[SCM] postgis.net branch json-config updated. clarity-final-94-gb32d2b4
git at osgeo.org
git at osgeo.org
Fri May 31 05:20:18 PDT 2024
the project "postgis.net".
The branch, json-config has been updated
discards bdab6850107a37066ac8431e94850fa5ae6cd7c8 (commit)
via b32d2b4dea8cc99517aa49ebc071767ed7e23d29 (commit)
via 2e52ab46b1d0bb4426fbf2ef7244126f41b5f9d5 (commit)
This update added new revisions after undoing existing revisions. That is
to say, the old revision is not a strict subset of the new revision. This
situation occurs when you --force push a change and generate a repository
containing something like this:
* -- * -- B -- O -- O -- O (bdab6850107a37066ac8431e94850fa5ae6cd7c8)
N -- N -- N (b32d2b4dea8cc99517aa49ebc071767ed7e23d29)
When this happens we assume that you've already had alert emails for all
of the O revisions, and so we here report only the revisions in the N
branch from the common base, B.
revisions in full, below.
commit b32d2b4dea8cc99517aa49ebc071767ed7e23d29
Author: Sandro Santilli <strk at kbt.io>
Date: Fri May 31 13:29:13 2024 +0200
Convert configuration from toml to json
diff --git a/config.json b/config.json
new file mode 100644
index 0000000..b780f1a
--- /dev/null
+++ b/config.json
@@ -0,0 +1,128 @@
+ "baseURL": "https://postgis.net/",
+ "title": "PostGIS",
+ "theme": "hugo-geekdoc",
+ "pygmentsUseClasses": true,
+ "pygmentsCodeFences": true,
+ "disablePathToLower": true,
+ "enableRobotsTXT": true,
+ "permalinks": {
+ "news": "/:year/:month/:title/"
+ "markup": {
+ "goldmark": {
+ "renderer": {
+ "unsafe": true
+ "tableOfContents": {
+ "startLevel": 1,
+ "endLevel": 9
+ "taxonomies": {
+ "tag": "tags",
+ "event": "events"
+ "services": {
+ "rss": {
+ "limit": 10
+ "outputFormats": {
+ "RSS": {
+ "mediatype": "application/rss",
+ "baseName": "feed"
+ "params": {
+ "geekdocToC": 2,
+ "geekdocMenuBundle": false,
+ "geekdocCollapseAllSections": false,
+ "geekdocNextPrev": true,
+ "geekdocBreadcrumb": true,
+ "geekdocSearch": true,
+ "geekdocSearchShowParent": true,
+ "geekdocAnchor": true,
+ "geekdocAnchorCopy": true,
+ "geekdocImageLazyLoading": true,
+ "geekdocOverwriteHTMLBase": false,
+ "geekdocDarkModeToggle": true,
+ "geekdocDarkModeDim": false,
+ "geekdocDarkModeCode": false,
+ "geekdocBackToTop": true,
+ "geekdocTagsToMenu": false,
+ "docLanguages": [
+ "en",
+ "ja",
+ "fr",
+ "zh_Hans",
+ "de",
+ "ko_KR",
+ "es",
+ "it",
+ "br"
+ "geekdocFileTreeSortBy": "title",
+ "geekdocContentLicense": {
+ "name": "CC BY-SA 4.0",
+ "link": "https://creativecommons.org/licenses/by-sa/4.0/"
+ "postgisMenu": [
+ "name": "Documentation",
+ "href": "/documentation"
+ "name": "Community",
+ "href": "/community"
+ "name": "Development",
+ "href": "/support"
+ "postgis": {
+ "version": "3.3.4",
+ "release_docs": "https://download.osgeo.org/postgis/docs",
+ "release_source": "https://download.osgeo.org/postgis/source",
+ "release_notes": "https://git.osgeo.org/gitea/postgis/postgis/raw/tag",
+ "source_dev_branch": "https://git.osgeo.org/gitea/postgis/postgis/src/branch/master",
+ "site_docs": "/docs",
+ "dev_download": "/stuff",
+ "releases": {
+ "dev": {
+ "minor": "3.5",
+ "dev": "3.5.0dev",
+ "tag": "3.5.0dev",
+ "is_dev": true
+ "34": {
+ "minor": "3.4",
+ "dev": "3.4.3dev",
+ "tag": "3.4.2"
+ "33": {
+ "minor": "3.3",
+ "dev": "3.3.7dev",
+ "tag": "3.3.6"
+ "32": {
+ "minor": "3.2",
+ "dev": "3.2.8dev",
