[SCM] PostGIS branch stable-3.5 updated. 3.5.0-21-g26d0eb132
Sat Nov 2 02:14:25 PDT 2024
the project "PostGIS".
The branch, stable-3.5 has been updated
       via  26d0eb132c404f22c99d946068d8fc12bd5c6bb9 (commit)
      from  9e97a85fbd192ea3460f38bc59be7db0b871286d (commit)
revisions in full, below.
commit 26d0eb132c404f22c99d946068d8fc12bd5c6bb9
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Nov 2 10:09:41 2024 +0100
    Revert "Check motion range upon snap/splitting edge to existing node"
    The check is bogus, we need a different approach
    This reverts commit 69abb0721c7f4e551f0061de9293db61b83a0037.
    This reverts commit 158efb88c1ecc59c3dc195eed6a68bfe87fd9aaf.
    Re-opens #5792 in 3.5 branch (3.5.1dev)
    References #5786
diff --git a/NEWS b/NEWS
index 49b861726..5bf942ac4 100644
--- a/NEWS
+++ b/NEWS
@@ -6,8 +6,6 @@ PostgreSQL 12-17 required. GEOS 3.8+ required. Proj 6.1+ required.
 * Bug fixes *
-- #5792, Prevent topology corruption with TopoGeo_addPoint near almost
-         collinear edges (Sandro Santilli)
 - #5795, Fix ST_NewEdgesSplit can cause invalid topology
          (Björn Harrtell)
 - #5794, Fix crash in TopoGeo_addPoint (Sandro Santilli)
@@ -19,7 +17,7 @@ PostgreSQL 12-17 required. GEOS 3.8+ required. Proj 6.1+ required.
          to allow pg_upgrade (Regina Obe)
 - #5800, PROJ compiled version reading the wrong minor and micro
          (Regina Obe)
-- #5790, Non-schema qualified calls causing issue with
+- #5790, Non-schema qualified calls causing issue with
          materialized views (Regina Obe)
 * Enhancements *
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index e137ef336..93e98681e 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -5287,7 +5287,7 @@ _lwt_SnapEdgeToExistingNode(
   for ( n=0; n<2; ++n)
     int forward;
-    /* TODO: directly get full existing edge rather than just id */
+    /* TODO: directly get full existing edge rather than just id * */
     LWT_ELEMID existingEdgeId = _lwt_GetEqualEdge( topo, lwgeom_as_lwline(splitC->geoms[n]), &forward );
     if ( existingEdgeId == -1 )
@@ -5408,74 +5408,8 @@ _lwt_SnapEdgeToExistingNode(
       splitNodeNewEdgeOutgoing = 0;
-    /* TODO: check that newSplitEdgeLine part does not cross any other edge ? */
+    /* TODO: check that newSplitEdgeLine part does not crosses any other edge ? */
     /* TODO: check that newSplitEdgeLine retains its position in the edge end star (see ticket #5786) */
-    /* TODO: check that the motion range does not contain any node */
-      // build the motion range shape: splitC->geoms[0] + splitC->geoms[1] - edge->geom
-      POINTARRAY *motionRange = ptarray_clone_deep(lwgeom_as_lwline(splitC->geoms[0])->points);
-      ptarray_append_ptarray(motionRange, lwgeom_as_lwline(splitC->geoms[1])->points, 0);
-      POINTARRAY *reverseNewLine = ptarray_clone_deep(edge->geom->points);
-      ptarray_reverse_in_place(reverseNewLine);
-      ptarray_append_ptarray(motionRange, reverseNewLine, 0);
-      ptarray_free(reverseNewLine);
-      // motionBounds takes ownership of motionRange
-      LWLINE *motionBounds = lwline_construct(topo->srid, NULL, motionRange);
-      // motionPoly takes ownership of motionBounds
-      LWGEOM *motionPoly = (LWGEOM *)lwpoly_from_lwlines(motionBounds, 0, NULL);
-      LWDEBUGG(1, motionPoly, "Motion range");
-      // check the Motion range doesn't cover any of
-      // the edges incident to the split node other
-      // than the existing edge
-      GEOSGeometry *motionPolyG = NULL;
-      for ( uint64_t t=0; t<splitNodeEdges->numEdges; t++ )
-        LWT_ISO_EDGE *e = &(splitNodeEdges->edges[t]);
-        GEOSGeometry *eg;
-        if ( e == existingEdge ) continue;
-        if ( e == edge ) continue;
-        if ( ! motionPolyG ) {
-          motionPolyG = LWGEOM2GEOS( motionPoly, 0 );
-            lwerror("Could not convert edge geometry to GEOS: %s", lwgeom_geos_errmsg);
-            return -1;
-        eg = LWGEOM2GEOS( lwline_as_lwgeom(e->geom), 0 );
-        if ( ! eg )
-          return -1;
-        int covers = GEOSCovers( motionPolyG, eg );
-        // TODO: use preparedCovers ?
