAL(cu_wkt("POINTM(0 0 0)",WKT_ISO), "POINT M (0 0 0)");
+ ASSERT_STRING_EQUAL(cu_wkt("POINTM(0 0 0)",WKT_EXTENDED), "POINTM(0 0 0)");
+ ASSERT_STRING_EQUAL(cu_wkt("POINTM(0 0 0)",WKT_SFSQL), "POINT(0 0)");
- CU_ASSERT_STRING_EQUAL(cu_wkt("POINT(100 100)",WKT_ISO), "POINT(100 100)");
- CU_ASSERT_STRING_EQUAL(cu_wkt("POINT(100 100)",WKT_EXTENDED), "POINT(100 100)");
- CU_ASSERT_STRING_EQUAL(cu_wkt("POINT(100 100)",WKT_SFSQL), "POINT(100 100)");
+ ASSERT_STRING_EQUAL(cu_wkt("POINT(100 100)",WKT_ISO), "POINT(100 100)");
+ ASSERT_STRING_EQUAL(cu_wkt("POINT(100 100)",WKT_EXTENDED), "POINT(100 100)");
+ ASSERT_STRING_EQUAL(cu_wkt("POINT(100 100)",WKT_SFSQL), "POINT(100 100)");
- CU_ASSERT_STRING_EQUAL(cu_wkt("POINT(100.1 100 12 12)",WKT_ISO), "POINT ZM (100.1 100 12 12)");
- CU_ASSERT_STRING_EQUAL(cu_wkt("POINT(100.1 100 12 12)",WKT_EXTENDED), "POINT(100.1 100 12 12)");
- CU_ASSERT_STRING_EQUAL(cu_wkt("POINT(100.1 100 12 12)",WKT_SFSQL), "POINT(100.1 100)");
+ ASSERT_STRING_EQUAL(cu_wkt("POINT(100.1 100 12 12)",WKT_ISO), "POINT ZM (100.1 100 12 12)");
+ ASSERT_STRING_EQUAL(cu_wkt("POINT(100.1 100 12 12)",WKT_EXTENDED), "POINT(100.1 100 12 12)");
+ ASSERT_STRING_EQUAL(cu_wkt("POINT(100.1 100 12 12)",WKT_SFSQL), "POINT(100.1 100)");
- CU_ASSERT_STRING_EQUAL(cu_wkt("SRID=100;POINT(100.1 100 12 12)",WKT_SFSQL), "POINT(100.1 100)");
- CU_ASSERT_STRING_EQUAL(cu_wkt("SRID=100;POINT(100.1 100 12 12)",WKT_EXTENDED), "SRID=100;POINT(100.1 100 12 12)");
+ ASSERT_STRING_EQUAL(cu_wkt("SRID=100;POINT(100.1 100 12 12)",WKT_SFSQL), "POINT(100.1 100)");
+ ASSERT_STRING_EQUAL(cu_wkt("SRID=100;POINT(100.1 100 12 12)",WKT_EXTENDED), "SRID=100;POINT(100.1 100 12 12)");
/* Test big numbers */
ASSERT_STRING_EQUAL(cu_wkt("POINT(-123456789012345.12345678 -1234567890123458.12345678)", WKT_ISO),
@@ -92,41 +92,41 @@ static void test_wkt_out_point(void)
static void test_wkt_out_linestring(void)
- CU_ASSERT_STRING_EQUAL(cu_wkt("LINESTRING(1 2 3 4,5 6 7 8)",WKT_ISO), "LINESTRING ZM (1 2 3 4,5 6 7 8)");
- CU_ASSERT_STRING_EQUAL(cu_wkt("LINESTRING(1 2 3,5 6 7)",WKT_ISO), "LINESTRING Z (1 2 3,5 6 7)");
- CU_ASSERT_STRING_EQUAL(cu_wkt("LINESTRINGM(1 2 3,5 6 7)",WKT_ISO), "LINESTRING M (1 2 3,5 6 7)");
+ ASSERT_STRING_EQUAL(cu_wkt("LINESTRING(1 2 3 4,5 6 7 8)",WKT_ISO), "LINESTRING ZM (1 2 3 4,5 6 7 8)");
+ ASSERT_STRING_EQUAL(cu_wkt("LINESTRING(1 2 3,5 6 7)",WKT_ISO), "LINESTRING Z (1 2 3,5 6 7)");
+ ASSERT_STRING_EQUAL(cu_wkt("LINESTRINGM(1 2 3,5 6 7)",WKT_ISO), "LINESTRING M (1 2 3,5 6 7)");
static void test_wkt_out_polygon(void)
cu_wkt("POLYGON((100 100 2, 100 200 2, 200 200 2, 200 100 2, 100 100 2))",WKT_ISO),
"POLYGON Z ((100 100 2,100 200 2,200 200 2,200 100 2,100 100 2))"
cu_wkt("POLYGON((100 100 2, 100 200 2, 200 200 2, 200 100 2, 100 100 2))",WKT_EXTENDED),
"POLYGON((100 100 2,100 200 2,200 200 2,200 100 2,100 100 2))"
static void test_wkt_out_multipoint(void)
- CU_ASSERT_STRING_EQUAL(cu_wkt("MULTIPOINT(1 2 3 4,5 6 7 8)",WKT_ISO), "MULTIPOINT ZM ((1 2 3 4),(5 6 7 8))");
- CU_ASSERT_STRING_EQUAL(cu_wkt("MULTIPOINT(1 2 3,5 6 7)",WKT_ISO), "MULTIPOINT Z ((1 2 3),(5 6 7))");
