[SCM] PostGIS branch master updated. 3.5.0-74-gf0d1ee2d6
git at osgeo.org
git at osgeo.org
Mon Nov 18 11:01:12 PST 2024
the project "PostGIS".
via f0d1ee2d6146286c450abb7d37074cd3eb45872d (commit)
from 31a5529dec9ad608fa5a7757cbc2844824d29fd3 (commit)
revisions in full, below.
commit f0d1ee2d6146286c450abb7d37074cd3eb45872d
Author: Regina Obe <lr at pcorp.us>
Date: Mon Nov 18 13:41:51 2024 -0500
Add 3.6 new section, and fix >= tags in SFCGAL
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index b03153023..00a6e4698 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -3025,7 +3025,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
<para>Computes the straight skeleton partition of the input polygon geometry <parameter>geom</parameter>.
The straight skeleton is a partitioning of the polygon into faces formed by tracing the collapse of its edges.
If <parameter>auto_orientation</parameter> is set to true, the function will automatically adjust the orientation of the input polygon to ensure correct results.</para>
- <para role="availability" conformance="3.6.0">Availability: 3.6.0 - requires SFCGAL >= 2.0.0.</para>
+ <para role="availability" conformance="3.6.0">Availability: 3.6.0 - requires SFCGAL >= 2.0.0.</para>
<para>&sfcgal_required;</para>
</refsection>
<refsection>
@@ -3064,7 +3064,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
0: Rounded buffer (default)
1: Flat buffer
2: Square buffer</para>
- <para role="availability" conformance="3.6.0">Availability: 3.6.0 - requires SFCGAL >= 2.0.0</para>
+ <para role="availability" conformance="3.6.0">Availability: 3.6.0 - requires SFCGAL >= 2.0.0</para>
<para>&Z_support;</para>
<para>&P_support;</para>
@@ -3100,7 +3100,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
<para>Rotates the input geometry <parameter>geom</parameter> by <parameter>angle</parameter> radians around the origin point (0,0).
The rotation is performed in 2D space; Z coordinates are not modified.
Positive angles rotate the geometry counter-clockwise.</para>
</refsection>
<refsection>
@@ -3135,7 +3135,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
<para>Rotates the input geometry <parameter>geom</parameter> by <parameter>angle</parameter> radians around the point (<parameter>cx</parameter>, <parameter>cy</parameter>).
The rotation is performed in 2D space; Z coordinates are dropped.
</refsection>
<refsection>
@@ -3170,7 +3170,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
<title>Description</title>
<para>Rotates the input geometry <parameter>geom</parameter> by <parameter>angle</parameter> radians around an axis defined by the vector (<parameter>ax</parameter>, <parameter>ay</parameter>, <parameter>az</parameter>) passing through the origin (0,0,0).
</para>
</refsection>
@@ -3203,7 +3203,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
<para>Rotates the input geometry <parameter>geom</parameter> by <parameter>angle</parameter> radians around the X-axis.
</para>
</refsection>
@@ -3236,7 +3236,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
<para>Rotates the input geometry <parameter>geom</parameter> by <parameter>angle</parameter> radians around the Y-axis passing.
</para>
</refsection>
@@ -3269,7 +3269,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
<para>Rotates the input geometry <parameter>geom</parameter> by <parameter>angle</parameter> radians around the Z-axis.
</para>
</refsection>
@@ -3302,7 +3302,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
<para>Scales the input geometry <parameter>geom</parameter> by a uniform scale <parameter>factor</parameter> in all dimensions (X, Y, and Z).
The scaling is performed relative to the origin point (0,0,0).</para>
</refsection>
<refsection>
@@ -3336,7 +3336,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
<para>Scales the input geometry <parameter>geom</parameter> by different factors along the X, Y, and Z axes.
</refsection>
@@ -3373,7 +3373,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
<refsection>
<para>Scales the input geometry <parameter>geom</parameter> by different factors along the X, Y, and Z axes, relative to a specified center point (<parameter>centerX</parameter>, <parameter>centerY</parameter>, <parameter>centerZ</parameter>).</para>
</refsection>
@@ -3407,7 +3407,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
<para>Translates the input geometry <parameter>geom</parameter> by adding <parameter>deltaX</parameter> to the X coordinates and <parameter>deltaY</parameter> to the Y coordinates.
Z coordinates are dropped.</para>
</refsection>
<refsection>
@@ -3440,7 +3440,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
<refsection>
<para>Translates the input geometry <parameter>geom</parameter> by adding <parameter>deltaX</parameter> to the X coordinates, <parameter>deltaY</parameter> to the Y coordinates, and <parameter>deltaZ</parameter> to the Z coordinates.</para>
</refsection>
diff --git a/doc/xsl-config.xml b/doc/xsl-config.xml
index f201d8cd5..ca99fec12 100644
--- a/doc/xsl-config.xml
+++ b/doc/xsl-config.xml
@@ -21,6 +21,7 @@
<!-- List of maj/min versions we want to know about -->
<postgis_versions>
+ <v>3.6</v>
<v>3.5</v>
<v>3.4</v>
<v>3.3</v>
Summary of changes:
doc/reference_sfcgal.xml | 26 +++++++++++++-------------
doc/xsl-config.xml | 1 +
2 files changed, 14 insertions(+), 13 deletions(-)
hooks/post-receive