-        GEOSGeom_destroy(eg);
-        if (covers == 2)
-          lwerror("Covers error: %s", lwgeom_geos_errmsg);
-          return -1;
-        if ( covers )
-          lwgeom_free(motionPoly);
-          lwerror("snapping edge %" LWTFMT_ELEMID
-            " to new node moves it past edge %" LWTFMT_ELEMID,
-            edge->edge_id, e->edge_id
-          return -1;
-      if ( motionPolyG ) GEOSGeom_destroy(motionPolyG);
     LWDEBUGF(1, "Existing edge %"
         LWTFMT_ELEMID " (post-modEdgeSplit) next_right:%"
diff --git a/topology/test/regress/topogeo_addpoint_merge_edges.sql b/topology/test/regress/topogeo_addpoint_merge_edges.sql
index 1cc0d59bf..fc0fff28d 100644
--- a/topology/test/regress/topogeo_addpoint_merge_edges.sql
+++ b/topology/test/regress/topogeo_addpoint_merge_edges.sql
@@ -425,20 +425,4 @@ SELECT * FROM runTest('multi-merge-closest-not-containing-projected',
   ], 'POINT(12.472410859513998 70.77020397757477)', 0
 ) WHERE true ;
-SELECT * FROM runTest('#5792.0',
-  ARRAY[
-    'LINESTRING(11.812075769533624 59.77938755222866,11.811862389533625 59.77938237222866)',
-    'LINESTRING(11.811862389533625 59.77938237222866,11.811969079533624 59.77938496222866,11.812075769533624 59.77938755222866)'
-  ], 'POINT(11.812029186127067 59.7793864213727)', 0
-) WHERE true ;
-SELECT * FROM runTest('#5792.1',
-  ARRAY[
-    'LINESTRING(11.811862389533625 59.77938237222866,11.811969079533624 59.77938496222866,11.812075769533624 59.77938755222866)',
-    'LINESTRING(11.811862389533625 59.77938237222866,11.811969079533624 59.77938,11.812075769533624 59.77938755222866)'
-) WHERE true ;
 DROP FUNCTION runTest(text, geometry[], geometry, float8, bool);
diff --git a/topology/test/regress/topogeo_addpoint_merge_edges_expected b/topology/test/regress/topogeo_addpoint_merge_edges_expected
index 994187546..90b2a3d21 100644
--- a/topology/test/regress/topogeo_addpoint_merge_edges_expected
+++ b/topology/test/regress/topogeo_addpoint_merge_edges_expected
@@ -29,5 +29,3 @@ full-merge-exterior-face|-checking-
 double-merge-forward-backward|-checking-
 multi-merge-forward-backward|-checking-
 multi-merge-closest-not-containing-projected|-checking-
-ERROR:  snapping edge 2 to new node moves it past edge 3
Summary of changes:
 NEWS                                               |  4 +-
 liblwgeom/topo/lwgeom_topo.c                       | 70 +---------------------
 .../test/regress/topogeo_addpoint_merge_edges.sql  | 16 -----
 .../regress/topogeo_addpoint_merge_edges_expected  |  2 -
 4 files changed, 3 insertions(+), 89 deletions(-)
hooks/post-receive