- CU_ASSERT_STRING_EQUAL(cu_wkt("MULTIPOINTM(1 2 3,5 6 7)",WKT_ISO), "MULTIPOINT M ((1 2 3),(5 6 7))");
+ ASSERT_STRING_EQUAL(cu_wkt("MULTIPOINT(1 2 3 4,5 6 7 8)",WKT_ISO), "MULTIPOINT ZM ((1 2 3 4),(5 6 7 8))");
+ ASSERT_STRING_EQUAL(cu_wkt("MULTIPOINT(1 2 3,5 6 7)",WKT_ISO), "MULTIPOINT Z ((1 2 3),(5 6 7))");
+ ASSERT_STRING_EQUAL(cu_wkt("MULTIPOINTM(1 2 3,5 6 7)",WKT_ISO), "MULTIPOINT M ((1 2 3),(5 6 7))");
static void test_wkt_out_multilinestring(void)
cu_wkt("MULTILINESTRING((1 2 3 4,5 6 7 8))",WKT_ISO),
"MULTILINESTRING ZM ((1 2 3 4,5 6 7 8))"
cu_wkt("MULTILINESTRING((1 2 3,5 6 7))",WKT_ISO),
"MULTILINESTRING Z ((1 2 3,5 6 7))"
cu_wkt("MULTILINESTRINGM((1 2 3,5 6 7))",WKT_ISO),
"MULTILINESTRING M ((1 2 3,5 6 7))"
@@ -134,11 +134,11 @@ static void test_wkt_out_multilinestring(void)
static void test_wkt_out_multipolygon(void)
cu_wkt("MULTIPOLYGON(((100 100 2, 100 200 2, 200 200 2, 200 100 2, 100 100 2)))",WKT_ISO),
"MULTIPOLYGON Z (((100 100 2,100 200 2,200 200 2,200 100 2,100 100 2)))"
cu_wkt("MULTIPOLYGON(((100 100 2, 100 200 2, 200 200 2, 200 100 2, 100 100 2)))",WKT_EXTENDED),
"MULTIPOLYGON(((100 100 2,100 200 2,200 200 2,200 100 2,100 100 2)))"
@@ -147,17 +147,17 @@ static void test_wkt_out_multipolygon(void)
static void test_wkt_out_collection(void)
//printf("%s\n",cu_wkt("GEOMETRYCOLLECTION(MULTIPOLYGON(((100 100 2, 100 200 2, 200 200 2, 200 100 2, 100 100 2))),MULTIPOINT(.5 .5 .5,1 1 1),CURVEPOLYGON((.8 .8 .8,.8 .8 .8,.8 .8 .8)))",WKT_ISO));
cu_wkt("GEOMETRYCOLLECTION(POLYGON((100 100 2, 100 200 2, 200 200 2, 200 100 2, 100 100 2)),POINT(.5 .5 .5),CIRCULARSTRING(.8 .8 .8,.8 .8 .8,.8 .8 .8))",WKT_ISO),
"GEOMETRYCOLLECTION Z (POLYGON Z ((100 100 2,100 200 2,200 200 2,200 100 2,100 100 2)),POINT Z (0.5 0.5 0.5),CIRCULARSTRING Z (0.8 0.8 0.8,0.8 0.8 0.8,0.8 0.8 0.8))"
cu_wkt("GEOMETRYCOLLECTION(MULTIPOLYGON(((100 100 2, 100 200 2, 200 200 2, 200 100 2, 100 100 2))),MULTIPOINT(.5 .5 .5,1 1 1),CURVEPOLYGON((.8 .8 .8,.8 .8 .8,.8 .8 .8)))",WKT_ISO),
"GEOMETRYCOLLECTION Z (MULTIPOLYGON Z (((100 100 2,100 200 2,200 200 2,200 100 2,100 100 2))),MULTIPOINT Z ((0.5 0.5 0.5),(1 1 1)),CURVEPOLYGON Z ((0.8 0.8 0.8,0.8 0.8 0.8,0.8 0.8 0.8)))"
/* See http://trac.osgeo.org/postgis/ticket/724 */
cu_wkt("GEOMETRYCOLLECTIONM(MULTIPOINTM(0 0 0), POINTM(1 1 1))", WKT_EXTENDED),
"GEOMETRYCOLLECTIONM(MULTIPOINTM(0 0 0),POINTM(1 1 1))"
@@ -165,11 +165,11 @@ static void test_wkt_out_collection(void)
static void test_wkt_out_circularstring(void)
cu_wkt("CIRCULARSTRING(1 2 3 4,4 5 6 7,7 8 9 0)",WKT_ISO),
"CIRCULARSTRING ZM (1 2 3 4,4 5 6 7,7 8 9 0)"
cu_wkt("CIRCULARSTRING(1 2 3 4,4 5 6 7,7 8 9 0)",WKT_EXTENDED),
@@ -178,7 +178,7 @@ static void test_wkt_out_circularstring(void)
static void test_wkt_out_compoundcurve(void)
cu_wkt("COMPOUNDCURVE((1 2 3 4,4 5 6 7,7 8 9 0),CIRCULARSTRING(7 8 9 0,4 3 2 1,1 2 3 4,4 5 6 7,7 8 9 0))",WKT_ISO),
"COMPOUNDCURVE ZM ((1 2 3 4,4 5 6 7,7 8 9 0),CIRCULARSTRING ZM (7 8 9 0,4 3 2 1,1 2 3 4,4 5 6 7,7 8 9 0))"
@@ -186,7 +186,7 @@ static void test_wkt_out_compoundcurve(void)
static void test_wkt_out_curvpolygon(void)