+ "tag": "3.2.7"
+ "31": {
+ "minor": "3.1",
+ "dev": "3.1.12dev",
+ "tag": "3.1.11"
+ "30": {
+ "minor": "3.0",
+ "dev": "3.0.12dev",
+ "tag": "3.0.11"
diff --git a/config.toml b/config.toml
deleted file mode 100644
index 13caa9a..0000000
--- a/config.toml
+++ /dev/null
@@ -1,205 +0,0 @@
-baseURL = "https://postgis.net/"
-title = "PostGIS"
-theme = "hugo-geekdoc"
-# Required to get well formatted code blocks
-pygmentsUseClasses = true
-pygmentsCodeFences = true
-disablePathToLower = true
-# enableGitInfo = true
-# Required if you want to render robots.txt template
-enableRobotsTXT = true
-[permalinks]
- news = '/:year/:month/:title/'
-[markup]
- [markup.goldmark.renderer]
- # Needed for mermaid shortcode
- unsafe = true
- [markup.tableOfContents]
- startLevel = 1
- endLevel = 9
-[taxonomies]
- tag = "tags"
- event = "events"
-[services.rss]
- limit = 10
-[outputFormats]
-[outputFormats.RSS]
- mediatype = "application/rss"
- baseName = "feed"
-[params]
- # (Optional, default 6) Set how many table of contents levels to be showed on page.
- # Use false to hide ToC, note that 0 will default to 6 (https://gohugo.io/functions/default/)
- # You can also specify this parameter per page in front matter.
- geekdocToC = 2
- # (Optional, default static/brand.svg) Set the path to a logo for the Geekdoc
- # relative to your 'static/' folder.
- # We ignore this value in the CSS
- #geekdocLogo = "postgis-logo-horizontal.png"
- # (Optional, default false) Render menu from data file in 'data/menu/main.yaml'.
- # See also https://geekdocs.de/usage/menus/#bundle-menu.
- geekdocMenuBundle = false
- # (Optional, default false) Collapse all menu entries, can not be overwritten
- # per page if enabled. Can be enabled per page via 'geekdocCollapseSection'.
- geekdocCollapseAllSections = false
- # (Optional, default true) Show page navigation links at the bottom of each
- # docs page (bundle menu only).
- geekdocNextPrev = true
- # (Optional, default true) Show a breadcrumb navigation bar at the top of each docs page.
- geekdocBreadcrumb = true
- # (Optional, default none) Set source repository location. Used for 'Edit page' links.
- #geekdocRepo = "https://git.osgeo.org/gitea/postgis/postgis.net"
- # (Optional, default none) Enable 'Edit page' links. Requires 'GeekdocRepo' param
- # and the path must point to the parent directory of the 'content' folder.
- #geekdocEditPath = "/src/branch/website/content"
- # (Optional, default true) Enables search function with flexsearch.
- # Index is built on the fly and might slow down your website.
- geekdocSearch = true
- # (Optional, default false) Display search results with the parent folder as prefix. This
- # option allows you to distinguish between files with the same name in different folders.
- # NOTE: This parameter only applies when 'geekdocSearch = true'.
- geekdocSearchShowParent = true
- # (Optional, default none) Add a link to your Legal Notice page to the site footer.
- # It can be either a remote url or a local file path relative to your content directory.
- #geekdocLegalNotice = "https://blog.example.com/legal"
- # (Optional, default none) Add a link to your Privacy Policy page to the site footer.
- #geekdocPrivacyPolicy = "/privacy"
- # (Optional, default true) Add an anchor link to headlines.
- geekdocAnchor = true
- # (Optional, default true) Copy anchor url to clipboard on click.
