[PostGIS] #5807: Joined table ST_Transform runs on each filter evaluation instead of just once per input row
trac at osgeo.org
Fri Nov 1 23:52:21 PDT 2024
once per input row
Reporter: lnicola | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Comment (by robe):
Just to confirm it's not something special about this dataset, I created a
dummy example attached:
\i ticket_transform_issue.sql
outputs
funcname | calls | total_time
st_transform | 11090 | 5.841
st_intersects | 11084 | 14.881
(2 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5807#comment:7>