cu_wkt("CURVEPOLYGON((1 2 3 4,4 5 6 7,7 8 9 0),CIRCULARSTRING(7 8 9 0,1 2 1 1,1 2 3 4,4 5 6 7,7 8 9 0))",WKT_ISO),
"CURVEPOLYGON ZM ((1 2 3 4,4 5 6 7,7 8 9 0),CIRCULARSTRING ZM (7 8 9 0,1 2 1 1,1 2 3 4,4 5 6 7,7 8 9 0))"
@@ -194,11 +194,11 @@ static void test_wkt_out_curvpolygon(void)
static void test_wkt_out_multicurve(void)
cu_wkt("MULTICURVE((1 2 3 4,4 5 6 7,7 8 9 0),CIRCULARSTRING(1 2 3 4,4 5 6 7,7 8 9 0))",WKT_ISO),
"MULTICURVE ZM ((1 2 3 4,4 5 6 7,7 8 9 0),CIRCULARSTRING ZM (1 2 3 4,4 5 6 7,7 8 9 0))"
cu_wkt("MULTICURVE(COMPOUNDCURVE((1 2 3 4,4 5 6 7,7 8 9 0),CIRCULARSTRING(7 8 9 0,8 9 0 0,1 2 3 4,4 5 6 7,7 8 9 0)),(1 2 3 4,4 5 6 7,7 8 9 0),CIRCULARSTRING(1 2 3 4,4 5 6 7,7 8 9 0))",WKT_ISO),
"MULTICURVE ZM (COMPOUNDCURVE ZM ((1 2 3 4,4 5 6 7,7 8 9 0),CIRCULARSTRING ZM (7 8 9 0,8 9 0 0,1 2 3 4,4 5 6 7,7 8 9 0)),(1 2 3 4,4 5 6 7,7 8 9 0),CIRCULARSTRING ZM (1 2 3 4,4 5 6 7,7 8 9 0))"
@@ -206,7 +206,7 @@ static void test_wkt_out_multicurve(void)
static void test_wkt_out_multisurface(void)
cu_wkt("MULTISURFACE(((1 2 3 4,4 5 6 7,7 8 9 0)),CURVEPOLYGON((1 2 3 4,4 5 6 7,7 8 9 0)))",WKT_ISO),
"MULTISURFACE ZM (((1 2 3 4,4 5 6 7,7 8 9 0)),CURVEPOLYGON ZM ((1 2 3 4,4 5 6 7,7 8 9 0)))"
diff --git a/liblwgeom/cunit/cu_print.c b/liblwgeom/cunit/cu_print.c
index 7274b6109..6b9da1805 100644
--- a/liblwgeom/cunit/cu_print.c
+++ b/liblwgeom/cunit/cu_print.c
@@ -31,7 +31,7 @@ test_lwpoint_to_latlon_assert_format(char *point_wkt, const char *format, const
CU_FAIL();
num_old_failures = CU_get_number_of_failures();
- CU_ASSERT_STRING_EQUAL(actual, expected);
+ ASSERT_STRING_EQUAL(actual, expected);
num_new_failures = CU_get_number_of_failures();
if (num_new_failures > num_old_failures)
diff --git a/liblwgeom/cunit/cu_sfcgal.c b/liblwgeom/cunit/cu_sfcgal.c
index 0cba17319..f226b0ea9 100644
--- a/liblwgeom/cunit/cu_sfcgal.c
+++ b/liblwgeom/cunit/cu_sfcgal.c
@@ -80,7 +80,7 @@ test_sfcgal_noop(void)
out_ewkt = lwgeom_to_ewkt(geom_out);
if (strcmp(expected_ewkt[i], out_ewkt))
fprintf(stderr, "\nExp: %s\nObt: %s\n", expected_ewkt[i], out_ewkt);
- CU_ASSERT_STRING_EQUAL(expected_ewkt[i], out_ewkt);
+ ASSERT_STRING_EQUAL(expected_ewkt[i], out_ewkt);
lwfree(out_ewkt);
diff --git a/liblwgeom/cunit/cu_stringbuffer.c b/liblwgeom/cunit/cu_stringbuffer.c
index b6479426a..57c9f99e0 100644
--- a/liblwgeom/cunit/cu_stringbuffer.c
+++ b/liblwgeom/cunit/cu_stringbuffer.c
@@ -28,7 +28,7 @@ static void test_stringbuffer_append(void)
stringbuffer_append(sb, "hello world");
str = stringbuffer_getstring(sb);
- CU_ASSERT_STRING_EQUAL("hello world", str);
+ ASSERT_STRING_EQUAL("hello world", str);
stringbuffer_destroy(sb);
@@ -42,7 +42,7 @@ static void test_stringbuffer_aprintf(void)
stringbuffer_aprintf(sb, "hello %dth world", 14);
- CU_ASSERT_STRING_EQUAL("hello 14th world", str);
+ ASSERT_STRING_EQUAL("hello 14th world", str);
diff --git a/liblwgeom/cunit/cu_surface.c b/liblwgeom/cunit/cu_surface.c
index ce9db5274..074a9dd05 100644
--- a/liblwgeom/cunit/cu_surface.c
+++ b/liblwgeom/cunit/cu_surface.c
@@ -24,7 +24,7 @@ void triangle_parse(void)
CU_ASSERT_EQUAL(strlen(cu_error_msg), 0);
