[SCM] PostGIS branch master updated. 3.4.0rc1-1128-g459216137
git at osgeo.org
git at osgeo.org
Fri May 31 03:57:43 PDT 2024
the project "PostGIS".
via 459216137e99a9ea07be864638edc55e31ccccb1 (commit)
via d0d3823f48dd3fa529e3345bcf96c49cc2cd4002 (commit)
from 63ecdf15aac3cdd3fff8effea02d9f898be20587 (commit)
revisions in full, below.
commit 459216137e99a9ea07be864638edc55e31ccccb1
Author: Sandro Santilli <strk at kbt.io>
Date: Fri May 31 12:57:20 2024 +0200
Add ability to specify list of releases to check
diff --git a/utils/check_releases_md5.sh b/utils/check_releases_md5.sh
index c377f4708..47edf07e2 100755
--- a/utils/check_releases_md5.sh
+++ b/utils/check_releases_md5.sh
@@ -10,11 +10,15 @@ OLDEST_MIN=0
mkdir -p ${WORKDIR}
cd ${WORKDIR}
-echo "Fetching list of supported releases"
-curl -s ${API}/repos/postgis/postgis/tags > tags.json
-jq -r .[].name tags.json |
- grep "^${OLDEST_MAJ}\.${OLDEST_MIN}" |
- grep -v [a-z] > checked_releases.txt
+if test -n '$@'; then
+ echo $@ | tr ' ' '\n' > checked_releases.txt
+else
+ echo "Fetching list of supported releases"
+ curl -s ${API}/repos/postgis/postgis/tags > tags.json
+ jq -r .[].name tags.json |
+ grep "^${OLDEST_MAJ}\.${OLDEST_MIN}" |
+ grep -v [a-z] > checked_releases.txt
+fi
while read REL; do
relname=postgis-${REL}.tar.gz
commit d0d3823f48dd3fa529e3345bcf96c49cc2cd4002
Date: Fri May 31 12:55:12 2024 +0200
Add script to check releases MD5
References #5736
new file mode 100755
index 000000000..c377f4708
--- /dev/null
@@ -0,0 +1,37 @@
+#!/bin/sh
+WORKDIR=$PWD/releases-check
+API=https://git.osgeo.org/gitea/api/v1
+DOWNLOAD_BASE=https://download.osgeo.org/postgis/source
+MD5_BASE=https://postgis.net/stuff
+OLDEST_MAJ=3
+OLDEST_MIN=0
+mkdir -p ${WORKDIR}
+cd ${WORKDIR}
+echo "Fetching list of supported releases"
+curl -s ${API}/repos/postgis/postgis/tags > tags.json
+jq -r .[].name tags.json |
+while read REL; do
+ relname=postgis-${REL}.tar.gz
+ md5name=${relname}.md5
+ echo -n "Checking ${relname} ... "
+ curl -s ${DOWNLOAD_BASE}/${relname} -o ${relname} || {
+ echo "unable to download ${relname} from ${DOWNLOAD_BASE}"
+ continue
+ curl -s ${MD5_BASE}/${md5name} -o ${md5name} || {
+ echo "unable to download ${md5name} from ${MD5_BASE}"
+ continue
+ md5sum ${relname} | diff - ${md5name} > /dev/null 2>&1 || {
+ echo "MD5 mismatch"
+ continue
+ echo "OK"
+done < checked_releases.txt
Summary of changes:
utils/check_releases_md5.sh | 41 +++++++++++++++++++++++++++++++++++++++++
1 file changed, 41 insertions(+)
create mode 100755 utils/check_releases_md5.sh
hooks/post-receive
