[PostGIS] #5611: Remove the workaround for pgaudit being too verbose.
PostGIS trac at osgeo.org
Fri May 24 21:30:01 PDT 2024
  Reporter:  mnencia      |      Owner:  pramsey
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 3.5.0
 Component:  postgis      |    Version:  3.4.x
Resolution:               |   Keywords:
Comment (by robe):
 Replying to [comment:6 pramsey]:
 > So, having a gander at this, we could probably wrap the test in a check
 for the pgaudit version, since it's there in pg_extension.extversion. The
 code also says the problem is specific to PgSQL <=14, which I don't really
 recall.
 > I am going to remove the check entirely from trunk. How do we feel about
 a version checking port for stable releases?
 I'm fine with that.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5611#comment:7>