CU_ASSERT_EQUAL(geom->type, TRIANGLETYPE);
tmp = lwgeom_to_ewkt(geom);
- CU_ASSERT_STRING_EQUAL("TRIANGLE((0 1,2 3,4 5,0 1))", tmp);
+ ASSERT_STRING_EQUAL("TRIANGLE((0 1,2 3,4 5,0 1))", tmp);
lwfree(tmp);
lwgeom_free(geom);
/* 3DM */
@@ -32,49 +32,49 @@ void triangle_parse(void)
- CU_ASSERT_STRING_EQUAL("TRIANGLEM((0 1 2,3 4 5,6 7 8,0 1 2))", tmp);
+ ASSERT_STRING_EQUAL("TRIANGLEM((0 1 2,3 4 5,6 7 8,0 1 2))", tmp);
lwfree(tmp);
lwgeom_free(geom);
/* ERROR: a missing Z values */
geom = lwgeom_from_wkt("TRIANGLE((0 1 2,3 4 5,6 7,0 1 2))", LW_PARSER_CHECK_NONE);
- CU_ASSERT_STRING_EQUAL("can not mix dimensionality in a geometry", cu_error_msg);
+ ASSERT_STRING_EQUAL("can not mix dimensionality in a geometry", cu_error_msg);
cu_error_msg_reset();
lwgeom_free(geom);
/* ERROR: non closed rings */
geom = lwgeom_from_wkt("TRIANGLE((0 1 2,3 4 5,6 7 8,0 0 2))", LW_PARSER_CHECK_NONE);
- CU_ASSERT_STRING_EQUAL("geometry contains non-closed rings", cu_error_msg);
+ ASSERT_STRING_EQUAL("geometry contains non-closed rings", cu_error_msg);
lwgeom_free(geom);
/* ERROR: non closed face in Z dim */
geom = lwgeom_from_wkt("TRIANGLE((0 1 2,3 4 5,6 7 8,0 1 3))", LW_PARSER_CHECK_NONE);
lwgeom_free(geom);
/* ERROR: non closed face in Z dim, with a 4D geom */
geom = lwgeom_from_wkt("TRIANGLE((0 1 2 3,4 5 6 7,8 9 10 11,0 1 3 3))", LW_PARSER_CHECK_NONE);
lwgeom_free(geom);
/* ERROR: only 3 points in a face */
geom = lwgeom_from_wkt("TRIANGLE((0 1 2,3 4 5,0 1 2))", LW_PARSER_CHECK_NONE);
- CU_ASSERT_STRING_EQUAL("triangle must have exactly 4 points", cu_error_msg);
+ ASSERT_STRING_EQUAL("triangle must have exactly 4 points", cu_error_msg);
lwgeom_free(geom);
/* ERROR: more than 4 points in a face */
geom = lwgeom_from_wkt("TRIANGLE((0 1 2,3 4 5,6 7 8,9 10 11,0 1 2))", LW_PARSER_CHECK_NONE);
lwgeom_free(geom);
/* ERROR: no interior rings allowed */
geom = lwgeom_from_wkt("TRIANGLE((0 1 2,3 4 5,6 7 8,0 1 2),(9 10 11,12 13 14,15 16 17,9 10 11)", LW_PARSER_CHECK_NONE);
- CU_ASSERT_STRING_EQUAL("parse error - invalid geometry", cu_error_msg);
+ ASSERT_STRING_EQUAL("parse error - invalid geometry", cu_error_msg);
lwgeom_free(geom);
@@ -83,7 +83,7 @@ void triangle_parse(void)
tmp = lwgeom_to_wkt(geom, LW_PARSER_CHECK_NONE, 0, 0);
- CU_ASSERT_STRING_EQUAL("TRIANGLE EMPTY", tmp);
+ ASSERT_STRING_EQUAL("TRIANGLE EMPTY", tmp);
lwfree(tmp);
lwgeom_free(geom);
@@ -93,7 +93,7 @@ void triangle_parse(void)
CU_ASSERT_EQUAL(geom->srid, 4326);
- CU_ASSERT_STRING_EQUAL("SRID=4326;TRIANGLE((0 1 2,3 4 5,6 7 8,0 1 2))", tmp);
+ ASSERT_STRING_EQUAL("SRID=4326;TRIANGLE((0 1 2,3 4 5,6 7 8,0 1 2))", tmp);
lwfree(tmp);
lwgeom_free(geom);
@@ -119,7 +119,7 @@ void tin_parse(void)
CU_ASSERT_EQUAL(geom->type, TINTYPE);
- CU_ASSERT_STRING_EQUAL("TIN EMPTY", tmp);
+ ASSERT_STRING_EQUAL("TIN EMPTY", tmp);
lwfree(tmp);
lwgeom_free(geom);
@@ -128,7 +128,7 @@ void tin_parse(void)
- CU_ASSERT_STRING_EQUAL("TIN(((0 1,2 3,4 5,0 1)))", tmp);
+ ASSERT_STRING_EQUAL("TIN(((0 1,2 3,4 5,0 1)))", tmp);
lwfree(tmp);
lwgeom_free(geom);
@@ -137,49 +137,49 @@ void tin_parse(void)