- geekdocAnchorCopy = true
- # (Optional, default true) Enable or disable image lazy loading for images rendered
- # by the 'img' shortcode.
- geekdocImageLazyLoading = true
- # (Optional, default false) Set HTMl <base> to .Site.BaseURL if enabled. It might be required
- # if a subdirectory is used within Hugos BaseURL.
- # See https://developer.mozilla.org/de/docs/Web/HTML/Element/base.
- geekdocOverwriteHTMLBase = false
- # (Optional, default true) Enable or disable the JavaScript based color theme toggle switch. The CSS based
- # user preference mode still works.
- geekdocDarkModeToggle = true
- # (Optional, default false) Auto-decrease brightness of images and add a slightly grayscale to avoid
- # bright spots while using the dark mode.
- geekdocDarkModeDim = false
- # (Optional, default false) Enforce code blocks to always use the dark color theme.
- geekdocDarkModeCode = false
- # (Optional, default true) Display a "Back to top" link in the site footer.
- geekdocBackToTop = true
- # (Optional, default false) Enable or disable adding tags for post pages automatically to the navigation sidebar.
- geekdocTagsToMenu = false
- docLanguages = ['en', 'ja', 'fr', 'zh_Hans', 'de', 'ko_KR', 'es', 'it', 'br']
- # (Optional, default 'title') Configure how to sort file-tree menu entries. Possible options are 'title', 'linktitle',
- # 'date', 'publishdate', 'expirydate' or 'lastmod'. Every option can be used with a reverse modifier as well
- # e.g. 'title_reverse'.
- geekdocFileTreeSortBy = "title"
- # (Optional, default none) Adds a "Content licensed under <license>" line to the footer.
- # Could be used if you want to define a default license for your content.
- [params.geekdocContentLicense]
- name = "CC BY-SA 4.0"
- link = "https://creativecommons.org/licenses/by-sa/4.0/"
- [[params.postgisMenu]]
- name = "Documentation"
- href = "/documentation"
- name = "Community"
- href = "/community"
- name = "Development"
- href = "/support"
- # [[params.postgisMenu]]
- # name = "Home"
- # href = "/"
- [params.postgis]
- version = "3.3.4"
- release_docs = "https://download.osgeo.org/postgis/docs"
- release_source = "https://download.osgeo.org/postgis/source"
- release_notes = "https://git.osgeo.org/gitea/postgis/postgis/raw/tag"
- source_dev_branch = "https://git.osgeo.org/gitea/postgis/postgis/src/branch/master"
- site_docs = "/docs"
- dev_download = "/stuff"
- [params.postgis.releases]
- [params.postgis.releases.dev]
- minor = "3.5"
- dev = "3.5.0dev"
- tag = "3.5.0dev"
- is_dev = true
- [params.postgis.releases.34]
- minor = "3.4"
- dev = "3.4.3dev"
- tag = "3.4.2"
- [params.postgis.releases.33]
- minor = "3.3"
- dev = "3.3.7dev"
- tag = "3.3.6"
- [params.postgis.releases.32]
- minor = "3.2"
- dev = "3.2.8dev"
- tag = "3.2.7"
- [params.postgis.releases.31]
- minor = "3.1"
- dev = "3.1.12dev"
- tag = "3.1.11"
- [params.postgis.releases.30]
- minor = "3.0"
- dev = "3.0.12dev"
- tag = "3.0.11"
- # [params.postgis.releases.25]
- # minor = "2.5"
- # dev = "2.5.11"
- # tag = "2.5.11"
- # eol = true
- # [params.postgis.releases.24]
- # minor = "2.4"
- # dev = "2.4.10"
- # tag = "2.4.10"
- # eol = true
- # [params.postgis.releases.23]
- # minor = "2.3"
- # dev = "2.3.11"
- # tag = "2.3.11"
- # eol = true
Summary of changes:
.woodpecker/build.yml | 9 +++++++++
README.md | 2 ++
2 files changed, 11 insertions(+)
create mode 100644 .woodpecker/build.yml
hooks/post-receive
postgis.net
