[SCM] PostGIS branch master updated. 3.4.0rc1-1114-g4ffca201c
git at osgeo.org
git at osgeo.org
Fri May 17 14:43:57 PDT 2024
the project "PostGIS".
via 4ffca201c5b5c97fd3a951c12a2fd7b034ed1806 (commit)
via c2acf6095e414993cb1c8b402425eb79e538c193 (commit)
from de88a07ca71e80f52ebf5be5e1aa74ce2f678280 (commit)
revisions in full, below.
commit 4ffca201c5b5c97fd3a951c12a2fd7b034ed1806
Author: Sandro Santilli <strk at kbt.io>
Date: Fri May 17 23:36:45 2024 +0200
Fix printf format warnings in loader
diff --git a/loader/shp2pgsql-core.c b/loader/shp2pgsql-core.c
index 32c63e4e0..e86b5abae 100644
--- a/loader/shp2pgsql-core.c
+++ b/loader/shp2pgsql-core.c
@@ -1467,7 +1467,7 @@ ShpLoaderGetSQLHeader(SHPLOADERSTATE *state, char **strheader)
stringbuffer_aprintf(sb, "\"%s\".",state->config->schema);
- stringbuffer_aprintf(sb, "\"%s\" WHERE false;\n", state->config->table, state->geo_col);
+ stringbuffer_aprintf(sb, "\"%s\" WHERE false;\n", state->config->table);
/**out input data is going to be in different srid from target, so need to remove type constraint **/
stringbuffer_aprintf(sb, "ALTER TABLE \"pgis_tmp_%s\" ALTER COLUMN \"%s\" TYPE geometry USING ( (\"%s\"::geometry) ); \n", state->config->table, state->geo_col, state->geo_col);
commit c2acf6095e414993cb1c8b402425eb79e538c193
Date: Fri May 17 23:26:16 2024 +0200
Fix printf format warnings in rt_core
diff --git a/raster/rt_core/rt_wkb.c b/raster/rt_core/rt_wkb.c
index 9113274f7..ccec01a35 100644
--- a/raster/rt_core/rt_wkb.c
+++ b/raster/rt_core/rt_wkb.c
@@ -31,6 +31,8 @@
#include "librtcore_internal.h"
#include "rt_serialize.h"
+#include <inttypes.h>
/* Read band from WKB as at start of band */
static rt_band
rt_band_from_wkb(
@@ -286,7 +288,8 @@ rt_raster_from_wkb(const uint8_t* wkb, uint32_t wkbsize) {
/* Check that wkbsize is >= sizeof(rt_raster_serialized) */
if (wkbsize < RT_WKB_HDR_SZ) {
- rterror("rt_raster_from_wkb: wkb size (%d) < min size (%d)",
+ rterror("rt_raster_from_wkb: wkb size (%" PRIu32
+ ") < min size (%zu)",
wkbsize, RT_WKB_HDR_SZ);
return NULL;
@@ -350,11 +353,11 @@ rt_raster_from_wkb(const uint8_t* wkb, uint32_t wkbsize) {
if (!rast->numBands) {
/* Here ptr should have been left to right after last used byte */
if (ptr < wkbend) {
- rtwarn("%d bytes of WKB remained unparsed", wkbend - ptr);
+ rtwarn("%" PRIu64 " bytes of WKB remained unparsed", wkbend - ptr);
else if (ptr > wkbend) {
/* Easier to get a segfault before I guess */
- rtwarn("We parsed %d bytes more then available!", ptr - wkbend);
+ rtwarn("We parsed %zu bytes more then available!", ptr - wkbend);
rast->bands = NULL;
@@ -392,11 +395,11 @@ rt_raster_from_wkb(const uint8_t* wkb, uint32_t wkbsize) {
if (ptr < wkbend) {
+ rtwarn("%zu bytes of WKB remained unparsed", wkbend - ptr);
return rast;
Summary of changes:
loader/shp2pgsql-core.c | 2 +-
raster/rt_core/rt_wkb.c | 13 ++++++++-----
2 files changed, 9 insertions(+), 6 deletions(-)
hooks/post-receive