- CU_ASSERT_STRING_EQUAL("TINM(((0 1 2,3 4 5,6 7 8,0 1 2)))", tmp);
+ ASSERT_STRING_EQUAL("TINM(((0 1 2,3 4 5,6 7 8,0 1 2)))", tmp);
lwfree(tmp);
lwgeom_free(geom);
geom = lwgeom_from_wkt("TIN(((0 1 2,3 4 5,6 7,0 1 2)))", LW_PARSER_CHECK_NONE);
lwgeom_free(geom);
geom = lwgeom_from_wkt("TIN(((0 1 2,3 4 5,6 7 8,0 0 2)))", LW_PARSER_CHECK_NONE);
lwgeom_free(geom);
geom = lwgeom_from_wkt("TIN(((0 1 2,3 4 5,6 7 8,0 1 3)))", LW_PARSER_CHECK_NONE);
lwgeom_free(geom);
geom = lwgeom_from_wkt("TIN(((0 1 2 3,4 5 6 7,8 9 10 11,0 1 3 3)))", LW_PARSER_CHECK_NONE);
lwgeom_free(geom);
geom = lwgeom_from_wkt("TIN(((0 1 2,3 4 5,0 1 2)))", LW_PARSER_CHECK_NONE);
lwgeom_free(geom);
/* ERROR: more than 3 points in a face */
geom = lwgeom_from_wkt("TIN(((0 1 2,3 4 5,6 7 8,9 10 11,0 1 2)))", LW_PARSER_CHECK_NONE);
lwgeom_free(geom);
/* ERROR: use ring for triangle */
geom = lwgeom_from_wkt("TIN(((0 1 2,3 4 5,6 7 8,0 1 2),(9 10 11,12 13 14,15 16 17,9 10 11)))", LW_PARSER_CHECK_NONE);
lwgeom_free(geom);
@@ -188,7 +188,7 @@ void tin_parse(void)
lwfree(tmp);
lwgeom_free(geom);
@@ -198,7 +198,7 @@ void tin_parse(void)
CU_ASSERT_EQUAL(geom->srid, SRID_UNKNOWN);
- CU_ASSERT_STRING_EQUAL("TIN(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))", tmp);
+ ASSERT_STRING_EQUAL("TIN(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))", tmp);
lwfree(tmp);
lwgeom_free(geom);
@@ -209,7 +209,7 @@ void tin_parse(void)
CU_ASSERT_EQUAL(FLAGS_GET_M(geom->flags), 1);
- CU_ASSERT_STRING_EQUAL("TIN(((0 0 0 0,0 0 1 0,0 1 0 2,0 0 0 0)),((0 0 0 0,0 1 0 0,1 0 0 4,0 0 0 0)),((0 0 0 0,1 0 0 0,0 0 1 6,0 0 0 0)),((1 0 0 0,0 1 0 0,0 0 1 0,1 0 0 0)))", tmp);
+ ASSERT_STRING_EQUAL("TIN(((0 0 0 0,0 0 1 0,0 1 0 2,0 0 0 0)),((0 0 0 0,0 1 0 0,1 0 0 4,0 0 0 0)),((0 0 0 0,1 0 0 0,0 0 1 6,0 0 0 0)),((1 0 0 0,0 1 0 0,0 0 1 0,1 0 0 0)))", tmp);
lwfree(tmp);
lwgeom_free(geom);
@@ -219,7 +219,7 @@ void tin_parse(void)
- CU_ASSERT_STRING_EQUAL("SRID=4326;TIN(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))", tmp);
+ ASSERT_STRING_EQUAL("SRID=4326;TIN(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))", tmp);
lwfree(tmp);
lwgeom_free(geom);
@@ -245,10 +245,10 @@ void polyhedralsurface_parse(void)
CU_ASSERT_EQUAL(geom->type, POLYHEDRALSURFACETYPE);
tmp = lwgeom_to_hexwkb_buffer(geom, WKB_NDR | WKB_EXTENDED);
- CU_ASSERT_STRING_EQUAL("010F00000001000000010300000001000000040000000000000000000000000000000000F03F00000000000000400000000000000840000000000000104000000000000014400000000000000000000000000000F03F", tmp);
+ ASSERT_STRING_EQUAL("010F00000001000000010300000001000000040000000000000000000000000000000000F03F00000000000000400000000000000840000000000000104000000000000014400000000000000000000000000000F03F", tmp);
lwfree(tmp);
- CU_ASSERT_STRING_EQUAL("POLYHEDRALSURFACE(((0 1,2 3,4 5,0 1)))", tmp);
+ ASSERT_STRING_EQUAL("POLYHEDRALSURFACE(((0 1,2 3,4 5,0 1)))", tmp);
lwfree(tmp);
lwgeom_free(geom);
@@ -257,16 +257,16 @@ void polyhedralsurface_parse(void)
- CU_ASSERT_STRING_EQUAL("POLYHEDRALSURFACEM(((0 1 2,3 4 5,6 7 8,0 1 2)))", tmp);
+ ASSERT_STRING_EQUAL("POLYHEDRALSURFACEM(((0 1 2,3 4 5,6 7 8,0 1 2)))", tmp);
