[PostGIS] #5733: Mixed use of compilers to build sources
    trac at osgeo.org
    Tue May 21 13:10:27 PDT 2024
 Reporter:  strk    |      Owner:  strk
     Type:  defect  |     Status:  new
 Priority:  medium  |  Milestone:  PostGIS 3.4.3
Component:  build   |    Version:  3.4.x
 Keywords:          |
 As odd as it seems, running `make` ends up using a mix of `gcc` and
 `clang-14` on my system. Even for the same file.
 For example, under raster/rt_pg, an extract of the build logs:
 grep rtpg_pixel.c build.log # returns:
 gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
 statement -Werror=vla -Wendif-labels -Wmissing-format-attribute
 -Wimplicit-fallthrough=3 -Wcast-function-type -Wformat-security -fno-
 strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation
 -Wno-stringop-truncation -g -g -O2 -fstack-protector-strong -Wformat
 -Werror=format-security -fno-omit-frame-pointer -fPIC -I../../liblwgeom
 -I../../liblwgeom -I/usr/local/include  -I/usr/include/x86_64-linux-gnu
 -I/usr/include/libxml2  -I/usr/include/json-c   -DNDEBUG -std=gnu99 -O2 -g
 -Wall -Wsuggest-attribute=format -fno-math-errno -fno-signed-zeros -Wall
 -O2 -I/usr/local/include -I../../libpgcommon -I/usr/include/x86_64-linux-
 gnu -I./../rt_core -I. -I./.. -I../.. -I. -I./
 -I/usr/include/postgresql/15/server -I/usr/include/postgresql/internal
 -Wdate-time -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2   -c
 -o rtpg_pixel.o rtpg_pixel.c
 /usr/bin/clang-14 -Wno-ignored-attributes -fno-strict-aliasing -fwrapv
 -Wno-unused-command-line-argument -Wno-compound-token-split-by-macro -O2
 -I../../liblwgeom -I../../liblwgeom -I/usr/local/include
 -I/usr/include/x86_64-linux-gnu   -I/usr/include/libxml2
 -I/usr/include/json-c   -DNDEBUG -std=gnu99 -O2 -g -Wall -Wsuggest-
 attribute=format -fno-math-errno -fno-signed-zeros -Wall -O2
 -I/usr/local/include -I../../libpgcommon -I/usr/include/x86_64-linux-gnu
 -flto=thin -emit-llvm -c -o rtpg_pixel.bc rtpg_pixel.c
 It does look like something about LLVM but I don't see where that line
 comes from. I guess it's from PGXS.
 The problem with this mix of compilers is that the same CFLAGS are passed
 to both but some flags are only supported by one compiler and not the
 other.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5733>
