[SCM] PostGIS branch master updated. 3.5.0-68-g41eae976e
git at osgeo.org
git at osgeo.org
Fri Nov 15 14:48:27 PST 2024
the project "PostGIS".
via 41eae976e5d955e41db2934124315d6cf63fb712 (commit)
from ddb7dfa0519108baf41faead8b6c682703a371b1 (commit)
revisions in full, below.
commit 41eae976e5d955e41db2934124315d6cf63fb712
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Nov 15 23:48:01 2024 +0100
Include default origin value for ST_Square documentation
Also fix a misleading information about SRID of returned square
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index 63c250664..819527f6b 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -1217,7 +1217,7 @@ FROM admin0 WHERE name = 'Canada'
<paramdef><type>float8</type> <parameter>size</parameter></paramdef>
<paramdef><type>integer</type> <parameter>cell_i</parameter></paramdef>
<paramdef><type>integer</type> <parameter>cell_j</parameter></paramdef>
- <paramdef choice="opt"><type>geometry</type> <parameter>origin</parameter></paramdef>
+ <paramdef choice="opt"><type>geometry</type> <parameter>origin='POINT(0 0)'</parameter></paramdef>
</funcprototype>
</funcsynopsis>
</refsynopsisdiv>
@@ -1228,7 +1228,11 @@ FROM admin0 WHERE name = 'Canada'
<para>Uses the same square tiling concept as <xref linkend="ST_SquareGrid"/>, but generates just one square at the desired cell coordinate. Optionally,
can adjust origin coordinate of the tiling, the default origin is at 0,0.
</para>
- <para>Squares are generated with no SRID set, so use <xref linkend="ST_SetSRID"/> to set the SRID to the one you expect.</para>
+ <para>
+Squares are generated with the SRID of the given origin.
+Use <xref linkend="ST_SetSRID"/> to set the SRID if the given origin
+has an unknown SRID (as is the case by default).</para>
<para role="availability" conformance="3.1.0">Availability: 3.1.0</para>
</refsection>
Summary of changes:
doc/reference_constructor.xml | 8 ++++++--
1 file changed, 6 insertions(+), 2 deletions(-)
hooks/post-receive