lwfree(tmp);
- CU_ASSERT_STRING_EQUAL("010F00004001000000010300004001000000040000000000000000000000000000000000F03F000000000000004000000000000008400000000000001040000000000000144000000000000018400000000000001C4000000000000020400000000000000000000000000000F03F0000000000000040", tmp);
+ ASSERT_STRING_EQUAL("010F00004001000000010300004001000000040000000000000000000000000000000000F03F000000000000004000000000000008400000000000001040000000000000144000000000000018400000000000001C4000000000000020400000000000000000000000000000F03F0000000000000040", tmp);
lwfree(tmp);
lwgeom_free(geom);
geom = lwgeom_from_wkt("POLYHEDRALSURFACE(((0 1 2,3 4 5,6 7,0 1 2)))", LW_PARSER_CHECK_NONE);
lwgeom_free(geom);
@@ -275,34 +275,34 @@ void polyhedralsurface_parse(void)
- CU_ASSERT_STRING_EQUAL("POLYHEDRALSURFACE(((0 1 2,3 4 5,6 7 8,0 1 2),(9 10 11,12 13 14,15 16 17,9 10 11)))", tmp);
+ ASSERT_STRING_EQUAL("POLYHEDRALSURFACE(((0 1 2,3 4 5,6 7 8,0 1 2),(9 10 11,12 13 14,15 16 17,9 10 11)))", tmp);
lwfree(tmp);
- CU_ASSERT_STRING_EQUAL("010F00008001000000010300008002000000040000000000000000000000000000000000F03F000000000000004000000000000008400000000000001040000000000000144000000000000018400000000000001C4000000000000020400000000000000000000000000000F03F00000000000000400400000000000000000022400000000000002440000000000000264000000000000028400000000000002A400000000000002C400000000000002E4000000000000030400000000000003140000000000000224000000000000024400000000000002640", tmp);
+ ASSERT_STRING_EQUAL("010F00008001000000010300008002000000040000000000000000000000000000000000F03F000000000000004000000000000008400000000000001040000000000000144000000000000018400000000000001C4000000000000020400000000000000000000000000000F03F00000000000000400400000000000000000022400000000000002440000000000000264000000000000028400000000000002A400000000000002C400000000000002E4000000000000030400000000000003140000000000000224000000000000024400000000000002640", tmp);
lwfree(tmp);
lwgeom_free(geom);
geom = lwgeom_from_wkt("POLYHEDRALSURFACE(((0 1 2,3 4 5,6 7 8,0 0 2)))", LW_PARSER_CHECK_ALL);
lwgeom_free(geom);
geom = lwgeom_from_wkt("POLYHEDRALSURFACE(((0 1 2,3 4 5,6 7 8,0 1 3)))", LW_PARSER_CHECK_ALL);
lwgeom_free(geom);
geom = lwgeom_from_wkt("POLYHEDRALSURFACE(((0 1 2 3,4 5 6 7,8 9 10 11,0 1 3 3)))", LW_PARSER_CHECK_ALL);
lwgeom_free(geom);
geom = lwgeom_from_wkt("POLYHEDRALSURFACE(((0 1 2,3 4 5,0 1 2)))", LW_PARSER_CHECK_ALL);
- CU_ASSERT_STRING_EQUAL("geometry requires more points", cu_error_msg);
+ ASSERT_STRING_EQUAL("geometry requires more points", cu_error_msg);
lwgeom_free(geom);
@@ -311,10 +311,10 @@ void polyhedralsurface_parse(void)
tmp = (char *)lwgeom_to_hexwkb_buffer(geom, WKB_HEX | WKB_ISO | WKB_NDR);
- CU_ASSERT_STRING_EQUAL("010F00000000000000", tmp);
+ ASSERT_STRING_EQUAL("010F00000000000000", tmp);
lwfree(tmp);
- CU_ASSERT_STRING_EQUAL("POLYHEDRALSURFACE EMPTY", tmp);
+ ASSERT_STRING_EQUAL("POLYHEDRALSURFACE EMPTY", tmp);
lwfree(tmp);
lwgeom_free(geom);
@@ -324,10 +324,10 @@ void polyhedralsurface_parse(void)
- CU_ASSERT_STRING_EQUAL("POLYHEDRALSURFACE(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))", tmp);
+ ASSERT_STRING_EQUAL("POLYHEDRALSURFACE(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))", tmp);
lwfree(tmp);
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tmp);
+ ASSERT_STRING_EQUAL("010F000080040000000103000080010000000400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F0000000000000000000000000000F03F0000000000000000000000000000000000000000000000000000000000000000010300008001000000040000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F0000000000000000000000000000F03F0000000000000000000000000000000000000000000000000000000000000000000000000000000001030000800100000004000000000000000000000000000000000000000000000000000000000000000000F03F0000000000000000000000000000000000000000000000000000000000000000000000000000F03F00000000000000000000000000000000000000000000000001030000800100000004000000000000000000F03F000000000000000000000000000000000000000000000000000000000000F03F000000000000000000000000000000000000000000000000000000000000F03F000000000000F03F00000000000000000000000000000000", tmp);
lwfree(tmp);
lwgeom_free(geom);
@@ -338,10 +338,10 @@ void polyhedralsurface_parse(void)
- CU_ASSERT_STRING_EQUAL("POLYHEDRALSURFACE(((0 0 0 0,0 0 1 0,0 1 0 2,0 0 0 0)),((0 0 0 0,0 1 0 0,1 0 0 4,0 0 0 0)),((0 0 0 0,1 0 0 0,0 0 1 6,0 0 0 0)),((1 0 0 0,0 1 0 0,0 0 1 0,1 0 0 0)))", tmp);
+ ASSERT_STRING_EQUAL("POLYHEDRALSURFACE(((0 0 0 0,0 0 1 0,0 1 0 2,0 0 0 0)),((0 0 0 0,0 1 0 0,1 0 0 4,0 0 0 0)),((0 0 0 0,1 0 0 0,0 0 1 6,0 0 0 0)),((1 0 0 0,0 1 0 0,0 0 1 0,1 0 0 0)))", tmp);
lwfree(tmp);
- CU_ASSERT_STRING_EQUAL("010F0000C00400000001030000C00100000004000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F00000000000000000000000000000000000000000000F03F00000000000000000000000000000040000000000000000000000000000000000000000000000000000000000000000001030000C0010000000400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F00000000000000000000000000000000000000000000F03F000000000000000000000000000000000000000000001040000000000000000000000000000000000000000000000000000000000000000001030000C001000000040000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F0000000000001840000000000000000000000000000000000000000000000000000000000000000001030000C00100000004000000000000000000F03F000000000000000000000000000000000000000000000000000000000000000000
0000000000F03F0000000000000000000000000000000000000000000000000000000000000000000000000000F03F0000000000000000000000000000F03F000000000000000000000000000000000000000000000000", tmp);
+ ASSERT_STRING_EQUAL("010F0000C00400000001030000C00100000004000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F00000000000000000000000000000000000000000000F03F00000000000000000000000000000040000000000000000000000000000000000000000000000000000000000000000001030000C0010000000400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F00000000000000000000000000000000000000000000F03F000000000000000000000000000000000000000000001040000000000000000000000000000000000000000000000000000000000000000001030000C001000000040000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F0000000000001840000000000000000000000000000000000000000000000000000000000000000001030000C00100000004000000000000000000F03F000000000000000000000000000000000000000000000000000000000000000000000
lwfree(tmp);
lwgeom_free(geom);
@@ -352,10 +352,10 @@ void polyhedralsurface_parse(void)
- CU_ASSERT_STRING_EQUAL("SRID=4326;POLYHEDRALSURFACE(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))", tmp);
+ ASSERT_STRING_EQUAL("SRID=4326;POLYHEDRALSURFACE(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))", tmp);
lwfree(tmp);
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tmp);
+ ASSERT_STRING_EQUAL("010F0000A0E6100000040000000103000080010000000400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F0000000000000000000000000000F03F0000000000000000000000000000000000000000000000000000000000000000010300008001000000040000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F0000000000000000000000000000F03F0000000000000000000000000000000000000000000000000000000000000000000000000000000001030000800100000004000000000000000000000000000000000000000000000000000000000000000000F03F0000000000000000000000000000000000000000000000000000000000000000000000000000F03F00000000000000000000000000000000000000000000000001030000800100000004000000000000000000F03F000000000000000000000000000000000000000000000000000000000000F03F000000000000000000000000000000000000000000000000000000000000F03F000000000000F03F00000000000000000000000000000000", tmp);
lwfree(tmp);
lwgeom_free(geom);
diff --git a/liblwgeom/cunit/cu_triangulate.c b/liblwgeom/cunit/cu_triangulate.c
index 45b8398e2..f54ebfe68 100644
--- a/liblwgeom/cunit/cu_triangulate.c
+++ b/liblwgeom/cunit/cu_triangulate.c
@@ -40,7 +40,7 @@ test_lwgeom_delaunay_triangulation(void)
if (strcmp(wkt, exp_wkt))
fprintf(stderr, "\nExp: %s\nObt: %s\n", exp_wkt, wkt);
- CU_ASSERT_STRING_EQUAL(wkt, exp_wkt);
+ ASSERT_STRING_EQUAL(wkt, exp_wkt);
lwfree(wkt);
Summary of changes:
liblwgeom/cunit/cu_chaikin.c | 2 +-
liblwgeom/cunit/cu_clean.c | 6 +--
liblwgeom/cunit/cu_clip_by_rect.c | 8 +--
liblwgeom/cunit/cu_filterm.c | 2 +-
liblwgeom/cunit/cu_force_dims.c | 12 ++---
liblwgeom/cunit/cu_force_sfs.c | 2 +-
liblwgeom/cunit/cu_gserialized1.c | 22 ++++----
liblwgeom/cunit/cu_gserialized2.c | 2 +-
liblwgeom/cunit/cu_homogenize.c | 2 +-
liblwgeom/cunit/cu_in_encoded_polyline.c | 2 +-
liblwgeom/cunit/cu_in_geojson.c | 6 +--
liblwgeom/cunit/cu_in_twkb.c | 58 ++++++++++-----------
liblwgeom/cunit/cu_in_wkb.c | 48 ++++++++---------
liblwgeom/cunit/cu_in_wkt.c | 80 ++++++++++++++---------------
liblwgeom/cunit/cu_misc.c | 26 +++++-----
liblwgeom/cunit/cu_node.c | 10 ++--
liblwgeom/cunit/cu_out_twkb.c | 64 +++++++++++------------
liblwgeom/cunit/cu_out_wkb.c | 50 +++++++++---------
liblwgeom/cunit/cu_out_wkt.c | 74 +++++++++++++--------------
liblwgeom/cunit/cu_print.c | 2 +-
liblwgeom/cunit/cu_sfcgal.c | 2 +-
liblwgeom/cunit/cu_stringbuffer.c | 4 +-
liblwgeom/cunit/cu_surface.c | 88 ++++++++++++++++----------------
liblwgeom/cunit/cu_triangulate.c | 2 +-
24 files changed, 287 insertions(+), 287 deletions(-)
hooks/post-receive
